need help fast on gmpp tune. - Saturn Sky Forums: Saturn Sky Forum
Old 10-09-2012, 08:17 PM   #1 (permalink)
i finally got my car delivered to me this evening,and it is quick as a alley cat with the hair standing on its back.the boost sometimes go up to 15-16 but mostly 14.my shelby was eat up with power,but this thing surprised me,how can i tell if its already had the tune,i have looked for stickers under the hood,but cant find anything.
rspears9 is offline   Reply With Quote
Old 10-09-2012, 08:22 PM   #2 (permalink)
Sky_Pilot's Avatar
If that's all the boost you're seeing, you don't have it. You should see boost up around 18 to 19.
2008 Redline - Carpe Diem Incoronatus, Infantem!
10/30/07: Born
11/17/07: Adopted
07/05/12: GMR Lobotomy
07/06/12: Trifecta Tuned
DDM Xtreme BB
DDM Yellow Coil Cover
Dejon IC Pipes
MRZ Buttress Caps
HID Low/Fog & Pulsating Brake Lamp
Sky_Pilot is offline   Reply With Quote
Old 10-09-2012, 08:27 PM   #3 (permalink)
More like up to 21 to 22!
Baldo is offline   Reply With Quote
Old 10-09-2012, 08:39 PM   #4 (permalink)
rghoskins's Avatar
I've got a DDM tune but see 21-22 max and the power is similar to the GMPP. Get the tune. You'll be schocked at the difference. I saw 15-16 at full throttle prior to the tune.
rghoskins is offline   Reply With Quote
Old 10-09-2012, 08:47 PM   #5 (permalink)
27rings's Avatar
My Photos: (5)
...and it is quick as a alley cat with the hair standing on its back...
Actually that would be standing still.
2009 Ruby Red SE
Mods are getting expensive
www.kronus.us
27rings is offline   Reply With Quote
Old 10-09-2012, 09:11 PM   #6 (permalink)
surprised
this car is quick,even the steering,going to take me a few days to get used to the handeling
Old 10-09-2012, 09:19 PM   #7 (permalink)
rghoskins's Avatar
Your old car was a very high performance car, but it was big and heavy man. This is a whole different kind of car.
Old 10-09-2012, 09:21 PM   #8 (permalink)
lorennerol's Avatar
My Photos: (46)
Send a message via AIM to lorennerol Send a message via MSN to lorennerol
There's a pressure sensor that gets changed out with the tune. The original uses three screws and the replacement two. This is perhaps the most sure of the easy ways to tell if the GM tune in installed.
2008 Red Line
Chili Pepper with special order red/black leather
Five speed
Chrome wheels
Monsoon stereo w/ USB input
Custom lighted Windrestrictor
GMPP ECM upgrade
Norm's custom rear facia
Ordered: 6/23/07
Born: 7/16/07
Del: 8/24/07
lorennerol is offline   Reply With Quote
Old 10-09-2012, 10:16 PM   #9 (permalink)
GS Stage 1's Avatar
GMPP tune:
TMAP and MAP sensors are changed out to 3-bar sensors. The new sensors have a blue sticker on them and are held in place by only 1 screw. (the stock 2.7 bar sensors are held in place by 2 screws)
There should be a sticker inside the gas cover hatch that says "Premium Required". (but not everyone bothers to install the sticker)
Boost command varies greatly with ambient air pressure, air temperature, turbo efficiency and altitude. But generally speaking: A stock car will pull about 14-16 PSI peak boost at sea level, or 17-19 at 5000 feet above sea level. A GMPP tuned car will pull about 20-23 PSI peak boost at sea level, or 23-26 at 5000 feet above sea level.
GMPP tune will enable NLS.
Sent from my DALEK MOBILE DEVICE using Exterminate.Com Free App
GS Stage 1 is offline   Reply With Quote
Old 10-09-2012, 10:34 PM   #10 (permalink)
gladmaker's Avatar
Originally Posted by GS Stage 1 View Post
GMPP tune:
What is NLS?
2008 Bluestone Sky Redline
Venom Brace
Backbone Brace
Woodgrain interior
Diamond pattern console cover
gladmaker is offline   Reply With Quote
Old 10-09-2012, 10:59 PM   #11 (permalink)
DaveOC's Avatar
Originally Posted by gladmaker View Post
What is NLS?
No Lift Shifting
No Lift Shift on GMPP Tune - how to?
Dave -
2006 Solstice NA #000741
DaveOC is offline   Reply With Quote
Old 10-10-2012, 12:06 PM   #12 (permalink)
wspohn's Avatar
The steering is one of the things I don't like about it but your perception of it being quick is accurate compared to what you were used to before. I wish they'd had a delete option for the power steering on these cars.
1958 MGA Twincam (race car)
1962 MGA Deluxe Coupe
1969 MGC roadster,
1957 Jamaican bodied MGA
1965 Jensen CV8,
1971 Jensen Interceptor
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
wspohn is offline   Reply With Quote
Old 10-10-2012, 12:59 PM   #13 (permalink)
|V3nom|'s Avatar
i wouldnt try nls with the gmpp tune, you have to hit it perfectly between 6200-6500 and if you miss the car stumbles. if you want a reliable way to do nls plus have 2-step then get a wotbox.
Old 10-10-2012, 03:12 PM   #14 (permalink)
Bogie's Avatar
The kappa is designed to deliver the boost necessary to achieve the designed torque. At sea level and in cooler weather, the boost will be less than at higher altitudes or in hot weather.
The 15-16 sounds about right for a stock tune at cool sea level, so I doubt you have a tune.
Black
Black/Red Leather
Monsoon 6
RHF Transmission
Born 7/20/07
Snagged 8/31/07
Belle? My car
Alizée? My Avatar
"Amateur Driver, Open Road"
Old 10-10-2012, 03:42 PM   #15 (permalink)
27rings's Avatar
My Photos: (5)
Originally Posted by Bogie View Post
...The 15-16 sounds about right for a stock tune at cool sea level, so I doubt you have a tune.
Man. Wrong year, wrong color, wrong tune. You really should take it back.
2009 Ruby Red SE
www.kronus.us
