#31 (permalink) |
From my understanding, VTEC was supposed to be Honda's answer to a turbo, so it's not that bad. Watch some in-car videos on youtube of VTEC kicking in, it definitely looks turbo-like.
2008 Saturn Sky Redline | BSR Stage 1 Tune, RPi Stage 2 IC, GMPP Air Intake, GM Turbo Cat-Back Exhaust, Eibach Pro-Kit Springs, Konig Again 5 Wheels, 245/45 Goodyear Eagle F1 GS-D3 Tires |
#32 (permalink) | |
2007 Silver Pearl RL Alloys, single CD Monsoon Black Leather Manual Trans K&N Replacement Filter No E10 |
#33 (permalink) |
vtec...all of the lag, none of the boost
Mods: Dejon Spring Magnaflow 3" catback Wastegate Mod: 21psi Removed gm emblems behind front tires Xentec 8K HIDs Low Beams and Fogs Parking Light Leds License Plate Leds Little Chromies 3rd brake light vinyl: REDLINE |
#34 (permalink) |
It's not consistent power throughout the band like a supercharger, and it does kick in in the mid-upper RPMs like a turbo, the kick-in is noticeable but far from a turbo. Maybe if our turbo was limited to 5psi it would feel the same. VTEC is a cheap alternative to a turbo though, and it serves its purpose, we here driving American cars shudder at the comparison though
#35 (permalink) | |
I guess you need to see what a real turbo feels like.
2008 Sky Redline: Slow :( 2000 Ford ZX2: 50 trim turbo 303whp B5 Audi A4 1.8T: Slammed and Slow Kawasaki ZX6RR |
#36 (permalink) |
It was never an answer to turbocharging. Who ever made that story up should be shot. Forced induction increases the volumetric efficiency of the engine and vtec does not even function the same. Its a timing issue.
Eloy "Brutus" #001 RPi 2.4GTS Race Precision, Inc. 7029 Marcelle Street Paramount, CA 90723 562-630-5966 www.raceprecision.com |
#37 (permalink) | |
"Additionally, Japan has a tax on engine displacement, requiring Japanese auto manufacturers to make higher-performing engines with lower displacement. In cars such as the Toyota Supra and Nissan 300ZX, this was accomplished with a turbocharger. In the case of the Mazda RX-7 and RX-8, a rotary engine was used. VTEC serves as yet another method to derive very high specific output from lower displacement motors." Source
#38 (permalink) |
basically every somewhat high end 4 and 6 cyls all have vtec in essence, only its not called that, its called variable valve timing. honda was just the first to come out with it to help out with the higher rpms but even our cars have it. like eloy said, its NOTHING like a turbo at all.
#40 (permalink) |
VTEC is the switching of cams when the engine reaches a certain rpm. One cam is used for normal everyday driving, while a second more aggressive cam is used for performance driving. Ford and Toyota had the first patents for VTEC in 1977, but Honda was the first company to use it in mass production.
VTEC - Wikipedia, the free encyclopedia
2007 Solstice GXP "Natsumi" Japanese female name that translates to Summer Beauty. |
#41 (permalink) | |
Buzz Bee Sunburst YELLOW RL Clear Bra on Hood & Rocker panels 5 speed manual Chrome Wheels 6 disc Monsoon Black / ebony Leather interior Spoiler |
#42 (permalink) |
Any 1997-present car just gets plugged into a computer (unless your in cali). So long as there's no codes (mine are turned off completely) you can't fail.
2007 Sky Redline Dejon 5027BB & Piping - RPI I/C - Magnaflow+Cutout 365 RWHP 351 RWTQ http://tinyurl.com/26j7kd |
#43 (permalink) |
Not even close enough to call it "similar". One has to do with forced induction and increasing volumetric efficiency and the other has to do with ignition/cam timing.
#45 (permalink) |
Is there really any effective difference between VTEC and the VVT designed into the Ecotec? Maybe slight differences in design, but they functionally sound the same. Both are based on varying the CAM geometry to change the valve timing. And both are actuated via computer controlled solenoids.
#47 (permalink) | |
#48 (permalink) | |
#49 (permalink) | |
VTEC has two different lobes on the cams, one for high lift/high rpm power and another for low rpm economy. i-VTEC is VTEC with the addition of cam phasors. This can advance or retard the position of the cam and alter valve timing. GM VVT (Variable Valve Timing) is only using cam phasors. |
#50 (permalink) |
ehh close enuf :P.
#51 (permalink) | |
I am looking to upgrade my turbo. What would I need to put the GT3076R into my Redline. Thanks, -Matt ![]()
07 SKY Redline Silver Red/Black Leather, JPM Dash Red leather, WDE Carbon Fiber Dash Kit, BSR Tune, Fujita Intake, Dejon IC pipes, Hahn IC, 3" Magnaflow Quad Exhaust, DDM BBK (RED), BlackCatCustom Gauges. http://www.compdoc777.com/Carstuff/sky1.jpg |
