Will the Trifecta tune stop my ecu from pulling power? - Saturn Sky Forums: Saturn Sky Forum
post #1 of 60 (permalink) Old 02-27-2017, 12:45 PM Thread Starter
Quoted: 43 Post(s)
I keep noticing this with the stock ECU settings. In second gear it really has a tendency to pull timing and boost, and I can really feel the power drop at the higher RPMS. It doesn't matter if I have traction or not. I'm just wondering if after I get the Trifecta tune my ECU will never again pull power due to loss of traction or it perceiving that power has increased "learn down."
I would bet that the majority of the 14.1-14.6 1/4 times that magazines and car owners see in stock form is the computer pulling timing and boost in the upper RPMS because it "thinks" the driver is too aggressive or more power is being made than should be. That's just my speculation anyway.
Back to the question though. Please let me know if after you got your Trifecta tune your ecu stopped pulling timing and boost just because it thought you were making too much power. I know it should still pull timing if it sees knock, but with anything else I wish it would quit pulling timing!!!!
MattM is online now
post #2 of 60 (permalink) Old 02-27-2017, 12:57 PM
Quoted: 685 Post(s)
Are you scanning to see what the ECM is doing?
post #3 of 60 (permalink) Old 02-27-2017, 01:00 PM Thread Starter
Quoted: 43 Post(s)
No, but I can feel it and check the boost gauge in second. It just depends on the time of day I guess as to when it pulls power. It's weird, but I would have thought the ecm would have learned my driving habits by now....
MattM is online now
post #4 of 60 (permalink) Old 02-27-2017, 01:10 PM
Quoted: 685 Post(s)
This is why I like to scan to figure out what's going on with the car.
With the RL, I have far less experience with it's programming to be able to tell you what it's doing. If your car is stock, this isn't necessarily the learn down feature you hear about. The learn down feature is really in regards to performance modifications not netting more than stock power levels because of the ECM. If you're stock, something else is going on.
In my experience (which isn't vast by any means) there may be a number of things causing that pulling of power. You mention time of day...does it do it more when it's warmer out? This could be the ECM pulling power due to the temperature of the air charge to prevent KR OR it could be KR generated due to higher air charge temps that come in the warmer part of the day.
post #5 of 60 (permalink) Old 02-27-2017, 01:46 PM Thread Starter
Quoted: 43 Post(s)
What would I need to scan the car?
MattM is online now
post #6 of 60 (permalink) Old 02-27-2017, 02:56 PM
Quoted: 685 Post(s)
Either the Torque app with a Bluetooth OBDII Dongle or something like HP Tuners. The Torque app is usually the cheaper way if you just want to scan. The dongle is about $100 on eBay for one that gives enough resolution to record a scan and then the Pro software is about $5 I think. You can find cheaper dongles that will let you monitor the ECM values while you drive but they don't work as good for recording those values.
post #7 of 60 (permalink) Old 02-27-2017, 03:46 PM
jgassor's Avatar
Quoted: 18 Post(s)
Is it worth trying this test out in competitive mode so see if a loss of power is still felt? This will help eliminate if the loss of power is deliberate. I dont seem to experience this condition as described, with or without Trifecta enabled.
Jim
Techo Gray 2008 Sky RL with Trifecta and DDM bracing
jgassor is offline
post #8 of 60 (permalink) Old 02-27-2017, 06:13 PM
Quoted: 685 Post(s)
Well, this is what makes me wonder about the OP's situation. I don't think the OP has the Tune yet and so I don't know if it will help him or not if the problem is something unrelated to the changes Trifecta makes in the tune.
post #9 of 60 (permalink) Old 02-28-2017, 07:49 AM Thread Starter
Quoted: 43 Post(s)
I did buy the app and dongle hopefully Ill know whats up soon.
