Old 05-28-2008, 12:34 PM   #1 (permalink)
08 Sky- Pinching Convertible Top
Hi,
I was wondering if anybody else is having this problem. I have searched the forum and have found a couple topics on it. I am having the exact same problem with the cloth top pinching on the driverside. The difference is that I don't have the plastic ball and socket, I have the metal ball and socket and it is in the correct place.
I took it to the dealer, and they spent a couple hours checking it, made sure I had the updated part, and in the end told me it was normal operation. As you can see from the picture, the fabric is pinching and I'm pretty sure I'll eventually get a tear in the cloth.
Just wondering if anybody else has this same problem with the metal ball and socket and if anybody else has found a fix. I know my dealer did everything they could and were told by corporate that there is no fix at this time.
Thanks,
Ryan
08-sky-pinching-convertible-top-p5220159.jpg  08-sky-pinching-convertible-top-p5220160.jpg
ryanmd is offline   Reply With Quote
Old 05-28-2008, 12:54 PM   #2 (permalink)
nomead's Avatar
Happens to me all the time...
nomead____________
2007 Graphite Redline
Manual, Black Leather & Top, Polished, XM/6CD+PAL, Opel GT Antenna; builtin V1;Ordered: 3/10/07 Delivered: 4/25/07
nomead is offline   Reply With Quote
Old 05-28-2008, 12:58 PM   #3 (permalink)
08BlueSky's Avatar
Where's the plastic / metal ball-n-socket located? - any additional photos? - just wondering... for my top seems fine, for now
08BlueSky is online now   Reply With Quote
Old 05-28-2008, 01:13 PM   #4 (permalink)
nomead's Avatar
I was thinking that all it needs is a thin piece of hard plastic about two inches by one sewn/glued to the fabric would fix this. Have not tried yet
nomead____________
Old 05-28-2008, 01:46 PM   #5 (permalink)
LANDSCAPE's Avatar
Same thing happens to me, I've just gotten in the habit of pulling it out before trying to tighten the latch inside, otherwise you have to pull pretty hard to get the buttress down.
Landscape
REDLINE #131984
Forest Green / Tan
N tires
Brake light pulse
V2 WR
Seat and Lumbar Mod
Polished SS IC pipes
Color match eng. cover
VDI Doors
Solo-Mach
Lil Chromies, Chrome Domes, Billet Grill
Dashhawk
Green Neon Underbody
LANDSCAPE is offline   Reply With Quote
Old 05-28-2008, 01:57 PM   #6 (permalink)
Bogie's Avatar
This seems to be a common problem and it is one of those quirks of the SKY that you will likely have to live with for a while...or forever.
The problem is whenever you have fabric covering a collapsable joint such that the fabric is in excees of the joint when collapsed, the fabric will either accordian, bend in, or bend out. The problem with the SKY top is the joint fabric can tend to bend in, which puts the fabric on the joint when the joint closes, grabbing the fabric. And yes, eventually it will rip it.
There is a relatively easy operational fix that works for me. When I grab the top to raise it, I take my right hand and sweep my fingers through the joint area and physically force the fabric away from the joint. I don't need to keep my fingers there and risk crushing them in the joint. Just sweep the fabric out, remove fingers, and raise the top. I do this religiously to the point I don't even think about doing it anymore, but just do it as my normal top raising routine.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Snagged 8/31/07
Belle? That's my car
Alizée? That's my avatar
Old 05-28-2008, 04:23 PM   #7 (permalink)
SSRL's Avatar
Happens to me after I had my top replaced.
Do or don't do, There is no try.
SSRL is offline   Reply With Quote
Old 05-28-2008, 05:24 PM   #8 (permalink)
Thanks for all the replies. I guess if it only does it on 1 side I can live with it. My biggest concern was that it would start doing it on the passenger side and I would have to walk around to the other side before latching it.
As for the ball and socket, you can only see it with the top down. Raise the top a little bit after closing it and look at the pieces inside (you'll have to get into the car and face towards the trunk). Mine has a metal ball and socket where others have reported a plastic piece in earlier years that can pop off causing the problem.
Old 05-28-2008, 05:27 PM   #9 (permalink)
G8TR's Avatar
My Photos: (3)
Same problm here, always on the driver's side. Just have to be careful when raising it. I watch it every time.
It's always fun when there's more than one!
