NHTSA cannot identify a problem with '08 brakes
I know a snipit of this is in another thread, I thought I would post the entire wording from the NHTSA and to make it easier for others to find in the future via searching.
CONTROLLED BY SWITCHES THAT SENSED BOOSTER VACUUM, TURNING THE IN MODEL YEAR (MY) 2007, PONTIAC SOLSTICE AND SATURN SKY VEHICLES EQUIPPED WITH THE 2.0L TURBOCHARGED ENGINE USED AN AUXILIARY VACUUM PUMP TO SUPPLEMENT THE ENGINE AS A SOURCE OF VACUUM TO THE BRAKE BOOSTER DURING LOW VACUUM CONDITIONS, SUCH AS IMMEDIATELY AFTER A COLD START. THE VACUUM PUMP OPERATION WAS PUMP ON WHEN BOOSTER VACUUM DROPPED BELOW A SPECIFIED LEVEL. IN THE MY 2008 SOLSTICE AND SKY VEHICLES (THE SUBJECT VEHICLES), GENERAL MOTORS (GM) ELIMINATED THE AUXILIARY VACUUM PUMP AND REPLACED IT WITH THE OPTIMIZED HYDRAULIC BRAKING (OHB) SYSTEM. THE DESIGN INTENT OF OHB IS TO SUPPLEMENT ENGINE VACUUM, IN CONDITIONS WHERE LOW VACUUM IS GENERATED BY THE ENGINE, WITH HYDRAULIC PRESSURE GENERATED BY THE STABILITY CONTROL SYSTEM PUMP CONTROLLED BY THE ELECTRONIC BRAKE CONTROL MODULE (EBCM). FOR UP TO ABOUT A MINUTE AFTER A COLD START, WHEN THE SYSTEM IS IN OHB ASSIST MODE, THE DRIVER MUST PRESS HARDER ON THE BRAKE PEDAL TO ACHIEVE DESIRED DECELERATION. ALSO, WHEN THE OHB MODE IS ACTIVATED, THE DRIVER CAN HEAR AND FEEL, THROUGH BRAKE PEDAL VIBRATION, THE STABILITY CONTROL SYSTEM PUMP OPERATION. STARTING IN LATE APRIL 2008, GM CHANGED FROM THE OHB SYSTEM BACK TO THE VACUUM PUMP SYSTEM DESIGN. ODI IS AWARE OF 264 NON-DUPLICATIVE COMPLAINTS TO ODI AND GM ALLEGING INADEQUATE BRAKE POWER ASSIST IN THE SUBJECT VEHICLES WHEN APPLYING THE BRAKES JUST AFTER A COLD START, INCLUDING ONE INCIDENT INVOLVING A CRASH INTO A TREE DURING A DRIVEWAY MANEUVER. TO ADDRESS THESE CONCERNS BY CONSUMERS, GM HAS ISSUED THREE TECHNICAL SERVICE BULLETINS. ON JUNE 4, 2007, GM RELEASED AN INFORMATIONAL BULLETIN (NO PART REPLACEMENT OR SOFTWARE UPDATES), BULLETIN# 07-05-22-002, TO DEALERS EXPLAINING THE FUNCTIONALITY OF THE OHB SYSTEM. ON NOVEMBER 29, 2007, GM RELEASED A SERVICE BULLETIN, BULLETIN# 07-05-22-007, WITH INSTRUCTIONS TO RECALIBRATE THE EBCM WITH REVISED SOFTWARE TO MAKE OHB OPERATION FEEL MORE LIKE A NORMAL VACUUM ASSIST SYSTEM. TO IMPROVE COLD START BRAKING PERFORMANCE COMPARABLE TO MY 2007 VEHICLES, GM RELEASED A THIRD SERVICE BULLETIN IN TWO PARTS, BULLETINS 07-05-25-007A (APRIL 29, 2008) AND 07-05-25-007B (MAY 16, 2008), FOR AUTOMATIC AND MANUAL TRANSMISSION VEHICLES RESPECTIVELY. THESE BULLETINS RELEASED NEW ENGINE CONTROL SOFTWARE TO CHANGE THE IDLE STRATEGY AFTER A COLD START SO THAT MORE VACUUM IS AVAILABLE FOR BRAKE POWER ASSIST. BEGINNING THE WEEK OF JUNE 23, 2008, GM WILL BEGIN SENDING LETTERS TO CONSUMERS TO MAKE THEM AWARE OF THE AVAILABILITY OF MOST RECENT CALIBRATION. A SAFETY-RELATED DEFECT HAS NOT BEEN IDENTIFIED AT THIS TIME AND FURTHER USE OF AGENCY RESOURCES DOES NOT APPEAR TO BE WARRANTED. ACCORDINGLY, THIS INVESTIGATION IS CLOSED. THE CLOSING OF THIS INVESTIGATION DOES NOT CONSTITUTE A FINDING BY NHTSA THAT A SAFETY-RELATED DEFECT DOES NOT EXIST. THE AGENCY WILL TAKE FURTHER ACTION IF WARRANTED BY THE CIRCUMSTANCES. Last edited by RedlineBlue : 07-03-2008 at 11:32 AM. Reason: Changed title per Bogie's suggestion |
#2 (permalink) | |
Junior Member
Another fine example of your taxpayer dollars at work.
drgallo '08 Sky RedLine Silver Red and Black Leather Std: XM Radio, Monsoon Audio, Onstar, 18" Chrome, Automatic, Spoiler. Mods: Opel GT Antenna, 8K HID Headlights, Garmin 780 NAV with Bluetooth. |
#3 (permalink) | |
I will be popping to hood for sure to make certain those parts are installed, AND will start the car and move it instantly and hit the brakes, if it stops like my current sky, I'll buy it.. However, I do not have any comfort for those who have the OHB system. I am hopeful that once GM 'perfects' these s/w tweaks they can make the system as safe as those with the original vac assist systems.. We can only hope, if they can't, they should have/ make a fall back position and make kits available, to retro the parts.. Maybe even at a nominal costs.. I for one would probably pay if the price is reasonable.. BUT it should be free..