MattM is online now
post #10 of 60 (permalink) Old 02-28-2017, 12:28 PM
wspohn's Avatar
Quoted: 109 Post(s)
Stock program has limits all over the place, so no doubt it is doing its job. Take a look at a factory torque curve some time - if it didn't limit torque low down the tires and possibly driveline would have a significantly shorter life. I never noted the tendency you did - and I suggest that you not word things to imply that you know the car "really has a tendency to pull timing and boost" when you have no evidence of that without instrumentation. You may have some issues that could be determined by having a shop with appropriate tools evaluate your car.
This is the stock dyno curve. It is not what actually happens in first (and, IIRC, second) gear, as the program has limits that smooth performance.
Suggest that you read these:
LNF Mod Primer - Pontiac Solstice Forum
GMPP Tune Learn Down?? - Pontiac Solstice Forum
1957 Jamaican - MGA
1958 MGA Twincam
1962 MGA Coupe
1965 Jensen CV8
1969 MGC roadster,
1969 Lamborghini Islero S
1971 Jensen Interceptor
1988 Pontiac Fiero GT
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #11 of 60 (permalink) Old 03-01-2017, 12:38 PM Thread Starter
Quoted: 43 Post(s)
Sorry WSpohn I didn't know I was offending anyone by saying what I see with my own eyes and feel. I literally see the boost in 2nd only get to around 13psi, and then I feel the car stop pulling after 5000 rpms or so. I then shift into 3rd and the car getting around 18psi all the way to redline and feel it continue to pull.
As I said, I'm getting a Bluetooth dongle and have the torque app and will know soon if it is because of knock or not. I don't know if they dealership put premium fuel in it, but I put 89 octane in on my first fill up. That might not be high enough octane, and causing detonation, but I won't know that. If it is not knocking then I will still have to figure out if it has to do with the ecu learning my driving habits or what's going on with it. I read in the thread that you linked were a few people were talking about the fact that they were steadily getting lower times at the track but there was no change in driving habits, and they suspected the ecu was just "learning" their track habits and slowly adding timing each run.
Is this something that the ecu does (i.e. learn driving habits)?
MattM is online now
post #12 of 60 (permalink) Old 03-01-2017, 12:51 PM
wspohn's Avatar
Quoted: 109 Post(s)
You aren't offending anyone, but please explain how you know that the program is 'pulling timing". Isn't that an assumption on your part?
1957 Jamaican - MGA
1958 MGA Twincam
1962 MGA Coupe
1965 Jensen CV8
1969 MGC roadster,
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #13 of 60 (permalink) Old 03-01-2017, 02:15 PM
Quoted: 685 Post(s)
Actually, it may not be.
MattM, a brief run down on ECM "learning".
What most people talk about when they are talking about an ECM "learning" has to do with fuel trims. There are two types, Long Term Fuel Trims (LTFT) and Short Term Fuel Trims (STFT).
Whenever you reset your ECM (through a programmer, scanner, or unplugging the battery for about 30 minutes) you are resetting your fuel trims to 0. When a fuel trim, Long or Short term, is at 0, it is neither adding or subtracting fuel from the basic fueling table. This means, whatever values you have in your various tables that dictate how much fuel to add (fuel injector tables and Mass Air Flow, or MAF, tables mainly) are spot on and the trim has to do nothing.
Now, if your trim goes into a positive number, this means that whatever you have in your tables is off a little and the trim has to add more fuel to achieve the proper Air to Fuel Ratio (AFR) for those specific conditions...ei RPM, Throttle Position, MAF reading, fuel injector duty cycle, etc. If the number goes negative, then that means the trim is pulling fuel to achieve the proper AFR.
Like I mentioned, there is a Short Term Trim and a Long Term Trim. The STFT is what the ECM is doing RIGHT NOW to adjust fuel. If, for a certain condition the STFT is constantly adding or subtracting fuel, it will re-write the LTFT to the average STFT value for that condition.
So let's say for a certain condition your STFT averages -6. This means it usually is rich in this condition and thus the STFT is pulling about 6% of the commanded fuel to hit 14.7:1 AFR (because for this condition you're just cruising...makes things simpler). So since it's doing that, it writes -6 to the LTFT. Now your LTFT is at -6 and your STFT is at 0 for this condition. Why did the STFT change? Because the LTFT is already pulling the 6% the STFT averaged. Now, there may be times when the LTFT is at -6 and the STFT is at 1 or -1 too but it's average over time should be at 0 once the LTFT cell is learned for that condition.
