Hi,
I just bought a 2008 saturn Sky and loving it, however whe I go to close my roof, the handle will not go all the way to seal it. I have to pull the roof down with one hand in order to crank it closed. Has this happened to anyone else and if so how did you fix it? Thanks you in advance.
Cheers,
SuzieQ
Congrats on your new Sky!
As for the top latching issue, I've never encountered that, but over time I have found that I have to take an extra few seconds to line my top up with the pin holes before closing latch. When I got her new, the top closed easily but I suspect that over time the alignment has changed slightly.
____________
2008 Sky Redline Silver Pearl & Black Leather
Three Pedals
Pretty basic set-up:
Monsoon stereo/ 6-disk CD
Splash Guards
Personal Audio Link for iPod
It is not unusual to have to pull down on the front of the top to get it to latch. I do it with both our Kappas.
If it is very hard to pull down, consider reducing the tension on the top a bit. There is an adjustment screw stop on each side on the back side of the tulip panel. That is on the left and right sides of the front of the trunk. There is a kind of round foot that is mounted on a stud with a lock nut. When you screw the foot out, to wards the rear of the car, it tightens up the top. If you screw each foot in slightly it will lower the tension on the top and should make closing it easier.
The trick is to make sure you get the same tension on both sides, left and right, and that you have enough tension to keep the top taught.
Mine is looser than that and falls into place just fine. However, I may well actually increase the tension on mine so I have to pull it down. The trouble with being loose is that the pins don't match with the holes in the windshield every time and end up scratching the plastic - or worse, possibly tearing the rubber seal.
Be carefull what you wish for
__________________ Owner of "Campbelle", a Brazen 2008 GXP ... with mods piling up...
I just had another thought... you ARE lowering your side windows a couple of inches (or opening the doors) before closing the top, right? If not, you MUST do so to prevent wear on the seals and avoid closing problems similar to what you describe.
I'm not sure if this is the same issue, but I had problems closing the top when I bought mine earlier this year. The metal bar that extends from the roof (the latch) was a little to high and I had to pull down on that metal bar in order for it to get around the pin on the top of the windshield frame. I finally did fix it and it was quite simple. I took some pliers and simply bent down the metal bar that extends out on the latch just a tiny bit. Now it works great. Supposedly if put the top down with the latch in the closed top position it bends the latching bar up a little and out of alignment with the pin. I assume that's what the previous owner did.
2008 Sky Redline
Manual
GMPP Tune
DDM Works IC Charge Tubes
Solo High Flow Catalytic Converter
If I have my top down for most of the summer and try to put it up, it takes a little effort because the top seems to have slightly shrunk but once everything is aligned up, windows down, it locks in place. Also I found that the wind restrictor, if left in place, puts a little pressure against the rear window of the top, making it harder to pull the top closed. I usually remove the wind restrictor before putting the car for the winter.
efbrodiesr
2008 2.4
Silver Pearl
Red Leather interior
Black top
No modifications
THAT was my initial thought.
Another problem that could happen is that if underneath the tulip panels there is a wire connected with a cheap plastic locking mechanism that opens the panels and especially when closing the top, IF those cheap plastic locking devices wear out or break & the elbow works its way off the tulip panels connection spot you cannot close the top without "someone manually" holding the tulip panel open then close the top. IF the panels don't open, there is NO way to close and lock the top without causing further damage "somewhere". I posted a thread on these things awhile back. In fact, on my drivers side the lead elbow is now broken, either I have to see if the cable can be replaced or make a modification to the mechanism.. IF or when the dealer states its not repairable I will invent a better system and I will post the details then. First however I have to replace the internals of BOTH windows, (wires corroded, which of course include the windows motors) assuming those parts are still available. At the moment I can't lower either one..
"No man is good enough to govern another man without that others consent." ~ Abraham Lincoln
"The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so." ~ Ronald Reagan
mine was hard to get shut,the latch was bent and the dealership repaired it for me,it works fine now.i think its to do with the latch when you tuck it away in your trunk,that is if the latch is left open.
Hi,
Cheers,
SuzieQ
Welcome aboard!. Please update us on the status on your latching issue and if it's been repaired. Have a good week and I hope you're enjoying your new Sky!
