anybody using Torque Pro app? - Saturn Sky Forums: Saturn Sky Forum
Register Home Forum  /  Current Posts Gallery Garage Search Today's Posts Mark Forums Read
Like Tree2Likes
LinkBack Thread Tools
Old 01-17-2017, 07:18 PM   #1 (permalink)
stungjoe's Avatar
Quoted: 157 Post(s)
Just got a new gadget. I picked up a bluetooth OBD2 device and am learning a bit about the Torque Pro app. The first thing I looked at was my boost levels. Ever since I got the Trifecta I was concerned that I may be boosting more than the DIC would show. I always see a constant 23 PSI on the display. I hooked up the gadget and the app is showing 22.8 max boost. I was wondering if anybody using this app knows how accurate this reading is. I'm pretty sure the OEM MAP sensors can read up to about 24.5 or so PSI. I'm hoping the readings are an accurate interpretation of the voltages the MAP sensors are sending. I know the DIC doesn't show tenths so I'm assuming it rounds things off.
Joe
FLASHED
2008 Red Line Carbon Flash SE Naked!
stungjoe is offline   Reply With Quote Quick reply to this message
Old 01-17-2017, 07:25 PM   #2 (permalink)
Quoted: 741 Post(s)
Well, keep in mind the OBD2 device won't be any more accurate than the dash reading since they both are getting their data from the exact same place.
I know sensors get a little "fuzzy" at the extreme ends of their range so I don't know how accurate the stock sensor is when it's almost maxed out.
OH, and I do run the torque app if I'm not wanting to break out the HP Tuners.
Robotech is offline   Reply With Quote Quick reply to this message
Old 01-17-2017, 07:36 PM   #3 (permalink)
stungjoe's Avatar
Quoted: 157 Post(s)
I found a post by Tomato Soup about the science behind the voltages but it was beyond my comprehension... suffice it to say the higher the voltage the less accurate the reading as you stated.
Joe
FLASHED
Old 01-18-2017, 12:48 AM   #4 (permalink)
Quoted: 741 Post(s)
This is why the GMPP Tune went with 3 bar MAP sensors...
Old 01-18-2017, 08:32 AM   #5 (permalink)
KappaTarbo's Avatar
Quoted: 20 Post(s)
I use it every once in a while. It's a pretty neat little tool.
Here is a link to some themes another member made to match the dash of the Sky.
Torque App Themes
stungjoe likes this.
08 Carbon Flash Redline 5 speed
Fujita intake and charge tubes / Gutted cat / 3 bar MAPS / Tuned with HP Tuners / Stoptech Street Performance pads / DDM SS brake lines / ATE Type 200 fluid
KappaTarbo is offline   Reply With Quote Quick reply to this message
Old 01-18-2017, 08:36 AM   #6 (permalink)
Quoted: 195 Post(s)
The sensors are only run within their accuracy ranges with the stock tunes. However, aftermarket tunes can increase boost into the 'rolled off' areas of the sensors.
Bottom line, boosts level reported by the sensors in stock tunes would be pretty accurate.
TomatoSoup is offline   Reply With Quote Quick reply to this message
Old 01-18-2017, 11:37 AM   #7 (permalink)
Quoted: 741 Post(s)
Kind of what I thought. Sounds about right.
Old 01-18-2017, 11:46 AM   #8 (permalink)
stungjoe's Avatar
Quoted: 157 Post(s)
I guess then I'm pretty glad to see something lower than 23PSI.
Now if i can find the knock sensor on this app.
Joe
FLASHED
Old 01-18-2017, 11:52 AM   #9 (permalink)
Quoted: 741 Post(s)
The value is called Knock Retard. It's there.
Old 01-18-2017, 01:22 PM   #10 (permalink)
stungjoe's Avatar
Quoted: 157 Post(s)
Can't find it. Goes from something kilometers to liters something
Old 01-18-2017, 01:41 PM   #11 (permalink)
Quoted: 741 Post(s)
Huh. Should be there. I have...
Kilometers Per Litre(Long Term Average)
Knock Retard
Knock Retard(Alternative)
Knock sensor active counter
Last Shift Time
Litres Per 100 Kilometer(instant)
(And I have no idea why it is litres and not liters)
Old 01-18-2017, 05:59 PM   #12 (permalink)
stungjoe's Avatar
Quoted: 157 Post(s)
Knock Retard
Last Shift Time
Mine jumps from:
to
EDIT: I did find a free widget called knock detector. But it has it's own screen so i can't see any other gauges while testing for knock.
Joe
FLASHED
Old 01-18-2017, 06:27 PM   #13 (permalink)
Quoted: 741 Post(s)
And you have the Pro version of Torque, right? Are you Android or Apple?
Old 01-18-2017, 06:31 PM   #14 (permalink)
stungjoe's Avatar
Quoted: 157 Post(s)
Pro version, paid $4.95 for it. Android (Galaxy S6) using a BAFX 34t5 Bluetooth dongle
Joe
FLASHED
Old 01-18-2017, 06:36 PM   #15 (permalink)
Quoted: 741 Post(s)
Huh...Same here...well, 5S Galaxy but that shouldn't make a difference. Sometimes there are little differences between the Android and Apple products but wouldn't matter in this case. COULD be your dongle if it uses another piece of software on your phone for connectivity. The one I have is straight Bluetooth and requires no other software. Here is mine:
ELM327 OBDII Bluetooth Auto Car Diagnostic Wireless Transceiver Dongle - Blue | eBay
But that's really the only thing I can think of. I'm a 2007 and you're a 2008 but again, that shouldn't make a difference.
Insurance
Please select your insurance company (Optional)
Human Verification
» Recent Discussions
foggy lenses?
05-22-2017 09:33 PM
Last post by expostdelirium
Today 12:02 AM
12 Replies, 251 Views
F/S 2007 $1500 Miami FL
05-26-2017 03:43 PM
by ChopTop
Yesterday 11:35 PM
5 Replies, 126 Views
What did you do to your...
11-10-2009 10:23 AM
by NormSky
Last post by Elff
Yesterday 11:05 PM
3 Replies, 227,195 Views
Leaking when in car wash
05-20-2017 11:02 AM
Last post by marlboromike
Yesterday 10:23 PM
17 Replies, 388 Views
Empty Halls?
05-18-2017 11:46 AM
by DaveOC
Last post by Rockchops
Yesterday 10:20 PM
20 Replies, 345 Views
UPDATED 2/9/2017 GM...
02-03-2016 07:12 PM
Yesterday 09:40 PM
518 Replies, 20,751 Views
want to trade
02-28-2017 10:22 PM
Last post by Rick W
Yesterday 06:06 PM
4 Replies, 460 Views
FS/2007 Saturn Sky Red...
Yesterday 05:51 PM
Last post by JaySky
Yesterday 05:59 PM
2 Replies, 57 Views
F\S Sky and Solstice...
05-15-2017 09:19 PM
Yesterday 04:13 PM
21 Replies, 741 Views
WTB: Cold Air Intake...
05-26-2017 11:28 AM
Last post by Anthony Camuso
Yesterday 02:59 PM
10 Replies, 153 Views
