Fujita CAI Issues
I just installed the Fujita CAI and ICP yesterday afternoon. I had a great day of driving with the top and radio up. I even got my first "That's a Saturn" from a couple of people walking in front of the car while we waited to go green.
Today I the car throw a code though. OnStar says its an issue with the air intake. It looks like all the connections etc. are still on tight. Has anyone had the same issue after installing the Fujita CAI. Any advice to point me in the right direction would be appreciated.
"I Drive Way Too Fast To Worry About Cholesterol" 2008 Chilli Pepper Red Sky R/L Black Top Black Leather Interior Monsoon System w/6 Disc Chrome Rims Spoiler RPI GT Exhaust Fujita CAI & ICP Lil' Chromies Stubby Antennae |
#2 (permalink) |
Actually "top down and radio up"
#5 (permalink) |
I do not know the exact code. The representative from OnStar merely stated that the air intake was the issue. Since then I examined all of the hoses and T-Clamps. A couple of them needed to be retightened; however, after that the car was still showing the check engine light. I think I will need to take it to the dealer to get a better indication of what the exact code is.
#7 (permalink) |
There was an earlier thread where someone got a Fujita that had the MAF sensor bung welded on backwards causing all sorts of problems. Ray
2008 R/L with no cute little name... Stick, Midnight Blue, Black/Tan Leather Tan Top, Monsoon 6 Disc, Spoiler, Fujita CAI, MagnaFlow 3" CatBack, El Rancho red poly swaybar bushings ...and a block heater, unfortunately |
#8 (permalink) |
I saw that post earlier today before I started my thread. I will be checking on that issue tomorrow. The vehicle has not seen any rain so I have eliminated that possibility. I have also disconnected the battery about 15 minutes ago and will be connecting it back up and see if that rectifies the issue.
#9 (permalink) |
Make sure you have the air flow pointing in the correct direction. Also I know of a few Fujita CAI's that had the airflow meter bung backwards so the meter would never fit correctly and by that I mean the little plastic piece that is electric that you fit into the CAI.
07 SKY Redline Silver Red/Black Leather, JPM Dash Red leather, WDE Carbon Fiber Dash Kit, BSR Tune, Fujita Intake, Dejon IC pipes, Hahn IC, 3" Magnaflow Quad Exhaust, DDM BBK (RED), BlackCatCustom Gauges. http://www.compdoc777.com/Carstuff/sky1.jpg |
#11 (permalink) |
Actually, the check engine light went off after reconnecting the battery. I went to the dealer today after coming back from a sales trip to Dallas and discussed the issue with them. They stated that a "hard reboot" of the system shouldn't have cleared it up. The code that was thrown was for the mass airflow sensor, code P101. It hasn't acted up again since, now it's just a waiting game to see if it happens again. I also checked the mass airflow sensor again and it is installed correctly.
#12 (permalink) |
Here is a comment today from
Bill Hahn Jr. Hahn RaceCraft "The Fujita is a nice piece, but it's a bit notorious for its smaller than stock tube size, which throws the MAF sensor calibration out in left field...essentially, the car thinks its experiencing much more airflow than it really is, leading to over-rich fuel mixtures and possible issues with the airflow readings exceeding acceptable thresholds."
Silver/RL 2007 - Black Top - Red/Black Leather 5th Break Light, DeJon CAI, IC Pipes Magnaflow, Opel Badges Hahn Intercooler, Westers Tune |
#13 (permalink) |
I assume you have not had the same issue with your DeJon CAI?
#14 (permalink) | |
#15 (permalink) | |
2007 Solstice gxp |
#16 (permalink) |
Engine light on and then back off again.
#17 (permalink) |
Some have said that if you have too much oil in your filter it can cause sensor problems. May try cleaning the filter and make sure you use very little oil, that is if you use an oiled filter!
#18 (permalink) |
Search previous threads
I remember reading a previous thread where someone had the same issue and someone suggested to replace the filters with dry filters. It cured the problem. Try the search.
Nuke
4.2 Tan over Green,Tan Leather, 6CD Monsoon,Chrome Wheels, Lil Chromies, Stubby Antenna, Seatbelt Extender “Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?” George Carlin |
#19 (permalink) |
Installed my dual intake Fujita two months ago on my 2.4 and no codes. Also these filters are dry and require no oil for the 2.4l.
08 2.4L SKY Forest Green/Tan/Black-Tan Fujita CAI "JohnD" Visor Mod Big Bore Throttle Body (to come) Vector ECM Tune Magnaflow Catback (to come) Hahn Stage II (to come) FUN SKY |
#20 (permalink) |
Looks like the issues are all done and taken care of now. I adjusted the filter and gave it a little more room between the end of the pipe and the internal fittings of the filter and now the issue seemed to have resolved itself.
