No Lift Shift-Tell me about it! - Page 2 - Saturn Sky Forums: Saturn Sky Forum
 8Likes
post #16 of 58 (permalink) Old 01-07-2017, 12:56 PM
wspohn's Avatar
Quoted: 125 Post(s)
Originally Posted by Blue Baby View Post
I wounds up giving my wife the Red Cable for a Christmas gift. She was so excited and told everyone I gave her Torque for Christmas!!!
Lucky guy - with my wife there's no torquing to her about cars!
Early versions of the Trifecta tune didn't have NLS in it, Vince never saw the point but I guess he changed his mind later if there was demand for it. It is usually used once by the curious and then never again.
1957 Jamaican - MGA
1958 MGA Twincam
1962 MGA Coupe
1965 Jensen CV8
1969 MGC roadster,
1969 Lamborghini Islero S
1971 Jensen Interceptor
1988 Pontiac Fiero GT
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #17 of 58 (permalink) Old 01-08-2017, 08:51 PM
jgassor's Avatar
Quoted: 21 Post(s)
I would definitely use it during autocross if it saves me a second going from first to second (rarely get to third). Just so hard to unlearn the lift action when shifting. did a couple of shift from second to third like this and can managed to do it quickly enough as so not to red line. My assumption is that red line will not be allowed when shifting in this fashion. Its kinda scary but also exhilarating!
Jim
Techo Gray 2008 Sky RL with Trifecta and DDM bracing
jgassor is offline
post #18 of 58 (permalink) Old 01-08-2017, 10:26 PM
Quoted: 741 Post(s)
You just need to be quick about it. I can almost do it now...but my clutch doesn't like it. Ran across my painter friend in his tricked out Datsun and once I hit third engine reved much faster than the car was accelerating. So I'm trying to take it easy until the new clutch is in but I have played around with it some...almost can do it without the ECM programming (since the LE5 ECM doesn't have a no lift shift option). I just have to lift 20% or so as I shift and make the shift quick. I bet with the short shifter I could do it without lifting or, at least, lifting less.
I think I tried it in your car Jim and you can do it right up to redline but doing that requires you to time it really well. If done correctly, the shift should take tenths of a second.
post #19 of 58 (permalink) Old 01-08-2017, 11:48 PM
stealthsky's Avatar
I do it with the N2MB WOT Box. It has NLS that is not RPM dependant. You can record how long your shifts are between gears and set up a custom time for how long spark is cut out, or can have it automatic. It also has a launch control feature you can program what RPM you want it set at. It just needs to be wired into the car.
stealthsky is offline
post #20 of 58 (permalink) Old 01-09-2017, 07:18 AM
stungjoe's Avatar
Quoted: 157 Post(s)
I'm with Vince on this one. I'm not even curious enough to use it once.
Joe
FLASHED
2008 Red Line Carbon Flash SE Naked!
stungjoe is offline
post #21 of 58 (permalink) Old 02-17-2017, 12:58 PM
Quoted: 54 Post(s)
I have a question for everyone regarding the Trifecta tune.
I only want to pay for one tune, but from what I hear if you do the downpipe upgrade you have to get it retuned. Well they charge the same amount for just an update.
My question is since I'm getting the tune first and will wait a bit for the downpipe. If I tell trifecta that I already have the downpipe when I get the tune, and they give me a tune as if I have the downpipe on it, but I don't...will that create a crappy tune for my car without the downpipe?
MattM is offline
post #22 of 58 (permalink) Old 02-17-2017, 01:54 PM
Quoted: 741 Post(s)
The difference between the tunes is pretty minor, but I would call them and ask them how critical it is to have the tune for a car with a high flow or catless downpipe on a car with a factory cat. I'm trying to think what may go wrong in that scenario and am drawing a blank at the moment. Not a lot of sleep for Robo last night...
post #23 of 58 (permalink) Old 02-17-2017, 03:34 PM
stungjoe's Avatar
Quoted: 157 Post(s)
I have the canned trifecta tune ($200) and in previous threads it was stated that anything after the turbo was OK to change. So I now have a SOLO hi-flow cat and Magnaflow exhaust (I really like the sound).
Now in those previous threads I have heard two opposing views on the intake side of things. Some say it's OK to to do a CAI, change the IC and charge pipes some say it's not. So I have a K&N Typhoon and a DDM street IC sitting in my storage (waiting for me to get off my a$$ and install them). My theory is since it's been established that the intake side changes are more acoustical rather than performance I'm not sure it would be of any detriment to the tune to add those things as well.
