Old 11-12-2006, 10:15 PM   #1 (permalink)
GaryH's Avatar
Clay Question?
First, let me say how much I've learned on this forum. I've never heard of claying a car before I read about it here. At my local autoparts store the only brand I could find was Mothers. It was a kit with a clay bar, spray detailer, and wax. It was about 18 bucks for the kit. Spray the detailer on, rub it with the clay bar, wipe it off. Then use Mothers cleaner wax. Really kind of easy. My question is, did I do it right? I used a plastic sandwich bag to feel the surface of my Sky like I've read about on this forum. Yes, it was rough. After I clayed and waxed the car it was a world of difference. Much smoother. However, I can still feel a little roughness when I rub my hand over it with a sandwich bag. On a scale of 1 to 10. Before was a 10 and after was a 2. Did I not do it right? Should it be a 1 or 0? Should I have spent more time with the clay bar? It looks great. But, it's a Silver Pearl and looks pretty good even when it's dirty. If you clayed a black, midnight or any dark color on any car, I think it would really make more of a difference. Will claying make the paint last longer and look better longer?
Silver Pearl
Black/Black leather
CD/MP3 XM satellite
5 speed manual
VIN#1745
Fiamm horn
Magnaflow Quad Tip Exhaust
Old 11-12-2006, 11:45 PM   #2 (permalink)
Skip's Avatar
Gary, you did fine. I bought Mothers and clayed the car using the detail spray. Wash it again and then used the wax to seal. It came out very good. Also use Raggtop for the ragtop. Just make sure when using RAGGTOP that you cover the windows and body before spraying the top. It can be a mess to get off. Skip...
Originally Posted by Darkwing View Post
I wish I had her azz too......about even with my belt buckle.
Old 11-13-2006, 08:57 AM   #3 (permalink)
MBVette's Avatar
Send a message via AIM to MBVette
Gary you did it correctly, you just might not have been thorough enough to get everything off. W/o feeling the surface myself, I cant say for sure. But it is possible that you are feeling what is normal. Remember the paint is not going to be 100% perfect no matter what we do.
MBVette is offline   Reply With Quote
Old 11-14-2006, 08:12 AM   #4 (permalink)
Gary. don't use cleaner wax, its 90% abrasive, go through the proper steps, (see Solstice detailing forum) wash, clay, wash, deep clean, polish, seal, here are some basic claying tips, Gary
Since the use of clay bar is one of most essential steps in car care, I thought it would be appropiate to post the "How to" of using clay.
Everyone wants to keep their Car in top condition, but if you drive it everyday, like most of us it is subjected to all kinds of contaminants.
Biggest complaint I've heard is "how to get out surface scratches". First lets talk about how they got there. Most of time its from improper washing/drying. When the car is not prepped properly, all you do is work existing dirt into the finish. (this is called Micro Marring)
The clay bar is the best solution to ensure proper cleaning BEFORE you polish/seal. Most people never heard of clay, and if they have they don't know how to use it. After you wash your car as I normally do, feel it with your hand.
A simple test is to put your hand in a plastic baggie and gently move across the finish, (The plastic magnifies the senses in your skin 15 times that of bare flesh so you will notice things through the plastic you never before felt.) if it grabs a little, or feels rough, you have fine particles of dirt that you did not remove during the washing stage. HOW TO USE CLAY. First get yourself a fresh bucket of soapy water. break off a small piece of clay in your hand, (clay works best with lots of lubrication) lather a small section of your car, dip the clay on the water, spray the clay with quick detail spray, gently work the clay in a side to side motion. (don't press to hard, it works well with gentle pressure)
After 4-4 strokes, spray again, lather, and do another section. Keep dipping clay in the bucket, keep spraying with QD, work side to side. You will see (and feel) the finish getting cleaner, your hand will start to get the hang of it (if the surface gums up, it is not lubricated enough).
Once you get it down, its easy. The key is lubrication, gentle side to side motion. also, after a few sections, press the clay in your hand in and out, making a fresh surface. It looks and feels like play dough, so you can make a new surface by working it.
One piece will do the whole car. IF YOU DROP THE CLAY THROW IT OUT, USE A NEW PIECE! It will pick up dirt from the ground and become a hazard, working like sandpaper. after you do the whole car, wash car again to remove clay residue, dry with large waffle weave micro fiber towel. Follow up with a paint cleaner and sealant. Your finish will be show car ready. Gary
Added:
Why do you clay a new car? Because when your car is shipped from the factory it attracks rail dust. Occurs when the friction between the steel train tracks rubs agains the steel wheels it creates hot metal fibers that stick to your finish.
Here is a simple test to see if you need to clay. Wash and dry your car. Get a plastic zip lock baggie. Put your hand in it and touch your finish - don't worry it won't hurt it. Now rub your hand gently around, if you feel bumps, roughness like fine sandpaper, that is the grit on your car you never noticed. Clay will remove that.
www.perfectautofinish.com
