Old 11-08-2006, 08:17 AM   #1 (permalink)
[Gary's] Product descriptions
Perfect Auto Finish
Ultimate paint cleaner:
A mild abrasive deep cleaner to be used after washing and clay procedure. Contains polishing oils to restore a wet look shine while cleaning the finish. Simply apply about a quarter size amount of product on an applicator pad, work product into the finish in back and forth motion, remove right away with a micro fiber towel. Work in small sections at a time. Not in direct sunlight.
Ultimate Paint Sealant:
A highly reflective finish that will also provide superior protection lasting up to 6 times longer than any wax. Apply a small amount on an applicator pad, do the entire car and let it sit for app 20 minutes. Remove with a micro fiber towel. (Recommended using paint cleaner prior to using this product for the first time)
Ultimate Spray and Shine:
Water based non protective product used as a lubricant for clay bar, and for removing smudge marks, finger prints, and dust. Use whenever necessary, simply spray and wipe with a micro fiber towel.
Poly –Seal Spray:
A petroleum based product that includes some of the properties in my paint sealant. A coat of poly seal offers added protection to your finish, giving the paint sealant added depth and brilliance. Use this once a month or whenever you want to “refresh” your finish. Continued use of poly-Seal will keep your car in show room condition. SHAKE WELL. Spray and wipe with micro fiber towel.
Ultimate Dressing:
A water based dressing safe for all rubber, molded plastic, and vinyl. Shake and spray on your engine, tires, wheel wells> use an applicator pad to apply on dash, inside door trim, rubber seals and other interior parts made of same. Will not stain or harm paint.
Ultimate leather cleaner;
A neutral medium alkaline cleaner safe for all leather and vinyl. Simply spray and wipe clean.
Ultimate leather conditioner:
A Lanolin based conditioner ideal for all leather to ensure oils are kept in leather to prevent from drying out. Use after the leather cleaner. Apply a small amount on a pad, work into the leather, continue until you are done, then go back and buff with a soft towel to a satin shine.
Clay Bar:
Automotive clay is specially formulated to remove surface contaminants from the finish, ensuring the finish is as clean as possible. This critical step is key is obtaining the most reflective shine on your vehicle. After car is washed, get a bucket of water and car wash soap solution, have your spray and shine handy. Flatten a small piece of clay in your palm; remove all jewelry from your hands. Lather a section of the car you are working on with soap solution. Dip the clay in the solution as well, now spray the clay and the section of the car you are about to clay, (NOTICE NOW MUCH I EMPHASIZE LOTS OF LURICATION)now rub the clay back and forth, when it starts to feel like its hesitating, repeat the procedure. Continue over entire car. When you’re finished, do a quick wash to remove clay residue, dry and your ready to deep clean.
p.s. If you drop the clay, throw it out, it will pick up millions of tiny dirt particles, which will harm your finish, use it wisely.
Micro Fiber is the softest most absorbent material on the market. Nothing comes close to this product for drying and or removing polish, wax/sealant or cleaning windows. They can be used over and over again, wash as you would any towel just don’t use fabric softener
Old 11-20-2006, 05:29 PM   #2 (permalink)
brentil's Avatar
My Photos: (90)
ToTheTop
Introducing some of Gary's very informative posts.
Supporting Dealer/Vendor Point of Contact (PM me for details)
[Official list of Supporting Vendors and Dealers]
2006 Solstice, Mysterious [sold]
Born Sept 8th, 2005
2007 Solstice GXP, Mean
Born Nov 17th, 2006
Old 04-22-2008, 07:05 AM   #3 (permalink)
Send a message via Yahoo to jesselyons2002
Just wondering if your on autopia or autogeek.net
jesselyons2002 is offline   Reply With Quote
Old 05-09-2008, 10:57 PM   #4 (permalink)
Top cleaning
I got a spot on the top and i dont know how to clean it can some one help me
starship is offline   Reply With Quote
Old 05-11-2008, 08:35 PM   #5 (permalink)
You can actually clean you top with a nylon bristle brush and the car soap from your bucket you use to clean your car. Just remember when using car soap. To throughly rinse out the soap out of the fabric. If you have apc you can dilute 30:1 on the spot with the nylon bristle brush and rub the spot. After that get a warm damp terry cloth or mf towel and blot the spot to pick up the residue. Then use another dry terry cloth or mf and pick up the remaining residue.
Old 05-12-2008, 09:59 PM   #6 (permalink)
Thanks i'll try that have to wait looks like rain next couple days
Thanks again.
Vic Juarez
