Go Back   Saturn Sky Forum > In the News > General Automotive Industry News
Old 12-20-2007, 01:03 PM   #1 (permalink)
2009 ZR1 Corvette Announced
2009 Corvette ZR1 Powered By The Most Powerful Production Engine Ever From GM: The Supercharged LS9 Small-Block V-8
PONTIAC, Mich. – When it arrives next summer, the 2009 Chevrolet Corvette ZR1 will be the most powerful and fastest production car ever produced by General Motors, with performance enabled by a new, supercharged 6.2L LS9 small-block V-8 engine.
Incorporating the engineering experience already found in the Corvette Z06’s LS7 engine and the new-for-2008 6.2L LS3 of the Corvette, GM Powertain is targeting 100 horsepower per liter for the LS9, or 620 horsepower (462 kW), and approximately 595 lb.-ft. of torque (807 Nm); final SAE-certified power levels will be available in early March 2008.
It is, indeed, the ultimate small-block engine for the ultimate Corvette.
“When you experience the LS9 in the Corvette ZR1, the terms performance and refinement take on a new meaning,” said Tom Stephens, group vice president for GM Powertrain and Quality. “The LS9 demonstrates an outstanding performance range, with smooth driveability at low speeds, and surprisingly fierce performance when the customer wants more power.”
The enabler of the LS9’s performance is a new, large positive-displacement Roots-type supercharger – with a unique four-lobe design – developed for the engine by Eaton. It is teamed with an integrated charge cooling system that reduces inlet air temperature for maximum performance. The LS9 represents the first of several new, supercharged small-block engines that will be introduced in GM vehicles in the near future, each using superchargers of similar design.
“The small-block V-8 once again demonstrates it boundless horsepower potential, versatile design and an architecture with proven quality, durability and reliability,” said Stephens. “We haven’t yet realized the small-block’s performance potential.”
Performance range
More than just its tremendous peak horsepower and torque numbers, the supercharged LS9 makes big power at lower rpm and carries it in a wide arc to 6,600 rpm. GM Powertrain testing shows the engine makes approximately 300 horsepower (224 kW) at 3,000 rpm and nearly 320 lb.-ft. of torque (434 Nm) at only 1,000 rpm. Torque tops 585 lb.-ft. (793 Nm) at about the 4,000-rpm mark, while horsepower peaks at 6,500 rpm. The engine produces 90 percent of peak torque from 2,600 rpm to 6,000 rpm.
Heavy-duty and lightweight reciprocating components enable the engine’s confident high-rpm performance, while the large-displacement Eaton supercharger pushes enough air to help the engine maintain power through the upper levels of the rpm band.
“The sixth-generation design of the supercharger expands the ‘sweet zone’ of the compressor’s effectiveness, broadening it to help make power lower in the rpm band,” said Ron Meegan, assistant chief engineer. “To put it simply, the low-end torque is amazing.”
The LS9 is assembled by hand at GM’s Performance Build Center, a unique, small-volume engine production facility in Wixom, Mich., that also builds the Corvette Z06’s LS7 engine and other high-performance GM production engines.
Cylinder block and reciprocating assembly details
The LS9’s aluminum cylinder block features steel, six-bolt main bearing caps, with enlarged vent windows in the second and third bulkheads for enhanced bay to bay breathing. Cast iron cylinder liners – measuring 4.06 inches (103.25 mm) in bore diameter – are inserted in the aluminum block and they are finish-bored and honed with a deck plate installed. The deck plate simulates the pressure and minute dimensional variances applied to the block when the cylinder heads are installed, ensuring a higher degree of accuracy that promotes maximum cylinder head sealing, piston ring fit and overall engine performance.
Nestled inside the cylinder block is a forged steel crankshaft that delivers the LS9’s 3.62-inch (92 mm) stroke. It features a smaller-diameter ignition-triggering reluctor wheel and a nine-bolt flange – the outer face of the crankshaft on which the flywheel is mounted – that provides more clamping strength. Other non-supercharged 6.2L engines, such as the base Corvette’s LS3, have a six-bolt flange. A torsional damper mounted to the front of the crankshaft features a keyway and friction washer, which also is designed to support the engine’s high loads.
Attached to the crankshaft is a set of titanium connecting rods and forged aluminum pistons, which, when combined with the cylinder heads, delivers a 9.1:1 compression ratio. This combination is extremely durable and lightweight, enabling the LS9’s high-rpm capability.
