» Sponsors
» Sponsors
Register Home Forum   /  Current Posts Gallery Register Search Today's Posts Mark Forums Read
SkyRoadster.com is the largest Saturn Sky Forum on the internet. Registered Users do not see the above ads.
Old 09-02-2008, 07:37 AM   #31 (permalink)
SKY 07's Avatar
Hmmmmm I love it. Something I need to have done. Nice job xmRedline. T.
07 White/Delivered 6/28/06
Leather Seats
Chrome Rims
Monsoon 6 Disc
Rear Spoiler
Dual Exhaust/CAI
Custom WindRestictor/Custom Pinstriping
and who knows what else....
Life Is Good
SKY 07 is offline   Reply With Quote
Old 09-02-2008, 08:43 AM   #32 (permalink)
08BlueSky's Avatar
My local "supermarket" auto part shops only had the 4 prong (normally open) type - ended up at NAPA $11 ea - A bit ? pricey but they were quality units, should hold up well over the years..
08BlueSky is offline   Reply With Quote
Old 09-02-2008, 09:13 AM   #33 (permalink)
Originally Posted by xmicro_Redline View Post
Mike, just use any relay, in the Caddi the relay may be all the way back in the wiring, it will not work for our set-up anyway.
Don't be afraid, this one is easy!
Not afraid...I have the master electrician on call...TOM (07Bluestone)
Old 09-02-2008, 11:34 AM   #34 (permalink)
Supporting Member
ceeker's Avatar
My Photos: (16)
I have the 4 pins on now but waiting for the new 5 pins to come in.
I did try the 5 pin from checker but they keept blowing the fuse. I checked the module and it's sending extra voltage to the marker lights causing the fuse to blow.
At least the two I bought did, they were the only ones checker carried. They also seam pretty cheap, so I'd suggest you not use these!
Silver/RL 2007 - Red/Black Leather
DeJon CAI, IC Pipes
Magnaflow, Opel Badges, Tail Lights, Back Up Light.
Hahn Intercooler, Westers Race Tune.
ceeker is offline   Reply With Quote
Old 09-02-2008, 11:45 AM   #35 (permalink)
Barry's Avatar
My Photos: (49)
Originally Posted by dipolley View Post
I found an easier way. At least on the sky. No idea how the solstice is wireloomed, but based on the pictures it is a tiny bit different.
1)Follow the side marker wireing (in the loom) where it meets with the loom to the turn signal. Both go into a larger loom.
2)Cut the electrical tape with a razor blade on the larger piece of loo from the point where the two meet and go 6 inches. Gently so you do not accidently cut the wires. Remove the electrical tape and pull the wires out.
3) There is one set of 4 wires to the front turn signal (blue, black, purple, brown). Seperate out the blue and black.
4) The other set is 2 wires for the side marker (black and brown). Cut this brown wire, strip back, and connect female spades to each end. Connect one side to 87A and the other to 30
5) Refering to step 3, tap the blue and black. Using a wire tap, and a 4 inch piece of wire with end connectors, connect the blue to 85 and black to 86.
6) bundle and place wires back into loom. Use black electrical tape to tidy up, and secure relay with black zip tie.
I found this to be better than running cables all over and you do not have to remove any connectors.
Pictures tomorrow.
Kudo's to DeepBlueGXP and Dipolley for this mod. Dipolley's layout is perfect, however I had to do it the Florida way
Befor step one wait for the outside temp to drop to 90 and humidity around 90 as well during step 2 wipe your sweat of the car and swat at the mosquito's.
During step 3 and 4, check for tropical storms and hurricanes...swat at bugs adjust your boy's..pull up pant's.
During step 5 wipe off more sweat; you realize how dirty the engine compartments..yell back at the wife "it's none of your' business"...start swearing at the bugs...check for rain
After step 6; you realize that you can accomplish anything (that someone else spells out for you) and how heavy your clothing becomes when it's soaked with sweat...pull your pants up again..adjust the boy's swat at more bugs and be thankfull for no storms.
