Old 03-23-2007, 02:21 AM   #1 (permalink)
Skyflare's Avatar
My Photos: (5)
Found a Hole in SkyFury
Is this normal? SkyFury has a gap, next to the liscense plate light area, and a hole from that gap then goes up into the trunk area. Is this gap normal or did someone forget to add a gasket or cover plate for the liscense plate light area. The hole, which I can see daylight looking from the trunk area, could be normal, but the gap, at the plate that lets the light in, doesn't seem right. It looks to me like water can get up into the trunk from there. See pic below. Anyone know if this is normal, do others have this gap and or hole?
Always remember above the best is the sky and the sky is always full of stars! SKYFURY
Skyflare is offline   Reply With Quote
Old 03-23-2007, 02:38 AM   #2 (permalink)
Skip's Avatar
The gap is normal. Shut your trunk and see the air come out there. And no, water will not get into it unless you submerge the Sky in water. And no even a carwash, high pressure at that, gets up in there...Skip...
Old 03-23-2007, 09:08 AM   #3 (permalink)
Correct...and what r u doing up so early SKIP?
marlboromike is online now   Reply With Quote
Old 03-23-2007, 10:29 AM   #4 (permalink)
GaryH's Avatar
or so late....
Silver Pearl
Black/Black leather
CD/MP3 XM satellite
5 speed manual
VIN#1745
Fiamm horn
Magnaflow Quad Tip Exhaust
GaryH is online now   Reply With Quote
Old 03-23-2007, 10:47 AM   #5 (permalink)
07_SKY_RL's Avatar
Maybe that's the ventilation hole that has to go along with the emergency trunk release.
That way you won't die of asphyxiation while you're contortioned into the trunk with your feet at the side of the trunk that has the release and no way to reach it with your hands.
Chris (formerly CPK0767)
Midnight Blue/Black Leather/Black Top Red Line
07_SKY_RL is offline   Reply With Quote
Old 03-23-2007, 10:53 AM   #6 (permalink)
wt2ga's Avatar
My Photos: (13)
Originally Posted by 07_SKY_RL View Post
Maybe that's the ventilation hole .
wt2ga is offline   Reply With Quote
Old 03-23-2007, 11:26 AM   #7 (permalink)
I know what it is for... for the TRUNK MONKEY to breathe
Old 03-23-2007, 01:23 PM   #8 (permalink)
Ahnuld's Avatar
this triggered another prob for me..
i felt it important to have a seperate thread.... hope thats ok!
http://www.skyroadster.com/forums/sh...192#post176192
Photos below taken at Dover Airforce Base
Ahnuld is offline   Reply With Quote
Old 03-23-2007, 03:15 PM   #9 (permalink)
Skip's Avatar
I have not been able to sleep as well anymore...Skip...
Old 03-23-2007, 04:15 PM   #10 (permalink)
Jack Daniels and YOU...zzzzzzzzzz, No longer a problem
Old 03-23-2007, 08:36 PM   #11 (permalink)
YellowSky's Avatar
Send a message via AIM to YellowSky
Xplain how you see air??????
Opel GT conversion
ONYX Black
ADD ON
RACE PRECISION EVERYTHING
opel badges and lights
Flurecent halos
SOL black rims
FIREFIGHTER Tag "SKYYY"
YellowSky is offline   Reply With Quote
Old 03-23-2007, 11:06 PM   #12 (permalink)
Skip's Avatar
Tape a piece of paper on the rear end and slam the trunk. See air....You have to have faith brother that air moved the paper....Skip....
Old 03-24-2007, 12:16 AM   #13 (permalink)
You even hear air...it's called passing gas...u may be able to recyle it into methane...CLEAN ENEREGY
Old 03-24-2007, 01:08 AM   #14 (permalink)
Skyflare's Avatar
My Photos: (5)
Thanks Skip, Mike and others who posted replies. I feel better knowing the actual nature of this hole has a purpose and that water doesn't actually get up in there, without a dunking that is. Though it does make me think that this is just a cheap fix for exhausting air from the trunk when you close it. Saturn should have at least made it look presentable, the gap does not have to look as is to deal with the exhausting of air when you close the trunk. How expensive is a grated type vent cover in that area. But now, after reading Ahnuld's thread, about the exhaust fumes, I think it should have been a sealed trunk with some type of exhaust valve system (which would of course added more cost), but eliminated the fume issue. At least an air flow type system that vents naturally out while you drive and allows the air to escape when the trunk is closed. That might have dealt with the trunk heat issues too. I will have to think about this and how to make it look, well better. Might be one of my first mods, although no one will see it.
Ahnuld, np on the spin off thread. Good post. Thanks, it got me thinking.
