Old 05-17-2007, 01:44 PM   #1 (permalink)
Send a message via AIM to BigGoat
Wind Noise
Is anyone having a problem with wind noise when the roof and windows are up?
There is a lot of wind noise coming from the passagner side window when the top and windows are up.
BigGoat is offline   Reply With Quote
Old 05-17-2007, 01:47 PM   #2 (permalink)
good luck. I tried having mine fixed 3 times and the dealer apparently gave up and told me it was normal.
lostcause is online now   Reply With Quote
Old 05-17-2007, 01:56 PM   #3 (permalink)
Rick Tinley Park's Avatar
My Photos: (11)
There are things that your dealer can do - adjusting seals, leaning/tilting the windows. It is definitely worth a shot.
Mine has "the whisper" at my left ear... I have not found it annoying enough to mention...
Find out about my radio show
http://www.anj.westpm.net
Founder:
www.chicagolandroadsters.com
Rick Tinley Park
Delivered June 15, 2006
VIN - 3099
Sunburst Yellow
Name - Sunni1
IL License # - YLO SKY 1
Old 05-17-2007, 01:57 PM   #4 (permalink)
TulsaSky's Avatar
please check
When you put the top up make sure the pins are lined up at the bottom of the top frame, the part the slides into the rubber boot at the edge of the door. Kind of hard to explain but if the top is not seated at the bottom then the window will not seal and you will get a wind noise. While Teri aka Skybaby was here in town she put the top up and WAIT the passenger side I need to make sure its seated or pins are in place, Maverick and I both went WOW ours are the same way! Before you latch the top in look at that rubber boot and move the top with you hand and adjust it so once its latched the plastic tab is in place seated. May help to look at the drivers side then walk around to the passenger and make sure its in the exact same place if its off you should see a difference.
TulsaSky
07 Midnight Blue Red Line Sky
TulsaSky is online now   Reply With Quote
Old 05-17-2007, 02:06 PM   #5 (permalink)
CountryGirl's Avatar
TulsaSky
Any chance you could post some pictures?
Bluestone/Black REDLINE
Perma-grin since Jan 2007
CountryGirl is offline   Reply With Quote
Old 05-17-2007, 02:18 PM   #6 (permalink)
Here's one of mine.
This isn't what's causing my wind noise, but I'm pretty sure it's the issue tulsasky mentioned.
Old 05-17-2007, 02:41 PM   #7 (permalink)
marzinair100's Avatar
I am having this same problem, Passenger side never seems to lock in properly. It has gotton on my nerves quite a bit since the dealer states there is no fix for this. I do not feel it should be our responsibility to ensure a top locks in properly, esp for a car that is not even a year old. Will continue to ask when the ar goes in to see if they have discovered a solution.
Sky RedLine
marzinair100 is offline   Reply With Quote
Old 05-17-2007, 02:52 PM   #8 (permalink)
I wish I knew the service bulletin for it. There is one.
Old 05-17-2007, 03:30 PM   #9 (permalink)
wind noise on passenger side.
I've got that "Wind" noise as well on the passenger side. Just got back from dealer from fixing the leaking LSD...was told that they could not find a problem and that the wind noise was "Normal".
J_G_Place is offline   Reply With Quote
Old 05-17-2007, 03:35 PM   #10 (permalink)
Graysky's Avatar
This is a reply to all. I had this problem until Monday on the driver's side. Inside the top if you push it half way down you'll see the problem is that one of the struts has become disconnected. You cannot re-connect it...I tried. My dealer replaced both sides just to make sure the top was even. The problem was that even though the strut is metal and pushes forward the bottom part of the top into the boot, where there is a small well for it to hook in to, the swivel is made of plastic and the threads have become stripped from the pressure load that is put on the struts everytime you lift or raise the top. I believe the swivel that screws to the end of the struts were replaced with metal ones that won't tear apart during operations. The wind was very high coming through the bottom of the window, you could stick your finger through the edge of the glass into the car. It's now fixed. In fact several top issues were resolved with this one fix. One of which was the rattle sound in the top behind my head is now gone. I hope this helps everyone.
deposit 6/03/06
Silver Graphite RL
premium red/black interior
MP3 1 disc player
spoiler
18" chrome wheels
absolutely manual
snagged on 2/28
Awesome ride!
Graysky is offline   Reply With Quote
Old 05-17-2007, 05:17 PM   #11 (permalink)
zbeerman21's Avatar
Why are you worried about what it sounds like with the top up?
Shouldn't you be more concerned about what it is like with the top down?
Silver Graphine Redline with Red Interior
Magnaflow 3"
Fujita CAI
Custom Red Calipers and Rotors
Dual Polk Audio Component Sound System
zbeerman21 is offline   Reply With Quote
Old 05-18-2007, 12:25 AM   #12 (permalink)
TulsaSky's Avatar
Lostcause, you got it that is a picture for all my words. If that is not lined up and you roll the window up you will damage the window seal, then its a trip to the dealer to replace it.
TulsaSky
Old 05-18-2007, 09:33 AM   #13 (permalink)
snaponbob's Avatar
I have the same problem on both sides of my top. After breakfast I am going to inspect my top per Garysky's suggestion.
owner installed lock buttons,
painted calipers,
Koni S/A's, Kurt hitch,
Old 05-20-2007, 01:35 PM   #14 (permalink)
BlueSkyRL's Avatar
Gary,
Can you post a picture or two of what you are talking about. My passenger side does not sit right and this may help.
Thanks
Mike
Old 05-20-2007, 03:21 PM   #15 (permalink)
Graysky's Avatar
No picture because it's been fixed. The dealer called it the struts at the bottom of the top where it slides forward into the boot when you snap it to the trunk lid. It's an easy fix for them. Take it to you dealership.
deposit 6/03/06
Silver Graphite RL
MP3 1 disc player
spoiler
18" chrome wheels
absolutely manual
snagged on 2/28
Awesome ride!
