Old 05-20-2008, 02:21 PM   #1 (permalink)
Spinning tires
Yes yes yes... you don't want to spin the tires, traction is better to make you launch, blah blah. But if you wanted to lay down some rubber how do you do it?
When I was younger I was able to lay LOTS AND LOTS of rubber with an AMC Gremin with a 3 speed manual slant 6 engine (yes really. It would also chirp the tires between gears too). I also had no problems with a 5.0 Mustang, a 440 Dart, and a 442 Oldsmobile but I am having trouble with my Sky. Traction control is the only thing I have off when I try to spin the tires.
If I slide my foot off the clutch at about 2,500 - 3000 it typically lugs.
If I go up above 3000 (don't ask me how high I ain't telling it was an oops) I got clutch slippage. Great smell.
Clutch seems to be fine, puling in third gear with the brake on the car really lugs without the RPM's popping up and it pulls fine.
I once got it to spin the rear wheels a little around 3,000 RPM but it wasn't steady like there was wheel hop or something chirp chirp chirp chirp chirp.
So any advice besides getting a Mallet?
RedlineBlue is offline   Reply With Quote
Old 05-20-2008, 04:42 PM   #2 (permalink)
What type of sky do you have? It's easy to do with a 5 speed NA (drop the clutch @ 3000 rpm) so I suspect you have a RL and the turbo may be the limiting factor.
Jeff Donald is offline   Reply With Quote
Old 05-20-2008, 06:18 PM   #3 (permalink)
Yep it's a turbo but I thought at 3K the turbo should be spooled up no?
Old 05-20-2008, 07:54 PM   #4 (permalink)
SKY Spy's Avatar
My Photos: (47)
I have done a few full boar burnouts in my RedLine without any issues.
One time I tought I burnt the clutch up but it was all my fault, I didn't get of the clutch quick enough and all I got, like you was clutch slip...
Takes a little practice and some lack of fear...
Regards,
BA...
2nd SKY:
2008 RED on Red/Black Lthr
RedLine
Delivered - 7/14/08
Loaded
Auto
3" Magnaflow,
Lil Chromies & CAI
1st SKY: (Traded)
2007 Silver Graphite
RedLine
Loaded (-6CD)
Deposit - 4/11/06
Order # KFDHH7 - 5/27/06
Delivered - 2/21/07
SKY Spy is offline   Reply With Quote
Old 05-20-2008, 07:56 PM   #5 (permalink)
Supporting Member
ceeker's Avatar
My Photos: (16)
You need to put it in competitive mode!
Hit the button twice, or shut everything off to spin the tires.
Magnaflow, Opel Badges, tail lights.
ceeker is offline   Reply With Quote
Old 05-20-2008, 08:08 PM   #6 (permalink)
BlueSkyRL's Avatar
Explained a little more....hitting the button twice puts you in competition mode...holding the button in for a slow count of 10 puts the car totally in your hands(no controls of any kind)
I have on a number of ocassions forgot I had it in no holds bared mode and took off hard from an intersection to the left and ended with a lot of smoke and nearly sitting side ways in the car after the fish tailing. Don't get me wrong, it's fun to do when you expect it but holy sh*t it scares the begesus out of you when your not ready for it!!
Midnight Blue RL - Automatic
Rust proofed & Undercoated
Third brake light decal
Opel Gt antenna
3" Magnaflow exhaust
CTI hard pipes
Dejon Intercooler
Old 05-20-2008, 08:13 PM   #7 (permalink)
Supporting Member
ceeker's Avatar
My Photos: (16)
Here's the best explanation if you don't want to read the whole post!
"Competitive mode does NOT turn off ESC. It becomes more "leniant" before it takes affect.
Basically here's all the systems....
ON - Start car. Everything is on by default. Traction control and ESC.
TRAC OFF - (push button once) Traction control is completely off letting you spin the rear tires as you please, BUT ESC is still fully active. If it senses a slide, it will adjust braking in necessary corners to regain control, or prevent loss of control in the first place.
COMPETITIVE MODE - (push button twice within 3 seconds) Traction control is completely off, BUT ESC is still active, but to a lesser degree. It will allow you to swing the car a bit more aggressively and actually will let you slide a bit before taking over. If it senses a severe slide or loss of control, then it will kick in like normal and apply appropriate braking to regain control.
TRAC OFF & ESC OFF - (hold the button in for 8-10 seconds) You will see the message TRAC OFF and ESC OFF in the cluster. You now have full complete control of the car, in exception of ABS. There is NO way to disable ABS. You could spin the tires and do as many drifts and donuts as you like in this mode....until you run out of tires
After you're done playing around or wish to return to "everything on", you just simply have to hit the button once, and everything will be turned on again, and you'll see the Traction Symbol in the cluster go away.
