I must apologize ahead of time for another cai thread but I read this the other day on gmroadster.com:
Plastic is a preferable material for aftermarket intakes as well, but you will notice that not many companies use plastic, and instead opt for metal and rubber components. There are many reasons why plastic is preferable, the most prevalent in regards to performance is how they do or don’t retain engine heat. Plastic has much less of a tendency to retain heat from the engine compartment, and is less susceptible to “heat soak”.
Based on this info I was trying to find a "plastic" cai. Any recs from others about this and manufacturers? Thanks for the advice. CH
2009 RL silver only mods thus far are tinted windows, K&N, color matched saturn eblems, & opel antenna
Picked up 9/26/08
There aren't any plastic intakes for our cars, just steel/aluminum ones. I'm sure the investment to get one molded isn't worth it in the end for a low volume car.
Or you can stick with the stock air box, which from everything that I've read gives just as much air flow to the engine and is just as efficient.Just doesn't have the look or the sound of a CAI.
This is true for the LNF Turbo's, we have seen little to no gains from cars that have aftermarket Intakes as opposed to cars that are still running the Stock Airbox.
In fact our strongest LNF Tuned car which Dyno'ed in at 292 Wheel HP still had the Stock Air-box with only a K&N Drop in Filter.
The 2.4L's on the other hand do benefit from a CAI.
If it didn't come through right it is on the home page at the bottom. Very good article. Thanks again for the replies. I like the insulation addition but may stick with the stock box with K/N drop in.
Anyone used the GMPP CAI?? Does anyone know the part #. I have had a little difficulty finding it online.
thanks again CH
Picked up 9/26/08
I'm no rocket scientist, but wouldn't any air leave the turbo on the way to the intercooler the same temperature regardless what the ambient temperature or intake system are? Aren't those primary compressor vanes like 1000 degrees or something?
It's not a mod unless power tools were involved.
Thanks,
Martin
Is the lack of gain because the "nanny program" is compensating, or some other reason? When tunes are installed they must be defeating the "nanny", so the CAI may have some benefit. I am getting ready to change from SCCA Solo stock to Street Prepared and a tune is item one, CAI #2, rear frame brace #3, I/C #4, and then I will attack the suspension by swapping the Konis for D/As withcoil over setup. I want to hear the turbo popping and farting!!!!!
__________________ Redline (pre-halt), Pearl, Black/Red,
owner installed lock buttons,
painted calipers,
Koni S/A's, Kurt hitch,
OZ's, 295/30 Hoosiers for Solo
Adiabatic compression will only increase the temperature by a certain ratio (depending on how many PSI the air is being compressed to in a very short amount of time). So if Redline A is taking in air at 70 degrees and Redline B is takin air at 50 degrees, Redline B's air charge will still be 20 degrees cooler after adiabatic compression by the Turbo. In the end, the charge is a little cooler in redline B. But to be truthful, our intake is already in a good location, and the plastics do reject heat pretty well. So a cold air intake on the LNF doesn't really offer a cooler intake charge, and the turbo is doing the breathing for us so the intake restriction isn't too big of a deal. Now if we were collapsing the hose due to the enormous vacuum of a bigger turbo, then we may opt for a lower restriction intake.
Isn't it true that the reason the RL's don't benefit from CAI's is due to the bad airflow within the engine box.
There are no vents in the front or top for airflow, just the two inputs down near the fog lamps. That should be why the K & N drop in or modifying the airbox has been shown to do better.
Wondering if anyone has taking the blocks out of the grill, the hood vents, rerouted the lower intakes, and see if the CAI would actually have a benefit.
__________________ 2008 Sky Redline "SkyLon" Midnight Blue / Black Top/Leather
Monsoon 6 Disc
Tri-Pedal
Thats exactly the reason why every bolt on doesnt gain any hp, the ecm has a strict rules of airflow numbers it wants to see and it adjust boost accordingly to get it. Once you improve the efficiency of the engine(intake/exhaust/cat/intercooler/whatever) the ecm simply lowers the boost to get the same airflow numbers as before.
If you have a stock and modded kappa on the dyno and both have the same tune the modded car will be running less boost to hit the same numbers as the stock one.
Take a look at any other turbocharged car, every little mod that you do you get a gain in hp because it improves the efficiency of the engine, the ecm see's more airflow so it adds more fuel unlike our ecm.
No, we believe it's because the Stock Inter cooler on the Redline /GXP is 98% Efficient and since you are raising the air temperatures via the turbo anyways CAI's don't really have that big of an impact on Forced Induction Motors.
Now on N/A cars where there is no Turbo to heat the Incoming air you see better gains by using a CAI.
The stock intercooler is far from 98% efficient, i've seen iat2's climb 30-40 degrees over ambient temps with the stock intercooler. Plus its small size makes it heat soak during racing at a far greater rate compared to intercoolers 2-3x its size.
Since there really isnt any place where cold air can enter our cars the cai's only job is to remove the restrictiveness of the stock airbox/baffles/filter which Westers tested on Dejon's cai and it flowed a lot more. If we wouldnt have such a nanny ecm we would be seeing gains on every mod we add.
