Windshield Scratch Removal Anyone? - Saturn Sky Forums: Saturn Sky Forum
Old 12-27-2012, 01:54 PM   #1 (permalink)
TonyRedline's Avatar
Anyone had any luck with taking scratches out of your Windshield? I had a power line blow down on my Sky the other day. Can’t believe it didn’t scratch the crap outa my car but it did my Windshield. As you can see it got me pretty good. I looked around on the net some and saw where someone posted about CarPro CeriGlass. Has anyone used this or anything else with any luck? I might have to look into getting a new one, but wanted to check in with the pros first Thanks!
08 Redline
3 pedal
Trifecta Tune
TonyRedline is offline   Reply With Quote
Old 12-27-2012, 02:10 PM   #2 (permalink)
MCW Sky's Avatar
Google it...
how about something suggested here: How to Remove Light Scratches from Your Windshield - Popular Mechanics
'09 RL Ruby Red Manual
HID low beam & fogs
3" Magnaflow
MCW Sky is online now   Reply With Quote
Old 12-27-2012, 02:37 PM   #3 (permalink)
My Photos: (13)
A small scrach...u have a chance. You have no choice here. Go to E Bay. You can still purchase OEM...but the problem is...they will not ship just one...I believe the outfit is in Saint Charles, Missouri
Old 12-27-2012, 02:52 PM   #4 (permalink)
A small scrach...u have a chance. You have no choice here. Go to E Bay. You can still purchase OEM...but the problem is...they will not ship just one...I believe the outfit is in Saint5 Charles, Missouri
Yep, OEM, Missouri...Local pickup only...199.99
08 Redline
3 pedal
Trifecta Tune
Old 12-27-2012, 03:32 PM   #5 (permalink)
My Photos: (13)
Give them a call...see what they say. Good Luck. You really do not want to purchase another windshield from a glass installer...there was a thread regarding how inferior other glass manufacturers are...although our glass windshields are made in Mexico.
Old 12-27-2012, 03:44 PM   #6 (permalink)
I'll try a couple of things first to see if I can get them out. If it doesn’t work then I’ll probably give them a call. Said they had 10 or more of these items so I don’t have to be in too big a hurry, and with this being my daily driver I probably wouldn’t put it in till spring anyways. Be a decent little road trip at 5 hours one way. Thanks for the help!
08 Redline
3 pedal
Trifecta Tune
Old 12-28-2012, 11:24 AM   #7 (permalink)
GS Stage 1's Avatar
Claybar works well for minimizing window pitting. It is a long shot, and would take a lot of elbow grease; for what you have there. But it might be worth giving it a try. If you can knock down the sharp edges on the scratches, then they may not be as obvious.
Sent from my DALEK MOBILE DEVICE using Exterminate.Com Free App
GS Stage 1 is offline   Reply With Quote
Old 12-28-2012, 01:06 PM   #8 (permalink)
MidniteBlues's Avatar
Thumbs up
Most windshield damage is covered with your car insurance, check with them first before you shell out any doe.. In Florida for example, I can have my windshield replaced for "free" that's right NO deductible.. for example..
"No man is good enough to govern another man without that others consent." ~ Abraham Lincoln
"The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so." ~ Ronald Reagan
Old 12-28-2012, 01:31 PM   #9 (permalink)
JRinKY's Avatar
MidniteBlues : Most windshield damage is covered with your car insurance, check with them first before you shell out any doe.. In Florida for example, I can have my windshield replaced for "free" that's right NO deductible.. for example..
Kentucky is the same, assuming you have full coverage on the car.
The concern then comes back to the quality of the replacement glass. Some is good, some is not.
VIN 00252
2.4 NA Manual
Midnight Blue
Old 12-28-2012, 02:21 PM   #10 (permalink)
I have full coverage...Definitely worth checking into. The quality of glass is huge, because I know most all of the aftermarket is junk.
Thank You all for your thoughts and help!!
08 Redline
3 pedal
Trifecta Tune
Old 12-28-2012, 02:28 PM   #11 (permalink)
Thumbs up
That is true, I'm sure you can request and have OEM replacement only..
if available of course, otherwise it's approved equivalent..
Old 12-28-2012, 03:38 PM   #12 (permalink)
gladmaker's Avatar
In my over 50 years of driving, I've never had to replace a windshield so I don't know anything about the quality. How can you tell if the quality of replacement glass isn't the same as OEM?
2008 Bluestone Sky Redline
Venom Brace
Backbone Brace
Woodgrain interior
Diamond pattern console cover
gladmaker is offline   Reply With Quote
Old 12-28-2012, 05:20 PM   #13 (permalink)
JRinKY's Avatar
gladmaker : In my over 50 years of driving, I've never had to replace a windshield so I don't know anything about the quality. How can you tell if the quality of replacement glass isn't the same as OEM?
Mainly look at it.
Contrary to popular opinion, aftermarket glass isn't softer than OEM glass, and it isn't fundamentally diferent in any other way, either. All glass, aftermarket or OEM, has to pass the same safety inspections, so the materials and construction are pretty much the same.
The big difference, or potential difference, is appearance. OEMs have very strict appearance and distortion specifications, and they are pretty obsessive about following them. The only real inspector for a piece of aftermarket glass that is being installed in your car is you.
Cosmetic defects are usually pretty insignificant, unless you are completely anal about details. There may be a missing dot in the fade-out pattern, or some of the black may be more grey.
Distortion is the big thing to look out for. Tell the installer that you are going to check for distortion, and will reject a screen if it has too much. Make sure he agrees before you make any commitments. When the glass in installed in the car you should be able to look through it without seeing any significant distortion of what you are looking at. Move your head around as you look through the glass at something with straight lines. You will see some variation in the more curved pillar areas, but a lot of waviness in the middle is bad. Look through a "good" windshield to see what it looks like, then compare.
Other potential issues are scratches, bubbles, or "inside material" which is pieces of debris in the plastic or between the plastic and the glass. Also look for any milkiness around the edges, which is a sign of de-lamination. The is also a phenomenon called "ice flower" that is caused by air bubbles in the plastic growing into weird tree-shaped voids.
You should inspect the glass before it goes into the car. Have them set it up on something so that you can look through it at something approximating the installation angle, and from approximately where you would be sitting to drive the car. Also, check it carefully for the other defects.
You wouldn't accept a badly repaired fender, so don't accept a badly made piece of glass.
VIN 00252
2.4 NA Manual
Midnight Blue
Old 01-05-2013, 01:40 PM   #14 (permalink)
bun1t's Avatar
I used 3M Rubbing Compound to get some scratches out of a windshield before.
bun1t is offline   Reply With Quote
Old 01-05-2013, 10:39 PM   #15 (permalink)
knottAsky's Avatar
I agree with you Ask and tell them you want ( OEM Glass ) It might take a day or so more but they can get it . Give them the Order and let them call you when it comes in to have it put in.
Also Known As 1 LIL NDN find Me and the Chief on the Kappa Performance forum
knottAsky is offline   Reply With Quote