(FYI - The trac symbol in the cluster doesn't differentiate between modes, anything besides the default ON mode will show the same trac symbol)"
Old 05-20-2008, 08:24 PM   #8 (permalink)
BlueSkyRL's Avatar
OK...an even better explaination
Opel Gt antenna
CTI hard pipes
Dejon Intercooler
Old 05-20-2008, 11:13 PM   #9 (permalink)
Send a message via MSN to Saber49
ive got the tires to spin a few times... its usually in the lower gears and once im already rolling... if im in 2nd ill just jab the gas a bit through a corner and the back end will kick good... need to be above 3000 rpm then give er a jab. be ready to catch it though. especially if your in the rain.
2007 Polar White Saturn Sky Redline
2.0 L I4 Turbo
1986 Torch Red Pontiac Fiero GT
4.9L V8 N/A
Saber49 is online now   Reply With Quote
Old 05-20-2008, 11:40 PM   #10 (permalink)
Kustomkaps's Avatar
Send a message via Skype™ to Kustomkaps
And where is this magic button?
Chili Pepper Red
Vin #1584
Down Payment June 6, 2005
Imaged March 8, 2006
Released to Carrier April 18, 2006
Delivered to Dealer May 5, 2006
In my Drive May 6, 2006
<--- My favorite logo
Kustomkaps is offline   Reply With Quote
Old 05-21-2008, 12:05 AM   #11 (permalink)
Thanks for the replies everyone. I understand the different modes well and how to get them into the correct mode. What I don't understand is why I won't spin the tires with traction off but I will in competiton mode? Why?
I do understand competiton mode is traction off and ESC in "fun mode" but shouldn't traction off alone allow the tires to spin?
Old 05-21-2008, 12:08 AM   #12 (permalink)
Lower right under neath the radio and just above the center console where the shifter is. A button with a car and squiggly lines behind it. I hope I got that right from my feeble memory
Old 05-21-2008, 07:31 AM   #13 (permalink)
It's also easier to blaze the tires by going from idle, rev the throttle and dump the clutch while the engine is accellerating and mat the gas. If you just hold the engine to 3k rpm, the turbo won't spool since the engine isn't under a load.
The Gremlin would have had a 232 or a 258 upright six. Slant six was Chrysler.
Three pedals
Red leather
Monsoon
Chrome rims
Old 05-21-2008, 09:32 AM   #14 (permalink)
Yep, my bad. Good for you remembering the engines! I had a Duster that had the slant 6 and I must of had that in my head. I have no idea how I didn't blow up the engine in the Gremlin. I beat the hell out of it. I would be in a parking lot and get going backwards a good 15 - 20 MPH Put it in first, FLOOR the engine, pop the clutch and let the smoke fly. Left nice candy canes. I did this all of the time. Not too good eating through tires on Burger King salary!
Old 05-21-2008, 11:02 AM   #15 (permalink)
Rob the Elder's Avatar
I can chirp the tires in the first three gears without really trying since I installed the Dejon pipes, magnaflow and finished the break-in. As already stated, if you turn off the mother control you can do just about anything including doing a high side off the road totally out of control on melted rear tires.
Old 05-21-2008, 11:50 AM   #16 (permalink)
bun1t's Avatar
Not hard.
Hold Traction control button for 10 seconds.
Put in 1st gear
Bounce off rev limiter
Sidestep clutch
Press the brake lightly
Watch your money disappear
Not a big fan of useless burnouts but thats how you do them.
2008 Sky Redline: Slow :(
2000 Ford ZX2: 50 trim turbo 303whp
B5 Audi A4 1.8T: Slammed and Slow
Kawasaki ZX6RR
bun1t is offline   Reply With Quote
Old 05-21-2008, 05:14 PM   #17 (permalink)
Bounce off rev limiter Sidestep clutch
I wasn't hitting the rev-limiter (I woudln't do that) but I was fairly high when I tried this. The clutch did more slipping than the tires did.
Old 05-21-2008, 05:19 PM   #18 (permalink)
bun1t's Avatar
Getting high and trying to do burn outs? Nevermind, I'm not going to contribute to the delinquency of idiots.
Kawasaki ZX6RR
Old 05-21-2008, 05:36 PM   #19 (permalink)
Supporting Member
RedHeaded RedLine's Avatar
My Photos: (9)
Were you high or were the revs high? -J
Old 05-21-2008, 05:40 PM   #20 (permalink)
Geesus no *I* wasn't high. I don't get high and even if I did I wouldn't be driving a car. I can see how I was misunderstood.
My point was: Even when not hitting the Rev. Limiter and the RPM's of the ENGINE was high the clutch slipped. Thus hitting the rev. limiter and doing this I would expect the clutch to slip even more. It doesn't smell very nice when the clutch slips.
Old 05-21-2008, 05:41 PM   #21 (permalink)
bun1t's Avatar
I guess thats a good question.
Kawasaki ZX6RR
Old 05-21-2008, 05:43 PM   #22 (permalink)
bun1t's Avatar
I don't know how your clutch would be that bad. Unless you did a burnout that you thought was spinning the tires but was really burning your clutch.
Kawasaki ZX6RR