Cylinder head details
The basic cylinder head design of the LS9 is similar to the L92-type head found on the LS3 V-8, but it is cast with a premium A356T6 alloy that is better at handling the heat generated by the supercharged engine – particularly in the bridge area of the cylinder head, between the intake and exhaust valves.
In addition to the special aluminum alloy, each head is created with a rotocast method. Also known as spin casting, the process involves pouring the molten alloy into a rotating mold. This makes for more even distribution of the material and virtually eliminates porosity – air bubbles or pockets trapped in the casting – for a stronger finished product.
Although the heads are based on the L92 design, they feature swirl-inducing wings that are cast into the intake ports. This improves the mixture motion of the pressurized air/fuel charge. The charge enters the combustion chambers via titanium intake valves that measure 2.16 inches (55 mm) in diameter. Spent gases exit the chambers through 1.59-inch (40.4 mm) hollow stem sodium-filled exhaust valves. The titanium intake and sodium-filled exhaust valves are used for their lightweight and high-rpm capability.
To ensure sealing of the pressurized engine, unique, four-layer steel head gaskets are used with the LS9’s heads.
Camshaft and valvetrain
The broad power band enabled by the LS9’s large-displacement supercharger allows it to make strong low-end torque and great high-rpm horsepower, which allowed engineers to specify a camshaft with a relatively low lift of 0.555-inch (14.1 mm) for both the intake and exhaust valves. This low-overlap cam has lower lift and slower valve-closing speeds than the Z06’s 505-horsepower (377 kW) LS7, helping the LS9 – with its approximately 620 horsepower – deliver exemplary idle and low-speed driving qualities.
The camshaft actuates a valvetrain that includes many components, including the lifters, rocker arms and valve springs, of the LS3 engine. However, LS7 retainers are used to support the engine’s high-rpm performance.
Supercharger and charge cooler details
The LS9’s R2300 supercharger is a sixth-generation design from Eaton, with a case that is specific to the Corvette application. The supercharger features a new four-lobe rotor design that promotes quieter and more efficient performance, while its large, 2.3-liter displacement ensures adequate air volume at high rpm to support the engine’s high-horsepower aspiration. Maximum boost pressure is 10.5 psi (0.72 bar).
The supercharger is an engine-driven air pump that contains a pair of long rotors that are twisted somewhat like pretzel sticks. As they spin around each other, incoming air is squeezed between the rotors and pushed under pressure into the engine – forcing more air into the engine than it could draw under “natural” aspiration. The rotors are driven by a pulley and belt that are connected to the engine’s accessory drive system.
Because the pressurized air is hotter than naturally aspirated air, the LS9 employs a liquid-to-air charge cooling system to reduce inlet air temperature after it exits the supercharger – reducing the inlet air temperature by up to 60 degrees C (140 F). Cooler air is denser and allows the engine to make the most of its high-pressure air charge. The charge cooling system includes a dedicated coolant circuit with a remote-mounted pump and reservoir.
The design of the supercharger case and its integrated charge cooling system was driven by the space and dimensions afforded under the Corvette’s hood. To that end, the charge cooler was designed as a “dual brick” system, with a pair of low-profile heat exchangers mounted longitudinally on either side of the supercharger. Coupled with the supercharger itself, this integrated design mounts to the engine in place of a conventional intake manifold and is only slightly taller than a non-supercharged 6.2L engine. The air inlet and rotor drive pulley are positioned at the front of the supercharger.
Additional engine details
Oiling system: The LS9 uses a dry-sump oiling system that is similar in design to the LS7’s system, but features a higher-capacity pump to ensure adequate oil pressure at the higher cornering loads the ZR1 is capable of achieving. An oil-pan mounted oil cooler is integrated, too, along with piston-cooling oil squirters located in the cylinder block. The expanded performance envelope of the Corvette ZR1 required changes to the dry sump system also used in the Z06. System capacity is increased and scavenge performance improved to meet the demands of Chevrolet's highest-performance sportscar.
Water pump: To compensate for the heavier load generated by the supercharger drive system, an LS9-specific water pump with increased bearing capacity is used.
Accessory drive system: In order to package the accessory drive system in the Corvette’s engine compartment, the supercharger drive was integrated into the main drive system. This required a wider 11-rib accessory drive system to be used with the LS9 in order to support the load delivered by the supercharger.
