Spinning tires
Yes yes yes... you don't want to spin the tires, traction is better to make you launch, blah blah. But if you wanted to lay down some rubber how do you do it?
When I was younger I was able to lay LOTS AND LOTS of rubber with an AMC Gremin with a 3 speed manual slant 6 engine (yes really. It would also chirp the tires between gears too). I also had no problems with a 5.0 Mustang, a 440 Dart, and a 442 Oldsmobile but I am having trouble with my Sky. Traction control is the only thing I have off when I try to spin the tires. If I slide my foot off the clutch at about 2,500 - 3000 it typically lugs. If I go up above 3000 (don't ask me how high I ain't telling it was an oops) I got clutch slippage. Great smell. Clutch seems to be fine, puling in third gear with the brake on the car really lugs without the RPM's popping up and it pulls fine. I once got it to spin the rear wheels a little around 3,000 RPM but it wasn't steady like there was wheel hop or something chirp chirp chirp chirp chirp. So any advice besides getting a Mallet? |
#4 (permalink) |
I have done a few full boar burnouts in my RedLine without any issues.
One time I tought I burnt the clutch up but it was all my fault, I didn't get of the clutch quick enough and all I got, like you was clutch slip... ![]() Takes a little practice and some lack of fear... Regards, BA...
2nd SKY: 2008 RED on Red/Black Lthr RedLine Delivered - 7/14/08 Loaded Auto 3" Magnaflow, Lil Chromies & CAI 1st SKY: (Traded) 2007 Silver Graphite RedLine Loaded (-6CD) Deposit - 4/11/06 Order # KFDHH7 - 5/27/06 Delivered - 2/21/07 |
#5 (permalink) |
You need to put it in competitive mode!
Hit the button twice, or shut everything off to spin the tires.
Silver/RL 2007 - Black Top - Red/Black Leather 5th Break Light, DeJon CAI, IC Pipes Magnaflow, Opel Badges Hahn Intercooler, Westers Tune |
#6 (permalink) | |
![]() I have on a number of ocassions forgot I had it in no holds bared mode and took off hard from an intersection to the left and ended with a lot of smoke and nearly sitting side ways in the car after the fish tailing. Don't get me wrong, it's fun to do when you expect it but holy sh*t it scares the begesus out of you when your not ready for it!!
Midnight Blue RL - Automatic Rust proofed & Undercoated Painted calipers and lettering Painted engine cover, fuse box, rearend Third brake light decal Opel Gt antenna 3" Magnaflow exhaust CTI hard pipes Dejon Intercooler Last edited by BlueSkyRL : 05-20-2008 at 07:13 PM. |
#7 (permalink) |
Here's the best explanation if you don't want to read the whole post!
"Competitive mode does NOT turn off ESC. It becomes more "leniant" before it takes affect. Basically here's all the systems.... ON - Start car. Everything is on by default. Traction control and ESC. TRAC OFF - (push button once) Traction control is completely off letting you spin the rear tires as you please, BUT ESC is still fully active. If it senses a slide, it will adjust braking in necessary corners to regain control, or prevent loss of control in the first place. COMPETITIVE MODE - (push button twice within 3 seconds) Traction control is completely off, BUT ESC is still active, but to a lesser degree. It will allow you to swing the car a bit more aggressively and actually will let you slide a bit before taking over. If it senses a severe slide or loss of control, then it will kick in like normal and apply appropriate braking to regain control. TRAC OFF & ESC OFF - (hold the button in for 8-10 seconds) You will see the message TRAC OFF and ESC OFF in the cluster. You now have full complete control of the car, in exception of ABS. There is NO way to disable ABS. You could spin the tires and do as many drifts and donuts as you like in this mode....until you run out of tires After you're done playing around or wish to return to "everything on", you just simply have to hit the button once, and everything will be turned on again, and you'll see the Traction Symbol in the cluster go away. (FYI - The trac symbol in the cluster doesn't differentiate between modes, anything besides the default ON mode will show the same trac symbol)"
#8 (permalink) | |
Midnight Blue RL - Automatic Rust proofed & Undercoated Painted calipers and lettering Painted engine cover, fuse box, rearend Third brake light decal Opel Gt antenna 3" Magnaflow exhaust CTI hard pipes Dejon Intercooler |
#9 (permalink) |
ive got the tires to spin a few times... its usually in the lower gears and once im already rolling... if im in 2nd ill just jab the gas a bit through a corner and the back end will kick good... need to be above 3000 rpm then give er a jab. be ready to catch it though. especially if your in the rain.
2007 Polar White Saturn Sky Redline 2.0 L I4 Turbo 1986 Torch Red Pontiac Fiero GT 4.9L V8 N/A |
#11 (permalink) |
Thanks for the replies everyone. I understand the different modes well and how to get them into the correct mode. What I don't understand is why I won't spin the tires with traction off but I will in competiton mode? Why?
I do understand competiton mode is traction off and ESC in "fun mode" but shouldn't traction off alone allow the tires to spin? |
#13 (permalink) |
It's also easier to blaze the tires by going from idle, rev the throttle and dump the clutch while the engine is accellerating and mat the gas. If you just hold the engine to 3k rpm, the turbo won't spool since the engine isn't under a load.
The Gremlin would have had a 232 or a 258 upright six. Slant six was Chrysler.
'08 Silver Pearl Red Line delivered 5 Oct '07 Three pedals Red leather Monsoon Chrome rims Spoiler |
#14 (permalink) | |
#15 (permalink) |
I can chirp the tires in the first three gears without really trying since I installed the Dejon pipes, magnaflow and finished the break-in. As already stated, if you turn off the mother control you can do just about anything including doing a high side off the road totally out of control on melted rear tires.
#16 (permalink) |
Not hard.
Hold Traction control button for 10 seconds. Put in 1st gear Bounce off rev limiter Sidestep clutch Press the brake lightly Watch your money disappear Not a big fan of useless burnouts but thats how you do them.
2008 Sky Redline: stock :( 2000 Ford ZX2: 50 trim turbo 303whp B5 Audi A4 1.8T: Slammed and Slow Kawasaki ZX6RR |
#18 (permalink) | |
Nevermind, I'm not going to contribute to the delinquency of idiots.
#20 (permalink) |
Geesus no *I* wasn't high. I don't get high and even if I did I wouldn't be driving a car. I can see how I was misunderstood.
My point was: Even when not hitting the Rev. Limiter and the RPM's of the ENGINE was high the clutch slipped. Thus hitting the rev. limiter and doing this I would expect the clutch to slip even more. It doesn't smell very nice when the clutch slips. |
#22 (permalink) |
I don't know how your clutch would be that bad. Unless you did a burnout that you thought was spinning the tires but was really burning your clutch.
