| Supporting Vendor News & Announcements Supporting vendor product news & announcements section | Supporter thread starting only |
Fidanza Aluminum flywheel 2.4L Sky installed..
We are now offering the Fidanza aluminum flywheel for $355 and/or $640 installed. Although the 2.4L gives a good amount of torque, it suffers from slow revs. The Fidanza flywheel weighing in at just about 7.5lbs will lighten the load on the engine and provide quicker revs.
Eloy "Brutus" #001 RPi 2.4GTS Race Precision, Inc. 7029 Marcelle Street Paramount, CA 90723 562-630-5966 www.raceprecision.com Last edited by RPIpower : 02-02-2007 at 10:47 PM. |
#2 (permalink) |
FYI, I have received PMs asking what the stock flywheel weighs. I just weighed it in at 21.2lbs. Its a HUGE difference
Eloy "Brutus" #001 RPi 2.4GTS Race Precision, Inc. 7029 Marcelle Street Paramount, CA 90723 562-630-5966 www.raceprecision.com |
#3 (permalink) |
And does it fit the GXP/Redline 2.0?
Redline (pre-halt), Pearl, Black/Red, complete option list except auto, owner installed lock buttons, painted calipers, Solo Performance 3" single cat-back, Koni S/A's, Kurt hitch, OZ's, 295/30 Hoosiers for Solo's |
#4 (permalink) |
This particular flywheel is only for the 2.4L. I will be in contact with them on Monday to see where the 2.0 development is at.
#5 (permalink) |
Any word on the development of a similar flywheel for the Redline? thanks Eloy.
HAD - '07 Redline -292 whp & 327 wtq - SOLD :( HAVE - '02 Chevrolet Corvette Z06 - STOCK....for now http://youtube.com/profile?user=talkaboutblue NASSOA Founding Member |
#7 (permalink) |
Dumb question. Why do they put such heavy stock flywheels on? I would think they would get better performance to use as a selling point by simply using a lighter flywheel.
SKY 4 ME 2008 Red Line Chili Pepper Red / Black/Red Interior Auto Spoiler Chrome Wheels Single Disc Monsoon XM Deposit 3/10/2007 Order number 6/28/2007 Delivered 8/4/2007 MSRP + GM Employee discount UPShield Little Chromies Stubby antenna |
#9 (permalink) | |
Landscape REDLINE #131984 Forest Green / Tan N tires Brake light pulse V2 WR Seat and Lumbar Mod Polished SS IC pipes Color match eng. cover VDI Doors Solo-Mach Lil Chromies, Chrome Domes, Billet Grill Dashhawk Green Neon Underbody |
#10 (permalink) |
Ok. both answers make sense. Is there any draw back/concerns with simply changing a flywheel?
#12 (permalink) |
There's also a downside to a lightweight flywheel.
Some things to consider: - Engines don't make a lot of torque at very low rpm - Flywheels store energy - The amount of time you spend driving the car in high performance is nothing compared to the time you spend driving the car just getting around in traffic So, with these things in consideration... Heavier flywheels help launch the vehicle at a reasonable rpm. If you're good with the clutch, you'll find that just by slipping the clutch you can get the car moving with no throttle. This is because of the inertia of the flywheel. And the more weight something has, the more intertia it has. Where this plays out is in stop and go driving situations. It's a lot easier to launch a car with a heavy flywheel as opposed to one with a fly weight wheel. The heavier flywheel also dampens out the crankshaft pulses, which can give you a bit of a bouncy engagement and make idling around in 1st gear a bit jerky. When cars were much bigger and heavier, there was a general rule of thumb for flywheel weight: 1 lb flywheel weight for every 100 lbs vehicle weight. But this isn't universal. The more torque an engine makes down low, the less weight you need in the flywheel. Of course, there are other considerations, like 1st gear and rear end ratio. Essentially, the more axle torque you make, the less important a flywheel observe the general rule of thumb. And the use of the vehicle has a lot to do with it too. Of course, this extra weight has a downside and benefits the lightweight wheel. Accelleration and deccelleration are faster when you aren't using power to swing a heavy wheel. Just like everything else when it comes to performance in a car, there are always compromises. |
#13 (permalink) |
The problem wih changing the fly wheel is that you are making a direct exchange of high rpms for torque. But this engine wasn't balanced or designed for high rpms, it was designed for torque. The reason it weighs so much is so that the torque is high, exchanging this out will drop your torque significantly and you will have to rev the engine to get torque. For the RL this would mean bad news, as the gears are long, based on the low-end torque. I would never change the flywheel....
2007 Silver Pearl RL Alloys, single CD Monsoon Black Leather Manual Trans K&N Replacement Filter No E10 |
#14 (permalink) |
Yes, you do lose low end with a lighter flywheel. There are pros and cons and they are all different from car to car and from set up to set up. The best thing for you guys to do is to try driving a car (sky/solstice) with the lightened flywheel. Then you will be able to tell if the pros out weight the cons. In my case, the pros far outweight the cons.
#15 (permalink) |
Thanks everyone. I am getting a Redline, and it sounds like for what I'm looking for this mod isn't going to be any benefit. I definately do't want to lose any torque. I was just looking to understand the pluses ans minuses with this mod. I have a much better understanding now. That's why I continue to come here. If there's a question, even from someone with little or no experience, there are usually several people that chime in on both sides. This really helps with the decisions about what mods/accessories I want to spend my money on.
SKY 4 ME