Fuel system: The LS9 uses high-capacity 48-lb./hr. fuel injectors with center-feed fuel lines. The center feed system ensures even fuel flow between the cylinders with less noise. In order to ensure fuel system performance during low speed operation as well as under the extreme performance requirements of wide open throttle (WOT), a dual pressure fuel system was developed. This system operates at 250 kPa at idle and low speed, and ratchets up to 600 kPa at higher-speed and WOT conditions.
Throttle body: An 87-mm, single-bore throttle body is used to draw air into the engine. It is electronically controlled.
Rocker covers / ignition coils: Unique rocker covers with new, direct-mount ignition coils are used. Other Gen IV engines, such as the LS3, feature coil packs mounted to a bracket. The LS9’s direct-mounted coils offer a cleaner appearance and a shorter lead between the coil and spark plug.
Beauty cover: A special engine cover is attached to the top of the LS9. It surrounds the intercooler, which is visible through a hood window, accenting the supercharger while simultaneously reducing noise. The cover has “LS9 SUPERCHARGED” script on the left and right sides, along with a debossed Corvette crossed flags emblem on the front.
New six-speed manual transmission
The Corvette ZR1’s LS9 engine is backed by a Tremec TR6060 six-speed manual transmission, with a twin-disc clutch system. It is based on the proven T56 six-speed, but upgraded to handle the LS9’s torque output and delivers improved shift quality
The twin-disc clutch system provides exceptional clamping power, while maintaining an easy clutch effort. The system employs a pair of 260-mm discs, which spreads out the engine’s torque load over a wider area, enabling tremendous clamping power to channel the LS9’s torque. It also dissipates heat better and extends the clutch life (in normal driving).
Thanks to comparatively small plates, the twin-disc system enables similar disc inertia to the Corvette Z06, which has a 290-mm single-disc system, contributing to low shift effort and providing exceptionally smooth engagement and light pedal effort. In fact, the more powerful ZR1 has a pedal effort similar to the Z06.
ZR1-specific gearing in the transmission provides a steep first-gear ratio that helps launch the car. The car’s top speed is achieved in sixth gear – a change from the fifth-gear top-speed run-outs in the manual-transmission Corvette and Corvette Z06. The gears also are designed to balance performance with refinement. The angles of the gear teeth are optimized to provide both strength and quietness
2008 Sky Redline
Techno Gray
Red/Black Leather
Auto
Monsoon- 6 Disk
Opel GT Antenna
K&N Panel Filter
krisis7 is offline   Reply With Quote
Old 12-20-2007, 01:11 PM   #2 (permalink)
southernSKYS's Avatar
Only 100 HP per liter? My Sky puts out 130 HP per Liter
Chili Pepper Red R/L
In the garage on 06/22/07
18" Chrome wheels
Red Calipers and lettering
Upgraded Leather
3" Magnaflow quad tip
Pioneer AVIC-D3 Nav
Backup cam
Bluetooth
Stubby antenna
southernSKYS is offline   Reply With Quote
Old 12-20-2007, 01:45 PM   #3 (permalink)
SilverRedLineSky's Avatar
Agree the 2.0 has the distinction of the Most Powerful Production Engine Ever From GM @ 130 HP per liter.
2007 Silver Graphite Redline
2004 Torch Red Corvette Convertible
SilverRedLineSky is offline   Reply With Quote
Old 12-20-2007, 01:53 PM   #4 (permalink)
I love telling that to the Vett owners; It's fun to watch the veins bulge out of there neck.
18" Chrome wheels
Upgraded Leather
Pioneer AVIC-D3 Nav
Backup cam
Bluetooth
Stubby antenna
Old 12-20-2007, 06:13 PM   #5 (permalink)
Supporting Member
RedHeaded RedLine's Avatar
My Photos: (9)
Or maybe not...Thanks-tree hugging filthy hippies. -J
http://www.foxnews.com/story/0,2933,317556,00.html
Old 12-20-2007, 06:44 PM   #6 (permalink)
Ahnuld's Avatar
Viper 650... compared to the new vette
http://www.caranddriver.com/carnews/...enom-650r.html
Photos below taken at Dover Airforce Base
Ahnuld is offline   Reply With Quote
Old 12-20-2007, 07:00 PM   #7 (permalink)
Valistener's Avatar
Send a message via AIM to Valistener
Don't sell the LS9 Short.
It's well under-rated at 100hp/liter, and there is a lot more to be pulled out of that engine and no official power has been given for it.
Also I have heard that sqabble from too many Ricers. My LS1 'only' makes 61 hp/liter, under half of the redline, but its makes much more power and has just as good if not better fuel economy, plus an awesome sound.
