engine shake. what does it mean? - Saturn Sky Forums: Saturn Sky Forum
Register Home Forum  /  Current Posts Gallery Garage Search Today's Posts Mark Forums Read
Like Tree1Likes
  • 1 Post By scott80
LinkBack Thread Tools
Old 12-21-2016, 12:42 AM   #1 (permalink)
scott80's Avatar
Guys, whenever I turn on my AC. It causes the engine to shake like if though the engine isn't bolted down and the belt make a weird noise. What does that mean? Should I bring it in for service? Any insight would be great!!! Thanks
tallcraig likes this.
scott80 is offline   Reply With Quote Quick reply to this message
Old 12-21-2016, 01:50 AM   #2 (permalink)
Quoted: 569 Post(s)
Does your air blow cold? It could be a number of things but it sounds like either the compressor is failing or the compressor's clutch is failing. It sounds like the motor is shaking and your getting a strange sound because the compressor or clutch (most likely compressor) is jammed and fighting the belt trying to turn it.
Robotech is offline   Reply With Quote Quick reply to this message
Old 12-21-2016, 12:46 PM   #3 (permalink)
scott80's Avatar
Thanks Robotech, the AC works fine. It gets pretty cold! The engine just shake when I turn it on.
Old 12-21-2016, 02:07 PM   #4 (permalink)
Quoted: 569 Post(s)
Then it just may be the engine reacting to the load the AC system is putting on it. Hard to tell if the conditions you describe are excessive. The AC system puts a load on the engine and it will react to that load. From your initial post it sounded like the engine was shaking really bad but if the AC is blowing cold it may just be the normal shaking. Without seeing what's going on it's hard to say. It could be one of the engine mounts is blown or loose. Uncommon for sure but at this point I'm just throwing out ideas.
Old 12-21-2016, 09:51 PM   #5 (permalink)
cityboy's Avatar
My Photos: (5)
Quoted: 15 Post(s)
Send a message via AIM to cityboy
Does the engine jump when you shift from park to drive or reverse ?
You can have some record the actions of the engine when you do the shifting
Some times you can tell if the engine mounts are bad by doing this
And like others have said if it's not that sounds like the AC compressor/clutch
09 silver RL
rims
spoiler
pedals
black leather
6-disk
gm-CIA
painted calibers
opel antenna
blue low/fog lights
gm turbo upgrade
WR
Cateless down pipe
Engine caps.
Pro beam
Back bone
Venom brace
Custom badging
DDM IC pipes
cityboy is offline   Reply With Quote Quick reply to this message
Old 12-23-2016, 03:16 AM   #6 (permalink)
scott80's Avatar
Thanks guys. Yeah, I think something is loose . haven't had time to take it to the shop. Just hope it doesn't die on me. How do I check the mount? Is it a bolt or something?
Old 12-23-2016, 11:50 AM   #7 (permalink)
ArikDahn's Avatar
Quoted: 9 Post(s)
Mine shakes like crazy when I turn the AC on. These engines are extremely weak from a torque perspective. For the car to maintain the load at idle torque with all the normal bells and whistles pulling power, the engine works pretty hard. The drivetrain on these cars is pretty loose in that components bang around a lot. It doesn't appear to affect reliability, but it can be unsettling if you are used to a more refined driving experience.
The engine mounts are fluid filled rubber "feet" that large bolts hold to the frame of the car and the engine. If one of them is bad, the fluid can escape and "deflate" the mount so that the engine is essentially sitting on the frame. All of the above can seriously amplify the drivetrain noises. I have not heard a failed engine mount so I speak theoretically, but I can imagine how awful it would be considering how loud these cars are to ride in when functioning properly.
Have you had any unexplained small oil puddles near the car lately that you cleaned up and then saw no more of and thought nothing of it?
Borg Warner EFR6758, EBC, & Forgev2 BPV
Custom boost tubes & intake
Twinscroll turbo manifold & custom catted downpipe
HPTuners
Performance Autowerks FMIC
RPi exhaust
AEM AFR & boost in ddm pillar
Spec ST2+ clutch & half mass flywheel
ArikDahn is offline   Reply With Quote Quick reply to this message
Old 12-23-2016, 12:57 PM   #8 (permalink)
Quoted: 569 Post(s)
ArikDahn, it is uncommon to have an engine mount fail but they will fail over time...and our cars are starting to get up there in age.
I thought I heard of a couple people having the passenger side mount fail...but I could be mistaken.
Old 12-23-2016, 01:37 PM   #9 (permalink)
ArikDahn's Avatar
Quoted: 9 Post(s)
Yeah me either but ya never know. One thing about cars is that no matter how rare an issue is, it could still happen.
HPTuners
RPi exhaust
Old 12-25-2016, 12:12 PM   #10 (permalink)
scott80's Avatar
No oil spill that I can recall. I'm the 4th owner. It's very reiable and I love it. I just want to maintain and keep it as long as possible. I was afraid that the shaking Will damage the engine.
Old 12-25-2016, 04:10 PM   #11 (permalink)
Quoted: 569 Post(s)
No, they are on hydraulic engine mounts and a little shaking isn't going to hurt it.
Insurance
Please select your insurance company (Optional)
Human Verification
» Recent Discussions
Best Top Dressing?
01-13-2017 09:15 PM
by BlueRL
Last post by marlboromike
Today 09:36 PM
22 Replies, 462 Views
Super Sky @ Barber...
Yesterday 10:39 PM
Last post by Z06-Redline
Today 09:25 PM
3 Replies, 108 Views
Resale value
02-22-2017 07:45 PM
Last post by mbeardsley
Today 08:14 PM
9 Replies, 243 Views
Interested in left side...
02-22-2017 11:54 AM
Last post by Elff
Today 07:56 PM
16 Replies, 259 Views
Spec Stage 3+ clutch...
Yesterday 01:16 AM
Last post by Elff
Today 07:54 PM
5 Replies, 107 Views
Wtb dead pedal
Yesterday 08:52 AM
Last post by jgassor
Today 05:05 PM
7 Replies, 153 Views
Battery
02-20-2017 02:13 AM
Last post by The Carrier
Today 08:18 AM
10 Replies, 268 Views
New head unit
02-17-2017 03:08 AM
Last post by Elff
Yesterday 09:56 PM
10 Replies, 263 Views
Diagnosing my sky base
02-20-2017 06:43 PM
Last post by Robotech
Yesterday 02:16 PM
10 Replies, 249 Views
Intercooler installation...
02-22-2017 05:32 PM
Yesterday 02:06 PM
12 Replies, 196 Views
