Radiator hose rubbing - Page 2 - Saturn Sky Forums: Saturn Sky Forum
Old 01-03-2013, 06:18 AM   #16 (permalink)
My Photos: (14)
With the help of JohnRR we are going to remove my
hood and make the repair needed with pics.
I have PM GM Matt a copy of this post.
lllfly is offline   Reply With Quote
Old 01-03-2013, 09:26 AM   #17 (permalink)
08BlueSky's Avatar
Thanks for notifying the 2.0’ers on this.
No need to “remove the hood” – just raise the hose up out of the way and support it with a flat tool.
Take a hacksaw blade (bare handed), first cut the plastic fin horizontally about an inch and a half, then vertically 1/2 inch and remove any frags with a file or sandpaper.
Replace the hose as needed.
08BlueSky is offline   Reply With Quote
Old 01-03-2013, 11:50 AM   #18 (permalink)
gladmaker's Avatar
I checked my '08 Redline. Hose is not over the shroud. It's in mid air between the shroud and engine, so no problem. They must have found the problem and corrected it.
2008 Bluestone Sky Redline
Venom Brace
Backbone Brace
Woodgrain interior
Diamond pattern console cover
gladmaker is offline   Reply With Quote
Old 01-03-2013, 12:24 PM   #19 (permalink)
Leppyxr2's Avatar
Looks like its time to get out the dremmle and do some cutting just gotta get the ol ladys benz out the garage first got some time befor the weather gets better anyway
Leppyxr2 is online now   Reply With Quote
Old 01-03-2013, 12:47 PM   #20 (permalink)
Leppyxr2's Avatar
Guess i should go ahead and get a hose ordered might b a shortage after these posts lol could you imagine being out at a sky meet on a cruise with a bunch of R/L's and radiator hoses just start blowing left n right
Old 01-03-2013, 02:19 PM   #21 (permalink)
My Photos: (14)
Here are pics.
Fan shroud cutting into rad hose 2.0L - Pontiac Solstice Forum
Do not think for a sec. it is not cut into.
Do not think it is far away. Get your hand.under the hose and feel.
Just orded new hose.
Great pic of the cut 08 BlueSky
Old 01-03-2013, 02:35 PM   #22 (permalink)
TonyRedline's Avatar
You guys are the best...I'll have ta check mine out after work. Thanks!!
08 Redline
3 pedal
Trifecta Tune
TonyRedline is offline   Reply With Quote
Old 01-07-2013, 07:02 AM   #23 (permalink)
pksudo's Avatar
Would putting a hose clamp there prevent the rubbing too?
Mission
Midnight Blue
Opel GT Antenna
pksudo is offline   Reply With Quote
Old 01-07-2013, 08:48 AM   #24 (permalink)
08BlueSky's Avatar
A valid thought – granted may add some weight & cause a greater dip… but can be “added’ without removal of the hose.
And you may want to double up the width to ensure coverage of the trouble spot.
Old 01-07-2013, 09:08 AM   #25 (permalink)
Leppyxr2's Avatar
Doesnt sound like a bad idea probably one of many fixes we will see for this problem i would like to hear every type of fix there is for this problem and will continue to follow this post and lllfly's write up of the problem also
Old 01-08-2013, 04:33 AM   #26 (permalink)
My Photos: (14)
GM C/S is now involved .
I will send them my VIN# today.
And dealer info.
