Its disabled...there is a weld that came loose inside the fob...I need to get that fixed..but the spare doesn't work thats for sure...found that loose weld the hard way too
It WAS my main fob...but once I tried to open the car and it didn't open....top down and armed...well..I had to go all the way home to grab the spare key/fob...
THEN I read that had I reached in and opened the lock manually I would have had a couple minutes to turn the key before the alarms would have beeped.
.the five alarm fire call.
But prior to this I had no idea the spare was loose inside and had set off alarms a couple times because that fob was not 100% working...thats why I say I have been traumatized..
I still double "click" the perfectly working fob I now have JUST to make sure the doors ARE open...
But still have NO idea why it did thoose 3 quick beeps this morning...it sounded like when someone reachs in when armed and the top is down..you know that content warning alarm...only the top was up..and no-one around for sure...