What's important to know is that the values for the LTFTs and STFTs are cumulative. So if the LTFT is at -6 and the STFT is at -1 then you are pulling 7% fuel at that condition. If LTFT is -6 and STFT is 1 then you are pulling 5% fuel for that condition.
This is how the ECM "learns" not just your driving style but the little nuances of your engine, the environment you're driving in and how the engine is reacting to different conditions.
This is constantly happening and your LTFTs and STFTs are always updating themselves. As a tuner, one thing we do is tune the MAF table to get those LTFTs to learn to 0...or as close to 0 as possible. This means our ECM is loading the proper values to hit the correct AFR target in these conditions within +/-2%
To get a better idea of how all this works, check out these two images I made on closed and open loops in the ECM. This was for a Harley forum but the principle applies here too. This is just a very basic overview on what's going on with our ECMs:
HOWEVER, This learning has nothing to do with spark. This is only fuel. Our ECMs are designed to run our cars optimally on 91 octane or higher fuel. When you do this, you should see no knock and when the ECM sees no or only sporadic unpredictable knock (which is defined as false knock) it runs on a spark advance table called "Good Fuel Spark Table". This is your basic spark table and determines how much spark advance the ECU bases it's spark calculations on. Now, whenever you see knock, false or otherwise, the ECM will pull timing (reducing performance) to try and combat this knock. With False knock, because the knock is usually just there and gone, this timing comes back very quickly. With real knock though, the timing will come back more slowly as knock is reduced. The worse the real knock, the longer it takes the ECM to add it back in.
However, if you have knock consistently, the ECM will switch over to what it calls the "Bad Fuel Spark Table". This table has lower timing across the board. Remember, these Good Fuel and Bad Fuel spark tables are the base spark advance table your ECM uses before adding or subtracting timing for various conditions. Thus if you run on the Bad Fuel Spark table, your timing will always be less than if you're on the Good Fuel Spark table.
Running your car on anything other than 91+ octane will put you on the Bad Spark Table. This is why our engines are "recommended" to run on 91+. If you run on 91+, you get the Good Fuel Spark table and get more performance. If you run on less than 91+, the car isn't going to get damaged but it is going to run on the Bad Fuel Spark Table and the reduced performance that goes along with that.
So if he is running on 89 octane, it may be a safe assumption the ECM is "pulling timing" because it should be running on the Bad Fuel Spark table. This also means just scanning for knock may not tell us anything. If the car is running on the Bad Fuel Spark table and it's lower spark advance numbers to start with, the car may not be seeing any knock...and thus the Bad Fuel Spark Table is giving us the results is should be giving us, no knock when running on fuel with an octane lower than 91. We need to see the spark advance commanded to get an idea of what table his ECM is running on.
I will also add that running on 89 octane is the worst decision you can make. It's more expensive than 87 but gives you 0 performance benefits over 87. Run 87 or 91+...and with the turbo motors you really only want to run 91+.
Dropping your boost to 13 psi though is related to neither of these things. That sounds like your ECM is pulling boost for some reason...or you have some other issue that's causing a loss of boost pressure...though usually that's an all or nothing kind of thing if you're not getting some kind of engine code along with the lower performance.
post #14 of 60 (permalink) Old 03-01-2017, 07:44 PM
Quoted: 23 Post(s)
I ever see 18psi on stock tune. Are others seeing 18psi on stock tune ???
I show 14 to 15 stock and 22 to 23 on Trifecta.
Larry
Z06-Redline is offline
post #15 of 60 (permalink) Old 03-01-2017, 10:58 PM
Quoted: 2 Post(s)
Most of the time I get 15-16 psi, but sometimes I get 17 or 18 psi (No tune)
~ssky~
Ssky is offline
Human Verification