I See Red Lines
08 Sky Red Line Silver - 12-16-07
07 Ion
07 Sky Red Line Silver - 9-22-06
07 Base Sky Silver - 3-06
07 Aura
07 Saturn Outlook XR
06 Saturn Vue
4-04 Ion Red Lines
2-03 EFX Ion Coupes
2-02 EFX SC2 Coupes
2-98 SL2's
Barry is offline   Reply With Quote
Old 09-02-2008, 01:52 PM   #36 (permalink)
xmicro_Redline's Avatar
When following Dipolley's method I had to switch the position of the Blue and Black taped wires in order for it to work properly. This may be the relays I bought, or he just transposed the numbers. EIther way, this is an awesome mod!
Old 09-02-2008, 02:26 PM   #37 (permalink)
G8TR's Avatar
My Photos: (3)
Ordered my relays from the aforementioned place on line. Bought a few extra so if anyone in TBR wants it done. Relays should be here this week. Looks like an easy mod and enhances the car.
Riding High In My Sky
G8TR is offline   Reply With Quote
Old 09-02-2008, 02:31 PM   #38 (permalink)
Just bought mine from PepBoys...the Brand is BWD and their part number is R3177...it is 5 prong and made in China...here goes nothing...dum de dum dum
It has on the module the same diagram as DeepBlue has...although the unit does not have the availability to put a screw into it...i liked that module better.
Old 09-02-2008, 04:04 PM   #39 (permalink)
G8TR's Avatar
My Photos: (3)
MM, let me know how it turns out and if you are doing the first or second version (with spade connection). I'd like to know which is easier and better able to be kept out of harm's way.
Old 09-02-2008, 04:18 PM   #40 (permalink)
Luv2BGrrl's Avatar
Send a message via AIM to Luv2BGrrl Send a message via Yahoo to Luv2BGrrl
I just ordered the relays from the website, but I also discovered they have pre-wired plugs for the relay so all you have to do is splice the wires to the cut wires you make in the car wiring! How simple is that! And if the relay should die, pop it out and put new one in!
Just an idea!
Linda Ann
North Beach, MD
07 Silver Graphite with red/black
plate "SKYGRRL"
Mods:
VectorSports ECM
Third brake light, sequential rear and sidemarker turn signals
DMV Solstice and Sky Meetup Group
IMSaturn
MySpace
Luv2BGrrl is offline   Reply With Quote
Old 09-02-2008, 04:41 PM   #41 (permalink)
G8TR's Avatar
My Photos: (3)
Just an idea!
Did you get the plugs from them also?
Old 09-02-2008, 05:27 PM   #42 (permalink)
I CHEATED>>>it was 95 degrees and inside the garage was hotter...I brought my car to an auto detailer...handed him the modules..told him to do the dirty deed...69 dollars later...DONE! Sometimes, it's nice to watch someone else sweat.
Old 09-02-2008, 05:28 PM   #43 (permalink)
G8TR's Avatar
My Photos: (3)
Being from Florida I understand the heat problem.
Old 09-02-2008, 05:33 PM   #44 (permalink)
I'll be in Fla this winter...will look up all the forum members like last year. Had a great time meeting everyone.
Old 09-02-2008, 06:09 PM   #45 (permalink)
wj3a's Avatar
It has on the module the same diagram as DeepBlue has...although the unit does not have the availability to put a scew into it...i liked that module better.
Whoops, I got the 5 prong Tridon EP27 from Pep Boys and blew two fuses before I put a meter on the connections for the side marker wires and discoverd a pulsing DC voltage there. Lower than the blinker connection voltage but still there.
At least I learned where the spare fuses are located (under the passenger-side mat) and where the light fuse is (the underhood fuse block) at position #69.
I'm still not convinced where the relay should be located. The wiring is easy enough to dress no matter where you put it.
08 2.4L SKY
Forest Green/Tan/Black-Tan
Fujita CAI
Vector ECM Tune
Magnaflow Catback
Hahn Stage II (to come)
FUN SKY
wj3a is offline   Reply With Quote
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin®. Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