2.4L Midnight Blue, Premium Trim Package, Automatic, Monsoon Pre Audio 1-CD, Std Rear. GMPP CAI, 3M Clear Bra, Splash Guards, Black Top, Fiam Frwy Blastr 2-horn Opel Ant - WR V2 - Flux Capacitor - Last edited by MidniteBlues : 07-03-2008 at 10:08 AM. |
#5 (permalink) |
The title of the thread is not accurate. The NHTSA did not determine the 08RL doesn't have a brake problem. Rather, they could not identify a brake problem.
Absence of evidence is not evidence of absence. The disconcerting part of their response is the NHTSA study appears to be only a paper investigation. NOTHING in the NHTSA report identifies that any tests were performed by NHTSA. Hence, they get to collect the reports from owners, combine it with reports from GM, and make a ruling. If you don't test it, you have ZERO technical basis on which to rule against it. Hence. No Techical Test. No Technical Evidence. Can't identify a brake problem. Bottom Line: NHTSA does not want to issue a problem statement as long as GM is attempting to fix the problem. If the latest TSB does not solve the problem for a good number of owners, I have a method to re-open the investigation. At this point, we'll wait and see. Post your feedback on the boards when you have the TSB fix applied to your vehicle. This is government beauracracy in motion. Hang in there. It's not over....unless the TSB actually fixes the problem.
#8 (permalink) | |
2.4L Midnight Blue, Premium Trim Package, Automatic, Monsoon Pre Audio 1-CD, Std Rear. GMPP CAI, 3M Clear Bra, Splash Guards, Black Top, Fiam Frwy Blastr 2-horn Opel Ant - WR V2 - Flux Capacitor - |
#9 (permalink) |
Yes, it's already been established (on multiple threads) that later '08 builds have the vacuum pump.
Presumably, the '09s will have it as well...
#10 (permalink) |
Wish I knew what to look for when I got my "new" 08 last week that was actually built in Oct 07.
Anyway, this sure explains why the sales guy insisted on being the one to drive the car initially, and be the one to pull it out when I was ready to take it home. He also turned the radio way up to mask the fuel pump ticking. Tricky. Ed |
#14 (permalink) | |
See! ![]() Last edited by Sky_Pilot : 07-12-2008 at 09:10 PM. |
#15 (permalink) | |
2008 Sky Red Line Midnight Blue/Black/5 spd Splash Guards Opel Antenna 2006 Ion Red Line Pacific Blue/Black/5 spd Stage 2/Extrudehone Exh Manifold Front Grille imSaturn:http://www.imsaturn.com/profile/Rob41 |
#16 (permalink) |
I received my letter from GM about 3 weeks ago, had the "upgrade" done last week for no cost, just take the letter to the Dealer. Previously I let my RL warm up in my garage until the RPMs dropped to normal, this was due to the minimal stopping power of the brakes at immediate start up and moving. The problem now seems to be solved, I started the car and immediately out it in reverse, the brakes were MUCH more effective and felt like normal.
Black 2008 Sky RL, red interior. |
#19 (permalink) |
My 08 RL goes in for the break recall on Wednesday the 16th of July. They told me it was simply a "computer up grade" to fix the breaks. Said it will take less than 1 hour to fix. I will relay my findings to the forum on Thursday the 17th.
Clark and Donna Huffman 08 Yellow Sky RL Morgans Point Resort, Tx |
#20 (permalink) |
[quote=Clark90;338194]My 08 RL goes in for the break recall on Wednesday the 16th of July. They told me it was simply a "computer up grade" to fix the breaks. Said it will take less than 1 hour to fix. I will relay my findings to the forum on Thursday the 17th.[/QUOTE
Breaks fixed ! The computer up grade worked fine and even on the cool mornings at start up the breaks work fine. Geez, they finally did something right ![]()
#21 (permalink) |
All Fixed...
Brought my RL in today, they fixed my brakes and washed the car in under an hour. MUCH better! I've had more than a few close calls backing out of my steep driveway! My dealership didn't even need the details; I called and said I got a notice in the mail, and the service guy said "You drive an 08 Sky?" and that was that. Fast, easy, free, and VERY worth it!
I hope you all have the same outcome ![]()
*Ciel* 2008 Sky Redline Midnight Blue Tan/Black Leather Shorty Antenna Sky Mats Kappa Luggage Rack 3rd Brake Light "Redline" decal |
#22 (permalink) |
I just took delivery of my 2nd SKY, an 08' RedLine and my brakes are 100% the same as my 07'. No issues at all...
I'm very glad this is the case... BA...
__________________ 2nd SKY: 2008 RED on Red/Black Lthr RedLine Delivered - 7/14/08 Loaded Auto 3" Magnaflow, Lil Chromies & CAI 1st SKY: (Traded) 2007 Silver Graphite RedLine Loaded (-6CD) Deposit - 4/ |
