Issues with disconnecting battery. - Saturn Sky Forums: Saturn Sky Forum
Old 01-26-2013, 10:48 AM   #1 (permalink)
gladmaker's Avatar
When I bought my Sky last fall, the seller had a new battery installed before I picked up the car. I discovered my key fobs wouldn't work. I thought the batteries in them might be bad so I put new batteries in them and they still wouldn't work. I searched this forum and found that disconnecting the car battery would cause the remotes to not work. I had to take them to a dealer to get them re-programmed which cost me $85.
Now I'm finding advice here on the forum to disconnect the battery to reset various problems. When I installed my Probeam, the instructions said to disconnect the battery before starting the installation. I didn't do that because I didn't want to spend another $85 to reprogram my remotes.
Now I bought the VDI hinges and it also says to disconnect the battery before starting to install.
How do I disconnect the battery without risking losing programming on the remotes?
2008 Bluestone Sky Redline
Venom Brace
Backbone Brace
Woodgrain interior
Diamond pattern console cover
gladmaker is offline   Reply With Quote
Old 01-26-2013, 11:00 AM   #2 (permalink)
Disconnecting the battery shouldn't (per se) futz the remotes. However, there was a TSB for a bug in the computer firmware for this very issue. The dealership should've updated your firmware when you took it in before. If they didn't, then you should complain and get them to do it this time for free. TSB# 08-03-16-001B
Battery Issues (Especially 08 Models)
TomatoSoup is offline   Reply With Quote
Old 01-26-2013, 12:20 PM   #3 (permalink)
I agree with Soup, if your remotes don't work after disconnecting the battery I would take a copy of the TSB and ask for my money back. This is a problem most prevalent with 2008 models Sky or Solstice. For the $85 he charged you he should have reprogrammed the RCDLR module and if he did it will not loose it's memory as the update should have fixed it.
Here is the actual bulletin take a copy of this to the dealer.
TSB 08-03-16-001B
Service Information 2008 Saturn AURA | AURA, BAS Hybrid (VIN Z) Service Manual | Document ID: 2176461
#08-03-16-001B: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes on Al Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR) - (Jul 31, 2008)
Subject: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes On All Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR)
Models: 2008 Chevrolet Cobalt, HHR, Malibu
2008 Pontiac G5, G6, Solstice
2008 Saturn AURA, SKY
This bulletin is being revised to update the Important statement to reflect the new direction to no longer contact TCSC. Please discard Corporate Bulletin Number 08-03-16-001A (Section 03 - Suspension).
Condition
Some customers may comment that the key fobs are inoperative or that the TPM system is showing dashes as the reading for all four tires.
Technicians may find DTCs C0775, C0569 and B3105 set simultaneously in the RCDLR module.
In addition, the technicians may find Tire Pressure Monitoring sensors are unable to be programmed to the vehicle by adding or releasing pressure to the tire while the vehicles in the TPM learn mode.
Cause
These conditions may be caused by the following:
• The RCDLR may lose its transmitter and tire pressure monitoring data from its memory if a low voltage condition occurs on the vehicle.
• The ability for TPM learning by adding or releasing pressure to the tire has been disabled in the RCDLR.
Correction
Reprogram the RCDLR with an updated software calibration to address both issues listed above. This new service calibration is available on TIS2WEB using Service Programming System (SPS). As always, make sure your Tech 2® is updated with the latest software.
Important: If the Tech 2® could not establish communication with the RCDLR AND the programming event ended with error, attempt to reprogram in Service Programming System (SPS) by selecting "Remote Control Door Lock Receiver (TSB 08-03-16-001) with E4399 error -- Pass Thru Only".
Once the RCDLR module has been reflashed with the latest software and calibrations, the following may also be necessary:
• Relearn all keyless entry transmitters.
• Reconfigure the tire pressure placards and the tire type.
• Relearn the tire pressure sensors.
Refer to SI for the procedures to relearn transmitters, placard and tire type configuration and tire pressure sensor learn.
Warranty Information
Labor Operation
Description
Labor Time
R4481
Remote Control Door Lock Receiver (RCDLR), Reprogram with SPS
Use Published Labor Operation Time
Add:
Diagnosis Time
0.0-0.3 hr
GM bulletins are intended for use by professional technicians, NOT a ""do-it-yourselfer"". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2012 General Motors Corporation. All rights reserved.
Hoosier GXP is offline   Reply With Quote
Old 01-26-2013, 02:15 PM   #4 (permalink)
gladmaker's Avatar
Thank you for the information! He probably did do the reprogramming. I was just afraid to disconnect the battery again. With this information, I'll give it a try and see what happens.
Thank you!
Venom Brace
Backbone Brace
Woodgrain interior
Old 01-26-2013, 06:25 PM   #5 (permalink)
Rob the Elder's Avatar
My Photos: (3)
I have disconnected Punisher's battery 75-100 times. Only once did it forget the key chip! But the remotes still worked
http://www.solsticeforum.com/forum/f62/punisher-65168/
http://www.skyroadster.com/forums/f2...cussion-42115/
Old 01-26-2013, 06:40 PM   #6 (permalink)
Elff's Avatar
My Photos: (5)
Gladmaker
My stock battery completely died. It sat for 2 weeks before I installed a new battery.
While installing the new battery, the car had no battery in it for about 30 minutes.
After I was done, my remotes still worked
LUSIFER
Old 01-26-2013, 10:39 PM   #7 (permalink)
gladmaker's Avatar
The previous information said the problem was with the '08 Skys. It looks like Punisher is an '07 Sol. What about your '08 Sky?
Venom Brace
Backbone Brace
Woodgrain interior
Old 01-26-2013, 10:40 PM   #8 (permalink)
gladmaker's Avatar
Originally Posted by Elff View Post
Gladmaker
Is yours an '08 Sky?
Venom Brace
Backbone Brace
Woodgrain interior
Old 01-26-2013, 10:51 PM   #9 (permalink)
So mine is an 08 Sol. It had been a showroom queen, and when I went to testdrive it the remotes were inoperable. They replaced the battery at the time and must've done the fix as I've disconnected power multiple times since then and not had a remote problem since.
Old 01-26-2013, 11:14 PM   #10 (permalink)
I had this problem with both my 08 Solstice and 08 Sky since the reflash of the module I have had no issues even when disconnecting the battery.
Old 01-27-2013, 10:03 AM   #11 (permalink)
carnut122's Avatar
I have a plug that goes into the cigarette lighter socket. A 9-volt battery (radio battery) goes onto it. It's supposed to save the presets, etc, when disconnecting the battery. Maybe you can buy one of those?
carnut122 is offline   Reply With Quote
Old 01-27-2013, 10:26 AM   #12 (permalink)
I've got a 2008 and never had an issue with disconnecting the battery. Mine was built late in the model year and the issue was fixed by then.
Sly Bob is offline   Reply With Quote
Old 01-27-2013, 01:08 PM   #13 (permalink)
My Photos: (14)
built 7/07 .
no issue .
lllfly is offline   Reply With Quote
