Old 08-11-2007, 07:55 PM   #1 (permalink)
kwayne's Avatar
Location: born & raised in Roseville,Mi. now living in Egg Harbor Twp.,NJ outside Atlantic City
Send a message via AIM to kwayne
going to strip
Something else I've always wanted to do; some questions:
1) I have stick what RPM to leave,
2) what traction setting,
3) what tire pressure - i run 30psi on stock tires, ran 40 in autocross was thinkin' 25 for traction.
Ernest I think u got most experience at track - help please
Ken
Mean Green Wolverine
R/L Forrest Green,3 pedals, spoiler,1 CD Monsoon
Originally Posted by Wise/Aldrich
From what I can tell Washington has finally come up with an effective illegal immigration policy: Let the economy get so bad, nobody will want to come here.
kwayne is online now   Reply With Quote
Old 08-11-2007, 11:39 PM   #2 (permalink)
PoppyH's Avatar
Try different RPMs starting around 2500 and change 200 rpm and go again, use the rpm that gives you the best 60' times is what I've always been told and it seems to work. Clutch release is also important, you may have to feather it out some to slow down wheel spin; bottom line here is to be consistent with how you do it. "Dropping the clutch" is hard on all of drivetrain and usually results in just a lot of wheel spin, burning rubber and bad (high) 60' times with resultant bad 1/8 or 1/4 mile ET, etc.
I'd start with traction in competition mode, what we did and found it worked best but I have an automatic so may be different with stick. Again try different settings to see which gives you the best 60' time. Totally shutting down traction control will just lead to 1 wheel spinning and not letting LSD do it's thing right but definitely don't want all of the electronic babysitters shutting down throttle or adding brake pressure, etc.
Same thing for tire pressures try different pressures in 2# increments or maybe even 5# increments if you're not seeing any real differences, but 25 if probably a good start if using street tires. Too low pressure will increase traction, but very hard on street tires and stock drivetrain, as is too much pressure being hard on tires due to too much wheel spin.
Finally, make only 1 change at a time on these so you know what is making the change. Have seen some make a change to all 3 and don't have any real idea what the final effect was due to and had a real mess going.
Red Line, black w/tan top & blk/tan interior
Loaded w/auto, XM, Monsoon, 6 CD.
Prototype multi-color v1 Windrestrictor; love it!
Super shorty stubby.
PoppyH is offline   Reply With Quote
Old 08-12-2007, 10:06 AM   #3 (permalink)
Supporting Member
JohnD's Avatar
My Photos: (73)
I told Mrs. JohnD that I was "going to the strip." She gave me a dirty look. When I added, "I hope to get a pole position" she smacked me...
Check out My Photos!
Old 08-12-2007, 10:57 AM   #4 (permalink)
SkyBaby's Avatar
My Photos: (13)
hehe... That .. I would PAY to see..... . I have gotten so many compliments on my Jacket... Thank you again.... LOVE IT... .SkyBaby
Kwayne, I was told not to put more than 29psi in my tires. ?
Old 08-12-2007, 05:47 PM   #5 (permalink)
kwayne's Avatar
Tirerack spec sheet says max pressure = 44psi
Ken
Old 08-13-2007, 12:06 AM   #6 (permalink)
SkyBaby's Avatar
My Photos: (13)
Ahhh.... well, Ok... I guess I should read some more.... . How do you know how much to use?.... Oh well.... Thanks.. SkyBaby
Old 08-13-2007, 12:10 AM   #7 (permalink)
cerberus's Avatar
My Photos: (19)
You're fine Teri with 29. That is the recommended psi for normal street use. When folks take their cars to the track they need to adjust from normal street psi.
Old 08-13-2007, 12:46 AM   #8 (permalink)
Spag's Avatar
Location: Delaware, walking distance from the Production Line!
Send a message via MSN to Spag Send a message via Yahoo to Spag
I waited an entire day before clicking to view this thread...
the title scared me - was I going to see a pic I wasn't prepared for??
Alas, I can now smile since I finally know that this is a car related thread!
No more fancy fonts 'cause I'm posting from my phone...
02.07.05 1st SKY viewing
02.08.05 SKY Waiting List
10.31.06 CHAOS IS HOME
Kappa Pics
UK Pics
Originally Posted by sworthit
I'm ready to break tradition!!!
