| Supporting Vendor News & Announcements Supporting vendor product news & announcements section | Supporter thread starting only |
#31 (permalink) |
Interesting
20RWHP? that would be about 22-25 at the crank.
Think about this. Formula one cars only get max of 20 at 180MPH! Wheres's the blower hidden ![]() I'd like to see a picture of your intake. Last edited by RickyD : 09-04-2007 at 12:41 AM. Reason: ask for picture |
#33 (permalink) |
That's basically the same thing I had on mine but I had built a aluminum box (like Brutus's) around mine and sealed it up with the CAI tube and filter inside. On the road I didn't notice anything and the intake temps where the same even at 80 MPH weather I had the box on or off. So I took it off because it didn't make any difference.
#34 (permalink) | |||
Eloy "Brutus" #001 RPi 2.4GTS Race Precision, Inc. 7029 Marcelle Street Paramount, CA 90723 562-630-5966 www.raceprecision.com Last edited by RPIpower : 09-04-2007 at 02:39 PM. |
#35 (permalink) |
Dyno?
My box as aluminum as well and is sealed also with two 3 inch hoses running to the front of the car. The only difference might be the size of the filter which I am running a K&N on the end of my CAI.
Dynoing bicycles? I think you need to bring it over to a real dyno. just kidding Is your dyno one of those that has the two smaller rollers that the cars tires sit between when you run it? And weather you have a box or just running tubes into your factory airbox. ram air is ram air. Last edited by RickyD : 09-04-2007 at 06:20 PM. |
#36 (permalink) | |
I think you are getting the whole thing confused. You DONT want a ram air affect when you have a turbocharged car. This thread is talking about the 2.4 NA. As for your intake set up. Its nothing like mine. All the details of what I did is where the difference between yours and mine lie. I sized my filter to the amount of power and size of my turbo. It was custom made to my specs. My hoses are coming in from a different area than yours. You cant simply say, its going to the front of the car also.
Eloy "Brutus" #001 RPi 2.4GTS Race Precision, Inc. 7029 Marcelle Street Paramount, CA 90723 562-630-5966 www.raceprecision.com |
#37 (permalink) |
Hp
The guy that does my dyno work has eddy current on his Dynojet 224xlc also. http://www.dynojet.com/downloads/cat..._auto_dyno.pdf
What I am and some others is questioning is on one post you said you have been getting 125 rwhp on stock 2.4's but the dyno sheet on this thread says around 147? Why the difference? And I'm not confused. I am talking about the 2.4's. You mention the the biggest gain was from the intake and according to people have said on here you are telling them on the dyno it is making right at 20HP? Or is the 20HP once everything is set and tuned. These are our questions. Or was that just a typo.If possible, and I know you are busy but is there any way we can see the dyno sheets each time you make a change? Intake then exhaust and then final tune? Last edited by RickyD : 09-04-2007 at 11:34 PM. |
#39 (permalink) | ||
I'm not a fan of supercharging. I don't like the fact that I am on boost all the time. I like the fuel economy and efficiency of a turbocharger better. I also like the simplicity of maintaining a turbocharged car instead of a sc car. Thats just my opinion but others may prefer the sc over the tc. Anyone who is in So Cal, that are able to get this tune/package, just drive Mark's car. Thats better than seeing any graph or hearing any type of argument over the net. Thats why we wanted those wanting gobs of power to come out and drive the GTS in FL in a couple of weeks. All it takes is a test drive to convince you. ![]()
#41 (permalink) |
We had several people test drive Cerberus' car and they were all very impressed. Let me know if you are ever around this area. We'll schedule a test drive.
BTW, this package is now called "2.4R1"
#42 (permalink) | |
the current S/C kit out there for the Kappas does not keep the engine in boost all the time. It has a boost bypass valve built into the S/C the keeps the engine in vacuum until you go WOT, then it closes and you have instant boost. There is also no addtional maintenance to it as it has it's own oil system that is good for 100k miles |
#44 (permalink) | |
That is what I was going to say the SC's are superior to turbos for gas mileage and maintence they have a bypass which runs most of the time unless you are on boost. The bypass it always active and modulates through partial throttle and then WOT. It is instant boost not laggy like some of the turbo even the sky RL turbo. Now I have 2.0 liter Acura RSX Type S is makes a little more stock 180 Whp compared to 135 whp, but with the SC at 11PSI. I make 200 whp at 2500 rpm (Which is more than stock at just off idle) then a whopping 320 whp at 8800 rpms. With torque dropping past 8K. I hardly have to drive hard or even get on the car to accelerate quickly and making so much power down low means that I can remain in the lower rpm not engaging Vtec. Still using the variable valve timing though thus saving gas. Yet, I get 35 mpg on a bad day. Now if I get into the pedal I can suck gas at an incredible rate and get down to 15 mpg or less. Yet trips where I am just cruising 70-80 mph 35 mpg or just town crusing it sipps fuel. Now with my car stock (no more SC) I find that I have to beat on it to get it to move meaning my gas mileage goes down. 22-28 zone. I also find this with the Redline it needs a great tune to wake it up. The BSR is good, but it still needs some more gusto off idle and up top. I know when I have a good tune when the car is silky smooth on acceleration and just seems to want to go effortlessly instead of having to force it. Turbo act different on different days good some days and bad others. Unless you can tune it daily.
07 SKY Redline Silver Red/Black Leather, JPM Dash Red leather, WDE Carbon Fiber Dash Kit, BSR Tune, Fujita Intake, Dejon IC pipes, Hahn IC, 3" Magnaflow Quad Exhaust, DDM BBK (RED), BlackCatCustom Gauges. http://www.compdoc777.com/Carstuff/sky1.jpg |
#45 (permalink) | |
Anyhow, the car is going to have a roll bar fitted, along with some other goodies so I'll see how that goes.supercharger more efficient than a turbocharger?
#46 (permalink) | |
#47 (permalink) |
Cool. Could you explain to me how a belt driven accessory will help with gas mileage over something that is being spun by exhaust gasses? Im just curious to see your theory on this because over the several years of doing this I have never seen this happen.