All that from a 'dinosaur', OHV, push rodded, 2 valves per cylinder engine.
http://www.popularhotrodding.com/hot...ls9/index.html
2007 Sky
2004 GTO
1992 Camaro RS -305 V8
http://www.skyroadster.com/forums/at...0&d=1163216593
Valistener is offline   Reply With Quote
Old 12-20-2007, 10:18 PM   #8 (permalink)
doc-o-pharm's Avatar
For the visual oriented, like myself:
More here: ZR1
If I had a spare 100K+ lying around I think I might just trade in the sky for that little jewel.
'08 Chili RL
GMR Tune, Wastegate mod, PAL adaptor, Dejon IC, Custom Grill
If the Prodigal Son's a parable, and if Adam and Eve are metaphors, then maybe God is just figure of speech.
doc-o-pharm is offline   Reply With Quote
Old 12-21-2007, 01:10 AM   #9 (permalink)
We must be in Fantasyland members...u know where the SSTs r now sitting...the SMITHSONIAN for one.. Corvette, the last AMERICAN dream machine...see how the world turns.
marlboromike is online now   Reply With Quote
Old 12-22-2007, 11:28 PM   #10 (permalink)
lorennerol's Avatar
Send a message via AIM to lorennerol Send a message via MSN to lorennerol
More here: ZR1
I still think it has a fat ass- they need to drop the top edge of the rear end down 3-4 inches to accentuate the curve of rear fenders, and make it look more svelte from behind. That, or put a real bumper back on the thing.
lorennerol is online now   Reply With Quote
Old 12-23-2007, 05:06 AM   #11 (permalink)
Blue04RedLine's Avatar
Send a message via AIM to Blue04RedLine Send a message via MSN to Blue04RedLine
Real back bumper isn't very aerodynamic. They make changes like that in cars like this because of efficiency issues, be it downforce or top speed.
2004 Saturn ION Red Line
Mods:
K&N Typhoon CAI
Billetflow 2.7" pully (in blue)
GM Stage Injectors (42.5# Lucas)
GM Stage Tune
B&G Springs
Central FLorida RedLine Association (CFLRA) - Member #5
Blue04RedLine is offline   Reply With Quote
Old 12-23-2007, 07:05 AM   #12 (permalink)
jel
jel's Avatar
This is the last time I pump my own gas! It's becoming so mundane!
JPM leather dash
Dual XDVD8285
Interior carbon fiber kit
Wind Restrictor V2
Fujita dual filter CAI
Kappasphere KS2/Li'l Chromies
Blackcat gauges
Billet grille
O-series stubby/FlameBall shifter
V doors
Sequential brake/3rd pulsating lights
Old 12-23-2007, 09:22 AM   #13 (permalink)
Ernest's Avatar
My Photos: (10)
LS motor's come from the factory severely detuned(thanks to the gov't ). A simple tune and air intake will bring you an instant noticeable increase in power/performance. The secret to the LS motor is breathing. Better it breathes the stronger they run, trust me on this. I added over 50 rwhp /50 rwt on my LS7 with simple bolt on mods and performance tune
The new ZR-1 is an awesome machine, however you can buy a Z06 for a lot less and with the money you saved can mod it to run faster than the ZR-1 and still have money in the bank
ERNEST
'04 Torch Red Corvette Coupe
'07 Corvette Z06 "Scarlett"
Victory Red
555.6 rwhp / 485.5 rwt N/A - No Spray
Myspace www.myspace.com/ernest06z06
Scarlett's 10.97 @ 127 Video www.youtube.com/watch?v=NWEaFz9hn8s
Ernest is offline   Reply With Quote
Old 12-24-2007, 02:44 AM   #14 (permalink)
larry4pyro's Avatar
Hi, I ran across a lot of detailed pictures of the ZR1's 6.2 L V8 on GM's media site:
http://media.gm.com/servlet/com.gm.m...ogon?key=09ls9
Check out the location of the intercooler!
Larry4pyro
larry4pyro is offline   Reply With Quote
Old 12-24-2007, 11:22 AM   #15 (permalink)
Celt03's Avatar
AMAZING.
My husband has uttered a phrase that I never thought I would hear out of his mouth in regards to a Corvette - "don't like it".
I about fell over hearing this from a man who loves Corvettes & has owned several.
www.imsaturn.com/profile/Celt
Old 03-07-2008, 11:07 PM   #16 (permalink)
Wow, I'd love to own one, but that'll never happen.
operatic is offline   Reply With Quote
