What air fuel ratio at full throttle ?
This is a question for you guys with a Dashhawk or aeroforce interceptor,how much air fuel ratio do you have at full throttle,mine shows around 12.5 and 13.5 which I think is a litlle to lean , I think it should be around 11.5 and 12.5.
My car doesn't have a flash.. Thanks... |
#3 (permalink) |
Actually you will here/read different ratios from people, BUT the laws of physics says 14.7:1 is the right ratio. Why do you and others see different readings??? Because the point of explosion is at 14.7:1 and the rest of the "free" chamber figures into the reading everyone sees. Sometimes 11 - 12:1 is what some see and think thats right, but that's not really true. The best way is to watch the temperature, fuel ratio, o2 sensors, tq and hp increase/decrease, knocking....all to determine the right ratio.
Midnight Blue RL - Automatic Rust proofed & Undercoated Painted calipers and lettering Painted engine cover, fuse box, rearend Third brake light decal Opel Gt antenna 3" Magnaflow exhaust CTI hard pipes Dejon Intercooler |
#4 (permalink) | |
#6 (permalink) |
The VVT valve overlap for the Ecotec can push uncombusted fresh air through the cylinder. Without calibration, the downstream sensors can read lean when the actual combusted mix is rich. In the stock configuration, this is accounted for by using a wideband 02 sensor and calibrating the reading in the ECM (since it will be aware of the valve overlap).
#7 (permalink) |
So if I understand you correctly when I see 13.5 on my dashhawk it could be a wrong reading and it could be for example 12.5 ?
I don't know for a redline but 13.5 for a porsche turbo at full throttle will destroy the motor... Just trying to learn about the redline because I will soon have a flash and I want the A/F to be perfect. |
#8 (permalink) | |
Maybe one of the main engine tuner folks can provide insight since they reflash the ECM and would need to be knowledgeable about such things.
#9 (permalink) | |
14.0 afr @ 1200-4000 rpm 13.6 afr @ 4520 rpm 12.9 afr @ 5000 rpm 12.8 afr @ 5320 rpm
2007 Solstice gxp |
