Coolant temperature
So, being as auto uneducated as i am, have no idea what this is. Something to do with the radiator maybe? What's heating at Xdegrees when i read the gauge?
Also, when you start the car in the morning, at what temperature is the motor considered to be warm so you can drive away?
Black Onyx RedLine 6-disc CD Spoiler Red interior Chrome Wheels 5spd Deposit: Aug 21st, 2006 Delivery: Dec 9th, 2006 Location: Southern CT. |
#2 (permalink) |
There are multiple coolant temp sensors. What you are seeing on the DIC read out is probably the coolant temp at, or near, the thermostat. If you actually keep an eye on the temp read out on the DIC you will see that the engine warms up VERY fast. The current wisdom is to start the car, idle it for a VERY short time (less than a minute unless it is quite cold outside) and drive away at a moderate pace. After just a mile or two you'll see about 140-170 deg and be getting heat from the dash. Basically, start the car, buckle up, tune the radio, and go drive. Extended idling is just a waste of gas and time. HTH.
Redline (pre-halt), Pearl, Black/Red, complete option list except auto, owner installed lock buttons, painted calipers, Solo Performance 3" single cat-back, Koni S/A's, Kurt hitch, OZ's, 295/30 Hoosiers for Solo's |
#3 (permalink) |
I notice that my coolant seems to be running between 200 - 212 degrees, is that too hot?
I'll take a BlueStone Sky, Redline please, Stitched not Smooth! MACH SKY RL Auto(Stomp 'n Go),Tan/Tan 6 CD,XM,Chrome Dep. 3/11/2006 1100 6/7/2006 #KFPZ7Q BlueStone 6/27/06 3800 10/18/06 VIN #115455 6000 11/03/06 Delivered! Home 11/05/06 |
#4 (permalink) |
These cars tend to run what we consider hot.
Even in winter my car runs about 195-200. In the summer add 10 to 15 degrees. . . And SnaponBob -- you quoted exactly what I do... So it HAS to be right!
#5 (permalink) | |
1st Known SKY RedLine Owner!
If it's a really cold morning (30's and below) and the coolant temp rises slowly the car will hold idle at 1500 rpm for around 2.5 - 3 minutes before dropping to 800. |
#6 (permalink) | |
This is apparently normal?
I was a little concerned as well... seeing my temp running between 199-210. That does seem a little hot. Wonder what temp. thermostat is in the Redline? ![]()
07 Sky REDLINE BLUESTONE /Auto/Monsoon/Spoiler/chrome On The Road - 12-27-06- 4 month wait VIN # ......121803 TAG- A BLU SKY Inflicted with "Perma Grin" |
#7 (permalink) | |
Yup, that's exactly what mine does, just didnt know it was correlated with the coolant temp as i have no idea what it is.
#8 (permalink) |
The thermostat opens at around 190 F, and the fan starts at around 215 F.
Using the air conditioner seems to start the fan sooner, since when I had it on I don't remember seeing any temps above about 210 F. Having the heat on full hot seems to result in a higher operating temperature, but I don't know if that is fact or illusion. I start out cold with very little idling, pretty much in line with Bob and Rick. I don't use a lot of throttle, and short shift until I see 190 F on the DIC.
#9 (permalink) |
Same, same
Same here.
----RedLine---- Chili Pepper Red : Tan Top/Leather Auto Trans MP3 Monsoon Stereo VIN - 10294 8 SEP 2006 - In the drivers seat with a ... “Permanent Big Grin” : Confessions of a Sky owner |
#13 (permalink) |
Water boils at 212* F. GOODanti-freeze takes H2o to 240 or so ,,,, depending on barometric pressure and such,,,,, U DO The Math!!!?!
Late '07 R/L Sil/Pearl 3 pedels Chrome Blk. Leather/Top Single Disc Monsoon Purigen 98 http://purigen98.com/index.html |
