08 diy oil change 2.4
OK - did my first oil change on my 2008 sky and it went pretty well (resetting the dic was a snap). My question for anyone else out there that has done this themselves; What did you use on the nut for the oil filter? I had a 1 and a 1/4 socket, but it was too tall (a pipe in the way wouldn't let it sit down properly), so I took it to a bench grinder and basically cut away about an eighth of an inch, but I still did not like how it worked. Any suggestions would be appreciated.
Thanks!
08 2.4 Silver/Black/Red Black 5 Speed Single CD Monsoon Opel Antenna Vin #118396 SGS - 12/12/07 |
#2 (permalink) |
I use a short 1 1/4", 1/2" drive socket and a 6 inch extension. works great. Supprisingly my $50.00 Snap-On socket is too tall but I bought a cheap one at autozone of all places and it works like a champ! Also I found that buying the filter at the dealership is just as cheap as the auto parts chain stores and comes with a new cap and o-ring.
#4 (permalink) |
Short 1 1/4" 1/2" socket on a wobble extension. Wix filters only on my vehicles. Ray
2008 R/L with no cute little name... Stick, Midnight Blue, Black/Tan Leather Tan Top, Monsoon 6 Disc, Spoiler, Fujita CAI, MagnaFlow 3" CatBack, El Rancho red poly swaybar bushings ...and a block heater, unfortunately |
#5 (permalink) |
Thanks forlks; I appreciate the input. Didn't realize that I could buy a socket that size that was a "shorty", was thinking I would probably wind up having to buy a boxed end wrench and cut it off or something. Sounds good.
#6 (permalink) |
i use this
![]() it's from matco tools and is $10.. (be aware that anything that works on the 2.2 works on your 2.4 and the 2.0) Vehicle Service, Engine, Oil Change Tools | Matco Tools Online Tool Catalog |
#9 (permalink) |
Yes, the cap is plastic. It does not need to by torqued down very tightly either, if you overtighten it you could brake the cap off from the threads leaving the threaded part in the filter housing. Just snugg it and check for leaks.
