Nitrous on a RL???
Looking for some input here, would a "dry" Nos system work with the redline?
If not, please explain. I've seen the system setup and it looks doable as far as havin the spray come into the engine after the IC just ahead of the TB. I'm wondering how the direct injection will be effected, and things of this nature. Thanks in advance ![]()
Landscape REDLINE #131984 Forest Green / Tan N tires Brake light pulse V2 WR Seat and Lumbar Mod Polished SS IC pipes Color match eng. cover VDI Doors Solo-Mach Lil Chromies, Chrome Domes, Billet Grill Dashhawk Green Neon Underbody |
#2 (permalink) | |
Bill Hahn Jr. Hahn RaceCraft GM TurboCharging since 1988 Ecotec Turbo Specialists www.turbosystem.com |
#3 (permalink) |
got a ? eco, off topic, i was wondering, is there any chance of yall making a turbo manifold for the redline/gxp. the stock one seems REALLY restrictive and no one makes an aftermarket manifold. i would DEFINITELY be interested in one.
Mods: Dejon IC Piping, Spring Magnaflow 3" catback Wastegate Mod: 20psi Removed gm emblems behind front tires Nokya 7000k lows, highs, and fogs Parking Light Leds License Plate Leds Little Chromies 3rd brake light vinyl: REDLINE |
#4 (permalink) |
Nice try mateyI agree with Bill. A direct port injection would be best, and most will be 75 HP minimum.
Kendall 2008 SKY R3DLIN3 White/Black/Chrome/Auto (2 pedals are faster) Mods: K&N, Koni, SMS Throttle body, Hahn IC & BSR, Dejon IC pipes & gauge pod, Aeroforce Interceptor, Autometer boost gauge. |
#5 (permalink) |
A wet system would be better, but you still need some form of ecm control, currently hptuners is a bit limited so you'll have to wait.
Have you measured the inside diameter of the runners? What makes you say its restrictive?
2007 Solstice gxp Last edited by shabby : 07-06-2008 at 10:43 PM. |
#6 (permalink) |
Hmm good thread topic, I was wondering myself. Obviously a dry shot would be out of the question because I doubt the ECU would like that.
A wet shot is the better option for F/I engines but I'm wondering how that will work with the direct injection. DI runs more fuel psi (anyone have a number?) so you may have to play with the jetting for awhile to get it right.
2008 Sky Redline: Slow :( 2000 Ford ZX2: 50 trim turbo 303whp B5 Audi A4 1.8T: Slammed and Slow Kawasaki ZX6RR |
#7 (permalink) |
You would get your fuel supply from the Schrader valve located on top of the intake manifold. It is fed from the in-tank pump (50-60 psi is my guess) and feeds the cam driven fuel pump that cranks out the real pressure. Like most EFI wet kits, your fuel supply would come from the Schrader valve and should be similar pressure to any late model GM.
#8 (permalink) | |
#9 (permalink) | |
#10 (permalink) |
This question needs to be followed up with another question.
Other than for the obvious reasons why would you even want to put Nitrous on your RL? You want more power? Get a tune from one of the many sources. You want WAY more power? Do a Turbo swap. Nitrous is an inexpensive solution for an engine that otherwise doesn't readily have the means to produce big power gains. When you have a Turbocharged engine you already usually have much more power available you just need to follow a few simple steps to unleash it.
-Adam Chant "Tune it or lose it" 2007 Silver Saturn SKY 2.5" Dual Exhaust - Stealth Style TEAM SCSKYSC 2008 I don't know? |
#11 (permalink) | |
#12 (permalink) |
Did you spray a fuel and nitrous mixture through the upflow throttle body?
#13 (permalink) |
I would be more concerned about the fact that you do not have control over when the throttle body opens and closes, you can only make suggestions to the computer...
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
