6200 RPM cutoff on RL
Is there a way to make that fuel cutoff go up or disappear on the Redline? I realize there are possible ramifications to my warranty, but I hit that fuel cutoff point twice and it's like a kick in the jewels when it happens.
I'm not looking to redline the Redline, but I'd just like to have a little margin of error in case I'm a little slow on the shift.
GMSKY 07 Midnight Blue RL Deposit MAR 06 RCVD NOV 5, 2006 |
#2 (permalink) |
If this is supposed to be a safety feature, it sure sounds dangerous
. Does it shut of the instant the tach goes over 6200 RPM? It would make more sense to me if it was tripped only if the tach was over 6200 RPM for more than one or two seconds.Not owning one nor having driven one to know for myself, what about this scenario: You're stuck in the slow lane behind a slower car so you downshift, stomp on it, and pull out to pass. You're telling me the car will go and shut off if you pass 6200 RPM? Meanwhile the guy behind you that you cut off nails you from behind? (I, by no means, condone this tactic . I'm just wondering what would happen).
Bought new house with garage. Mortgage a killer. Red Line on hold. |
#3 (permalink) | |
#5 (permalink) | |
Moderator Emeritus
X2 on this one. Look at it this way...it's saving you from yourself. Far better to bounce off the rev limiter at redline than a raised rev limiter above it. Do that too many times and you're going to severly shorten your engine life if you don't damage it right out. I'm sure there is some margine of safety with that limiter but I wouldn't risk it anyway. Now to your question. Yes you COULD raise it if you have access to a tuner that can edit your ECM...namely Vector. Not only that, but I would talk to him and see if this is a fuel cut off or an ignition cut off. I HOPE GM would do an ignition cut off rather than fuel as fuel cut off rev limiters are, in my mind, not a good idea. Our Grand Prixs have, from the factory, a fuel based rev limiter. However it is capable of being switched off or switching to an ignition based cut off and is one of the first things we do. Of course, with an Automatic Transaxle it's not as critical as on a manual transmission but the idea is still the same. Bottom line is keep it where it is at and learn to anticipate the shift. Your engine and your times will both benefit from it.
V.A.L. Midnight Blue MagnaFlow dual outlet, quad tip exhaust test car GMPP CAI 16.540 @ 82.096 MPH **Sold** Other car 97 Grand Prix GTP. 12.07 @ 113.4 MPH As seen on Pinks All Out Las Vegas! |
#6 (permalink) |
I don't cut people off. I figure if there isn't enough time to use my signal then that's a "cut-off". This was just straight line stuff and the only way to never hit it really is to stare at the tach (also not reccomended)
It IS a fuel shutdown, so it's a dramatic slowdown.
#7 (permalink) |
It IS aggravating, but true, 6300 rpm (not 6200) is the rev limit. As fast as it comes up in 1st and 2nd, and as quiet as the exhaust is, it is a bit of a pain. And the cutoff is sudden because of the short gears. I have found that one gives up NOTHING by shifting at 6000 rpm because the engine has SO much torque. Guess what? It is a REAL issue when autocrossing. Been dare, done dat! Get used to it. Unit someone unlocks the code in the ecm software we are stuck with it.
Redline (pre-halt), Pearl, Black/Red, complete option list except auto, owner installed lock buttons, painted calipers, Solo Performance 3" single cat-back, Koni S/A's, Kurt hitch, OZ's, 295/30 Hoosiers for Solo's |
#8 (permalink) |
From your starting post, I was under the impression it was like getting clotheslined in football. This sounds more like it.
Now that I think about it, a fuel shutoff is exactly what happens when you take your foot off the gas, only to a further degree.
#9 (permalink) | |
#12 (permalink) |
I don't hit it any more... As I learn the car, I know to start the shift as I am coming up hard through the 5000s... The power drops off there anyway, so it makes sense to shift out before bouncing on the ceiling.
