Hey Guys, I recently did a full LED swap for my sky, after searching around a bunch it was pretty hard to piece together the right bulbs (with even sylvania being wrong on one occasion) so here's a comprehensive list of all the bulbs you'll need for a full LED swap!
FRONT
Auxiliary Light above the low beam:
Bulb 194
This one's a basic 194 bulb, aim for a front single LED instead of the tower bulbs considering all of the light goes out the front anyway. I used these:
6K WHITE 4 LED 2W HIGH POWER BULBS 194 168 158 | 1 PAIR
Low Beam:
Bulb H11
Use 35W HIDs for these, they're MUCH nicer than the stock halogen. I grabbed them from DDM tuning here, they work GREAT, got the mounting brackets and that's all ya need:
DDM Tuning 35W and 55W HID Kits
High Beam:
Bulb H9
DON'T get these as HIDs, they take a bit to warm up which defeats the purpose of a high beam. Head to your local autozone and grab whatever Xenon bulbs they have to match your color scheme.
Fog Lights:
Bulb H11
HIDs work wonders for here too, same exact kit from DDM tuning I used, but you DON'T need the mounting brackets to install them:
Front Turn Signals:
Bulb 3157
LOAD RESISTORS ARE REQUIRED, MORE ON THAT AT THE END
Standard 3157 Bulb, DO NOT GET THE CK STYLE BULBS, those are meant for specific cars. I went with switchbacks to keep a white light until the turn signal is applied, but and standard 3157 tower would work too. I used these:
http://www.vleds.com/bulb/3157-3156-...57-1-pair.html
ONE THING WITH THESE: The bulb socket in our car is 3757, which they DONT make LEDs for. The only difference between 3157 and 3757 is little guide tabs on the sides of the bulbs. Just CUT THESE OFF! Watch this for instructions and proof. Worked for my car.
Side Marker Light:
Bulb 194
Because of the placement of the bulb, a mini tower (light in all directions) bulb is best to light up the entire strip. I used these:
AMBER 3 CHIP 5 LED LIGHT BULBS 194 168 158 2821 | 1 PAIR
Interior
Mirror Lights:
Bulb 194
On this, I hate sylvania. These are NOT the 212-2 light as described in their fit guide, learned that the hard way
Front facing light is best because of how sunk in the bulbs are. I used these:
Trunk Light:
Bulb 921
Because 912 is not made as an LED, 921 is compatible with no issues, and since you only need one the best place to grab em is autolumination because they sell them by the bulb. DON'T get a forward facing bulb since the bulb is mounted vertically. I used these, the 18 LED version:
906 921 Interior Lights
Rear
Tail Lights/Turn Signals:
Bulb 3157
And again, DO NOT GET CK STYLE BULBS. Make sure to order two pairs. Any red tower should work, but I got these and they're nice and bright:
http://www.vleds.com/bulb/3157-3156-.../3157-red.html
Tail Light Sidemarkers:
Bulb 194
This little guy almost went unnoticed, but I managed to find the bulb number for it. Any small bulb will work, I went with these because they look good behind the housing:
RED 1.5W LED BULBS W/ DIFFUSING LENS 194 168 158 | 1 PAIR
License Plate Light:
Bulb 194
For this light, make sure to get the mini towers since the bulb is mounted at an angle to illuminate the entire plate. I got this one:
6K WHITE 3 CHIP 5 LED LIGHT BULBS 194 168 158 2821 | 1 PAIR B/O
Reverse Light:
Bulb 3157
A single high powered front facing bulb is best for this, since the light only goes one way. I went with this one, hit ctrl+f and search "Round Globe":
3157 Tail Light Brake Light Turn Signal LED Bulbs
Opel GT Lights
Reverse Light:
Bulb 921
Use a high powered LED that has the most front facing LEDs as possible, this one should work best:
6K WHITE 19 LED 8W HIGH POWER BULBS 917 918 920 921 922 923 579 | 1 PAIR B/O - White LED - 921 LED - Bulb #
Fog Light:
Bulb 921
Same as above, luckily there's a higher powered front facing one in red!
http://www.vleds.com/bulb/921-led/re...21-1-each.html
Load Resistors
Basically if you don't get these, your turn signals will flash really fast to say you have a bulb out.
You need one pair of 6 ohm resistors for the front turn signals, and two pairs of 6 ohm resistors for the rear. I grabbed these:
http://www.vleds.com/load-resistors/...ix-1-pair.html
Grab 3 pairs of 6 ohm resistors, and the scotchlock taps too.
Install
Guides are already up with pics for the HIDs and where to hook up the resistors, so here ya go:
HID installation (hidden ballast)
Saturn Sky LED Tail lights
And there you are! Feel free to ask any questions you have, this works 100% with no problems, looks great, and is using less power on the alternator (lower wattage) So i'd like to think it's helping my MPG by a solid .1 MPG
Enjoy and happy modding!