Spag is offline   Reply With Quote
Old 08-15-2007, 06:23 PM   #9 (permalink)
RPIpower's Avatar
Your best bet is to try running different tire pressure, launching at different rpms, etc. Don't dump the clutch though. You might have to ride it a little bit but the stock clutch might not be up to the task. Or...just don't drag race it. The car is much better on a road course.
Eloy
"Brutus" #001 RPi 2.4GTS
Race Precision, Inc.
7029 Marcelle Street
Paramount, CA 90723
562-630-5966
www.raceprecision.com
RPIpower is offline   Reply With Quote
Old 08-15-2007, 08:50 PM   #10 (permalink)
Antonio's Avatar
from my times at the track......
Best RPM to launch was around 3500 with a slight feathering of the clutch. Not exactly a normal (street driving) engage, but not a dump either.
I turned all traction systems completely off (hold down for 10 seconds) Tire pressure around 25, I wouldn't want to go below that.....not with these tires anyhow.
Which track are you going to, and when? maybe I'll come down too.
Did you see my other thread. Autocrossing this saturday. Raceway Park. 9am. We gotta get to a race event together. You and I are the "rowdy" ones of our group
NASSOA Founding Member
Old 08-15-2007, 09:31 PM   #11 (permalink)
kwayne's Avatar
Track
1) I'll be going to ATCO on a Fri. - not sure when, in the next couple of weeks.
2) yeah,saw the post-but fri is the MRS.& MIL BD so doing dinner Sat. nite with the family; wouldn't have time to get back.
They're autocrossing down here on Sept. 16.
Ken
Old 08-15-2007, 09:33 PM   #12 (permalink)
Antonio's Avatar
sweet, sunday. I should be down for that
Old 08-17-2007, 12:13 AM   #13 (permalink)
What a disappointing thread. I was hoping it was gonna be a good story from kimberlysky or skybaby or one of the other forum hotties!!!
Old 08-17-2007, 12:46 AM   #14 (permalink)
Here's how to set the correct tire pressure:
1) Bring an air supply.
2) Drop the tire pressure down to 20 psi. Do a short burnout.
3) Examine the tire marks. If the mark is lighter in the center, then you need more air. If the mark is darker in the center, let some more air out. The goal is to have the black mark evenly dark all the way from the outside to the center.
4) It's faster to make big jumps in pressure at first and then zero in using smaller and smaller increments. For example, drop 10 psi first to 20 psi. Let's say it's too low. Then jump up 5 psi to 25. That's too high, so then you drop 3 psi to 22, which turns out to be perfect. That's 3 trials. If you just dropped 2 psi at a time, it would take you 4 or 5 trials to find it.
On the launch: Don't do a burnout in the water box. That's really only for slicks and drag radials. Street tires, with their deep tread, will pick up water in the tread and won't get rid of all of it during the burnout, and you'll drip water at the starting line. If you don't know what I'm talking about, you'll understand in about five seconds once you watch a few races. Instead, drive around the water and do just a short, 2 or 3 second burnout to clean the tires before you roll up to the starting line.
Have you ever been to the track? It's fun as heck. If you need some more pointers about how to stage and how to bracket race and stuff, let me know.
Stonebreaker
1996 Impala SS
355 ci LT1
11.99 at 115mph on 150 hp nitrous
2002 ECIRS CHAMPION
Ph.D. in R.E. (Redneck Engineering)
Well, it works in practice... But will it work in theory?
stonebreaker is offline   Reply With Quote
Old 08-17-2007, 12:59 AM   #15 (permalink)
cerberus's Avatar
My Photos: (19)
One handy thing about the Sky on track days is that we have an air compressor in the trunk to add back air. No spare of course in the rear glovebox, but in this case, it's a benefit.
Old 08-17-2007, 08:22 AM   #16 (permalink)
HiredGun's Avatar
Racing Voids Warranty?
Just a word of caution. My son took his Subaru Legacy to the track. Six months later his 5th gear went out while driving normally on the highway. Subaru refused the warranty claim because they were able to produce forum threads that look just like this one.
It was a $4000 lesson.
Hired Gun
"Of all the boats I have loved, the Sky is my mistress."
Toledo, Ohio
The Sky is my 4th Saturn and 2nd Redline.
HiredGun is offline   Reply With Quote
