No Lift Shift-Tell me about it! - Saturn Sky Forums: Saturn Sky Forum
 3Likes
post #1 of 24 (permalink) Old 01-07-2016, 04:53 PM Thread Starter
Blue Baby's Avatar
Quoted: 15 Post(s)
Hey folks. Bought a 07 RL with 32K miles and pristine condition.
Seriously looking at the turbo upgrade kit Item #19212670HK from CED. Not planning to go much further but any comments/suggestions on a CAI would be appreciated.
I am also interested in comments regarding any change in drivability after the upgrade. Wife will be driving it and I don't want her to have any issues.
Finally, I would like to hear about the 'no lift shift' feature. Whats it like?
Thanks all,
Mike
Blue Baby is offline
post #2 of 24 (permalink) Old 01-07-2016, 05:30 PM
Elff's Avatar
Quoted: 121 Post(s)
It's a feature where you shift without lifting the gas[You still need to use the clutch] at a specific RPM.
I am blanking at what RPM
If you are going to limit yourself to a tune, but not swap out the cat, and exhaust, Doing a CAI does not net you any performance. Just sound and looks.
Does the Part# you included from CED include the quick connect adapters for the new 3 bar sensors? If not, make sure you get that one.
LUSIFER
Elff is offline
post #3 of 24 (permalink) Old 01-07-2016, 05:50 PM
Quoted: 189 Post(s)
No change in driveability, but many have reported improved gas mileage (as long as you keep your foot from being too heavy!)
The no-lift-shift is fine, but not something you would do (or WANT to do) on a day to day basis. Great for the drag strip, though.
TomatoSoup is offline
post #4 of 24 (permalink) Old 01-07-2016, 06:49 PM
Quoted: 632 Post(s)
Or Autocross...LOL
I need to look into the LE5's computer and see if we have that kind of feature there. I've been too busy trying to figure out why my O2 sensor won't work with HPTuners right now.
Robotech is online now
post #5 of 24 (permalink) Old 01-06-2017, 11:48 AM Thread Starter
Blue Baby's Avatar
Quoted: 15 Post(s)
Hey Folks! Update:
I purchased the Trifecta Budget Tune and installed it last week while in SW FL.
I wounds up giving my wife the Red Cable for a Christmas gift. She was so excited and told everyone I gave her Torque for Christmas!!!
Install was straightforward. Took our Redline for what turned out to be an extended test drive. It was tricky to watch the boost display while driving but it wokred out well.
Also got to try the No Lift Shift feature. It is not easy untraining your brain and foot to NOT come off the (wide open) throttle, but it works and what a thrill..
Wife and I are very happy with the new power under the hood!
Mike
post #6 of 24 (permalink) Old 01-06-2017, 12:09 PM
Quoted: 632 Post(s)
Glad you and the wife like it Mike. It's a hell of a performance upgrade.
post #7 of 24 (permalink) Old 01-06-2017, 12:26 PM Thread Starter
Blue Baby's Avatar
Quoted: 15 Post(s)
Sounds like a replacement downpipe is another good upgrade. Anyone have experience with this? I am worried about breaking studs...
Mike
post #8 of 24 (permalink) Old 01-06-2017, 02:09 PM
Quoted: 632 Post(s)
I know I'm not an LNF car but I did sleep at a Residence Inn last night...
...Oh, and use an LNF downpipe on my K04 (LNF's) turbo. LOL
You have to be careful removing the bolts that connect the turbo to the downpipe. Be sure to hit them with penetrating oil and let them soak before hand.
The studs that connect the downpipe to the exhaust can also be tricky but you should have new ones of those that come with the new downpipe so IF they fail, it shouldn't be as big of a problem. Again, penetrating oil is your friend on those too.
post #9 of 24 (permalink) Old 01-06-2017, 08:44 PM
cityboy's Avatar
Quoted: 17 Post(s)
Send a message via AIM to cityboy
Changing out the down pipe some found to be tricky and had to lift the thus remove that
I have done it twice and found if you twist and turn in the cirr4ct way no need to doing anything but lift the car to get to it and drop it out the bottom
09 silver RL
rims
spoiler
pedals
black leather
6-disk
gm-CIA
painted calibers
opel antenna
blue low/fog lights
gm turbo upgrade
WR
Cateless down pipe
Engine caps.
Pro beam
Back bone
Venom brace
Custom badging
DDM IC pipes
cityboy is offline
post #10 of 24 (permalink) Old 01-06-2017, 10:15 PM
christopher_2's Avatar
Quoted: 44 Post(s)
Kroil -vs- PB - The Garage Journal Board
2007 (2.4L)
Solo Cat
Magnaflo Redline dual exhaust
Werks Turbo @ 10 PSI
FE2 shocks
ZOK anti-sway bars
christopher_2 is offline
post #11 of 24 (permalink) Old 01-06-2017, 10:58 PM
Elff's Avatar
Quoted: 121 Post(s)
Kroil all the way.
**** is real life unicorn tears that can uncease anything.
LUSIFER
Elff is offline
post #12 of 24 (permalink) Old 01-07-2017, 08:44 AM
stungjoe's Avatar
Quoted: 157 Post(s)
Trifecta has "No lift-Shift" component to it? I thought that was just the GMPP tune??
Anyways, the stock cat/down pipe can be removed as cityboy states by positioning the pipe just right and screwing it out. Holding your tongue when you don't position it just right is optional. It did seem the well placed curse words helped me more than it helped in removing the cat.
mstrjon32 likes this.
Joe
FLASHED
2008 Red Line Carbon Flash SE Naked!
stungjoe is offline
post #13 of 24 (permalink) Old 01-07-2017, 09:08 AM
Quoted: 38 Post(s)
I was also under the impression that the NLS was available only with the GMPP tune...
mstrjon32 is offline
post #14 of 24 (permalink) Old 01-07-2017, 09:33 AM
Quoted: 189 Post(s)
The other aftermarket tuners reverse-engineered the NLS from the GMPP tune. I think pretty much all of them have it there now (certainly HPT does).
mstrjon32 and stungjoe like this.
post #15 of 24 (permalink) Old 01-07-2017, 10:48 AM
Quoted: 38 Post(s)
Interesting. I wonder if Trifecta offers an upgrade for those of us that have had the tune since before they offered it with NLS...
Human Verification
