Old 04-26-2008, 08:24 PM   #1 (permalink)
encriptor's Avatar
Check Engine after WG Mod & EDAL MOD
Hey Everyone,
Driving around town the car seemed fine. But today I went to the race track and after making a pass I received a code P0088 - Fuel Pressure Too Low (Performance).
What exactly is that supposed to mean performance? I had adjusted the rod on the wastegate all the way in, and the EDAL is connected through a Y Adapter. I used a new 3/16" hose instead of cutting the stock one so that I can truly return back to stock under any question. I have the spring on order from Dejon but now I am wondering if I should return the car back to stock.
Any suggestions? If I did that HP Tuners suggestion would that fix this issue? Anything to help would be greatly appreciated. The exhaust was making popping sounds like when when you rev to high, and the mottor feels like it is shaking pretty bad. After shutting down the car doing a code clear and starting it back up again the car seems to be driving ok. But I am nervous to push it again.
Thanks,
The Festas!
1964 Chevrolet Corvette
2004 Pontiac Grand Am SE
2006 BMW K 1200 R
2007 Pontiac Solstice GXP
encriptor is offline   Reply With Quote
Old 04-27-2008, 02:06 PM   #2 (permalink)
SCVanguard's Avatar
I just did the wastegate mod and I had the screw on the left side fall off which caused the actuator to come completely off the rod. I'd take a look at that first.
How many miles are on it? If it's still in the warranty safe zone, just roll everything back to stock and take it in. When they noticed the nut was off, I played dumb and there was no issues.
Brad
2008 Sky Redline
Chili Pepper Red
18" chrome
Monsoon
Stubby