However I'm pretty certain that I'm not getting the full potential of my add-ons with the canned tune. It's my understanding that for Trifecta, at least(you will want to verify with Trifecta), you can get the custom tune ($400) by simply paying the difference ($200) from your original purchase of the canned tune and start data logging and sending that data to Trifecta for tweeking.
Joe
FLASHED
stungjoe is offline
post #24 of 58 (permalink) Old 02-18-2017, 09:58 AM
Elff's Avatar
Quoted: 157 Post(s)
To answer your question, takes a small description of AFR. AFR is the Air Fuel Ratio. Without going into great detail, you will want to make sure you car is not running lean [too much air] or running too rich[too much fuel]
The downpipe is the biggest factor and performance restriction in tuning our cars with the stock turbo. If properly tuned, a car with a high flow catalytic converter or no cat in the downpipe, can get 20-30 more wheel HP. On 93 Octane, on a stock Kappa, the car will be able to be tuned to roughly 280-290 rear wheel hp. Add the high flow cat or no cat downpipe and most tuners can get you to 300+ wheel hp
So the problem you might run into, until you get the new downpipe, is that the car will run Rich as it is expecting more air, compensating with more fuel, but does not have the extra air.
So you might have bad starts, which will require you to wait for the car to warm up more before driving, and you will see black unburnt fuel [which will be powder like] around your tail pipe ends.
Personally, I would just wait.
LUSIFER is Sold!
say hello to
RYUK
Elff is offline
post #25 of 58 (permalink) Old 04-03-2017, 12:28 PM
Quoted: 54 Post(s)
So. I just flashed the budget Trifecta Tune over the weekend. With the NLS feature...How does that work? I was in second and floored it...then kept the gas floored pushed the clutch in and shifted to third. Now the car didn't really act any different than I would have though it normally would. When I pushed the clutch in the RPMS shot up and then I shifted and let the clutch out it seemed like the clutch slipped and then picked up again and I started to go.
Can you guys tell me what should happen in the NLS feature? Like I thought the ECU would put timing then when the clutch was let out again just add back. Should my clutch be slipping as a result of NLS? When I shift conventionally my clutch does not slip at all it grabs.
I can say that if what happened was how the NLS is supposed to work then it is actually slower than when I shift conventionally do to the fact that it creates sort of a lag from when the clutch actually grabs.
Hopefully what I'm saying makes sense.
MattM is offline
post #26 of 58 (permalink) Old 04-03-2017, 12:39 PM
wspohn's Avatar
Quoted: 125 Post(s)
Trifecta never used to do a no lift shift, that was a feature of the GMPP tune. Were you told that you had it? If so perhaps there was enough demand that Trifecta eventually added it.
In any case it isn't, IMHO anything you should use frequently if you care about the clutch, as I'd be concerned about slippage at the shift. It is something that owners often try once or twice and then not again unless they are drag racing.
1957 Jamaican - MGA
1958 MGA Twincam
1962 MGA Coupe
1965 Jensen CV8
1969 MGC roadster,
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #27 of 58 (permalink) Old 04-03-2017, 12:48 PM
Quoted: 54 Post(s)
From what I understand...Trifecta has been adding that to the tune for a while. I could be wrong I guess....
MattM is offline
post #28 of 58 (permalink) Old 04-03-2017, 12:57 PM
wspohn's Avatar
Quoted: 125 Post(s)
Could well be. I talked to him in the early days and he said they hadn't had any demand but they could do it if anyone wanted it. Once you have the programming, it doesn't cost them anything to add it as an additional feature, so why not.
1957 Jamaican - MGA
1958 MGA Twincam
1962 MGA Coupe
1965 Jensen CV8
1969 MGC roadster,
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #29 of 58 (permalink) Old 04-03-2017, 12:59 PM
Quoted: 54 Post(s)
I just sent a message to Trifecta to ask them if my tune actually came with it. Better safe than sorry I guess....
MattM is offline
post #30 of 58 (permalink) Old 04-03-2017, 08:01 PM
Quoted: 54 Post(s)
So.....this is wierd. According to Trifecta (guy named michael) 2007 sky redlines cant have or dont get nls with Trifectas tune bc the 2007 has an analog throttle tracker and the 2008+ has a digital sensor that tracks if the throttle is floored.
He said bc of that since mine is 2007 I dont have it.
Is that true?
MattM is offline
Human Verification
