07 R/L Misfire should I have it checked?
My 07 r/l has a misfire yesturday when I was coming home from work. It was raining hard and I had just turned onto a side road when the check engine light started blinking. I immediately pulled over and when I did I noticed the engine sputtered. Turned off the car and called onstar. They said to crank it so they could check what code was listed. Said it was a misfire.
I have had this car misfire before, but it was a long time ago. This is the first time it has done this in a while, and it drove home just fine. Last time, saturn said they found a loose plug cable and replaced it. Should I bother having saturn check it out? Or will they just clear the code and send me on my way? The dealership is an hour away and I would hate to waste the gas if the trip won't be worthwhile. What do you guys think?
Midnight Blue R/L Blk/Tan Auto Polished wheels MP3/CD player 6-disc #124999 3800: 1/24/07 Delivered: 3/24/07 Kappa CAI |
#2 (permalink) |
I'd get it checked. It may something minor. Or not. Even if they "just clear the code and send you on your way", at least you have a record of the problem.
Silver Pearl Black/Black leather LSD CD/MP3 XM satellite 5 speed manual VIN#1745 Fiamm horn Magnaflow Quad Tip Exhaust |
#4 (permalink) |
It has the newer plugs in it. I had them replace them way back when... when it was misfiring every morning at startup. That didn't correct the misfire, but I wanted the new plugs in there anyway. I will call Augusta and see when I can bring it in for the checkup.
#5 (permalink) |
I had the same thing happen.
Driving home through very hard rain. Had several instances of a misfire and Onstar was able to confirm this. By the time they examined the car remotely the misfires had stopped. I took it to the dealer under warranty, they cleared the code, and reported no fault found. I suspect the rain may have had something to do with it. It has never misfired since then.