Yes, the louder note of the 3" Magnaflow helps in that regard. It sounds "right." It does still get to the high RPMs awfully quick, though... I let a buddy drive SPIRIT yesterday, and he bounced off the Rev Limiter. He was surprised how fast it got up there. But there was no violent reaction or anything - the car just stopped accelerating. AND - there was a cool "Pop! Pop! Pop!" sound coming from the exhaust when it did it. I certainly like having the Rev Limiter there. I don't hit it very much any more, but I know that it is there for my protection.
First:"BABY" Silver Pearl 9 May 06 Then:"SPIRIT" Black Onyx Red Line 25 Oct 06 Check out My Photos! |
#13 (permalink) |
This problem just does not happen or exist with an automatic--
I suppose I can cram it down her throat by "maually" changing the auto and push the rpm's, but why bother to mess with perfection?? Stick it in D and just SToMP the mother-- ![]()
2.4L Midnight Blue, Premium Trim Package, Automatic, Monsoon Pre Audio 1-CD, Std Rear. GMPP CAI, 3M Clear Bra, Splash Guards, Black Top, Fiam Frwy Blastr 2-horn Opel Ant - WR V2 - Flux Capacitor - |
#14 (permalink) |
I'm an auxiliary cop, so I just kinda never wore seatbelts very much...but this Sky has trained me to do so when I drive it because of that annoying "bing-bong" whenever the bladder under the seat moves around. Is your display actually showing the door ajar statement? I didn't look, but it's usually just a stupid little switch the door compresses on that the thing is looking at.
#15 (permalink) | |
#16 (permalink) |
Yeah, I know my power curve pretty well after all the controversy it caused when Magnaflow posted the great results of the 3.0 inch Cat-Back exhaust that they fitted. People just could not accept the gains as real. But I can feel them. The dyno below is from my very car. (the blue line shows stock, the red line shows after the monster exhaust is installed.) Notice how the torque drops off after about 5200... I start to feel it there, then by the time I react the RPMs are in the upper half of the 5000s, and then I release the gas, press the clutch and downshift to the next gear. I'm actually starting to get it right now. Whenever I go back and drive BABY, though, my brain resets and it takes me a while to get to learn SPIRIT again...
First:"BABY" Silver Pearl 9 May 06 Then:"SPIRIT" Black Onyx Red Line 25 Oct 06 Check out My Photos! Last edited by JohnD : 11-24-2006 at 09:43 PM. |
#17 (permalink) |
Now with 1000+ miles on my RL, I never hit it anymore....
You just get used to it and I trained myself to clutch at 6000rpm and this gave enough time before she reached 6300 and cut off... Now, I just know by the sound of the motor and the car's pull when to change.... It is simply a matter of getting used to it..... ![]()
SKYGAZR SKY REDLINE LOADED AUTO. CHILI PEPPER RED WITH COBALT RED LEATHER AND CHROME WHEELS. 2007 CORVETTE Z06 6 SPEED MANUAL LOADED VELOCITY YELLOW 505HP SOLD: Sky RL Chili Pepper Red 5 SPD MANUAL SOLD :Sky Chili Pepper Red 2.4L Loaded! |
#18 (permalink) | |
#19 (permalink) |
Fuel cut will have the same effect as ignition cut (eliminate a cylinder from producing power), except if you only cut the ignition you will still be flowing fuel through the engine. This can be used as a turbo lag solution, but it can be detremental to the turbo and exhaust components to be igniting fuel directly on the turbine, or catalytic converter for that matter. Be glad you only have fuel cut.
#20 (permalink) |
i used to experience it at the end of second but you train yourself to shift jusat around 6000 . The engine seems extremely strong however and its as if GM left alot on the bench with this one . I'll bet in the next couple of years they will tweak another 30 hp out of this motor . Id be interested to see if an after market company could make a chip to safely manage this additional HP I feel is sleeping comfortably inside this little 2.0 monster .
G |
