Old 07-24-2008, 01:24 AM   #1 (permalink)
New parts available for Kappa's: HKS HipermaxIII coilovers
Found these gems while looking around. HKS Hipermax III adjustable coilovers. For those that don't know about HKS, they DO NOT make junk ricer parts. HKS parts can be found on the fastest imports around [Skyline, Supra, RX7, 350Z, Evo, Sti, ect].
HKS USA Hipermax III
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
Thought I'd let you guys know
2007 Solstice GXP
"Natsumi" Japanese female name that translates to Summer Beauty.
Lithium Lotus is offline   Reply With Quote
Old 07-24-2008, 01:34 AM   #2 (permalink)
fr0stb1t3's Avatar
Oh hell yes!
random filler to beat the word count filter....
Old 07-24-2008, 09:15 AM   #3 (permalink)
ParrotHeadNation's Avatar
hks makes good stuff not quite tein but still good stuff
Now:
1994 Chevy S10 Extended Cab
1990 Bronco Eddie Bauer - 31s, 351 Windsor,Top Removed
Next:
Ordering 09 Black Onyx Saturn SKY Base or RL- Feb 2009
ParrotHeadNation is offline   Reply With Quote