G8TR is online now   Reply With Quote
Old 05-29-2008, 09:39 AM   #10 (permalink)
MidniteBlues's Avatar
Hmm, mine does not do that. Looks like it happens only to a few skys. In previous threads reported eventually it tears the fabric internally, thereby forcing you to replace the top. I think bogies way probably saves the thing.. Let me see if i can find that thread with the tear pics..
Yup, here's the thread.. Bent Metal and Torn Top
2.4L Midnight Blue, Premium Trim Package, Automatic, Monson Pre Audio 1-CD, Std Rear.
Opel Ant - WR V2
TODAY IS ANOTHER GOOD DAY, I WOKE UP ON THIS SIDE OF THE DIRT..
Old 05-29-2008, 09:57 AM   #11 (permalink)
Mickey's Avatar
if you read that thread justmike said the top was missing the tabs at the ends of the joints were the top catchs.
Pontiac builds excitement...
NASSOA
Founding Member
#1922 12/03/05
N/A Classic Solstice
Mysterious
MODS:GM CAI & CATBack
Mickey is offline   Reply With Quote
Old 07-08-2008, 10:26 AM   #12 (permalink)
saf0775's Avatar
My Photos: (10)
Send a message via MSN to saf0775
I've never seen a top do that. That looks awful! I'm surprised to hear it's such a common problem that people here have learned to "deal with it". There are multiple adjustments on the bow's and rods, more then enough to stop this from happening.
Stephen
Saturn Certified Technician
GM-ASEP Graduate, FCCJ class of 2003
Maria (139794) - 07, Auto, Monsoon, Stubbie
saf0775 is offline   Reply With Quote
Old 07-08-2008, 10:29 AM   #13 (permalink)
MRSSKY's Avatar
YEPPERS!! It happens to me also only drivers side, and I had my top replaced as well...I am really careful when I pull it up.
m.
MICHIGAN
Black Onyx, auto
BLK/RED Trim
am/fm cd/mp3 premium
18"Chrome
aka...(mrsviper)
ordered...may 2006
delivered..sept 2006
MRSSKY is online now   Reply With Quote
Old 07-08-2008, 10:31 AM   #14 (permalink)
MRSSKY's Avatar
Yes Sir thats what I do !!!
M.
MICHIGAN
Black Onyx, auto
BLK/RED Trim
18"Chrome
aka...(mrsviper)
ordered...may 2006
Old 07-08-2008, 05:42 PM   #15 (permalink)
Bogie's Avatar
Well saf, if you were my tech, I would let you do it. The problem is half the time someone goes in to have stuff like this adjusted, it either doesn't get fixed, gets partially fixed, or something else gets broken.
My top currently works great except for this one problem. I would rather live with this minor inconvenience than run the risk of a fix creating a major inconvenience.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Snagged 8/31/07
Old 07-08-2008, 07:25 PM   #16 (permalink)
Hmmmm.... I've never experienced this myself. I'd be upset if I saw this.
jus2shy is offline   Reply With Quote
Old 07-08-2008, 07:59 PM   #17 (permalink)
RMFNSKY's Avatar
My Photos: (23)
Been there doing that, I have had my service mgr note it on the service notice. I'll get a new top before the warranty runs out.
Sunburst Yellow
Ordered 4/5/06
Born 7/6/06
Oct 12th St Louis Fall Foliage Run
RMFNSKY is online now   Reply With Quote
Old 07-08-2008, 08:06 PM   #18 (permalink)
Sol-Candy's Avatar
Happens to me also in my Solstice ....on the drivers side...I know to get the wrinkle out before latching but it is a pain...did not happen with my '2006' at all... I am thinking about having it replaced.....
Out driving my Sol........
Sol-Candy is offline   Reply With Quote
Old 07-09-2008, 06:32 AM   #19 (permalink)
gadget's Avatar
That's just wrong! There's no way I would tolerate that. Sounds to me like alot of the Techs just don't know how to work on the tops.
'07 2.4 Liter
Polar White With Tan Trim
L.S. Differential
Dual Filter Fugita CAI
SMS BBTB, Vector tune
Old 07-09-2008, 08:03 AM   #20 (permalink)
SadyBlue's Avatar
I have the same problem on both sides. Glad to hear that it is not normal.
Is it possible for any GM dealership to do warranty work? Our nearest Saturn dealer is quite a drive and at this point the top is the only issue that I have and really don't want to take it in for just that one thing (knock on wood).
Kathy
'08 Midnight Blue
Black/Black
SadyBlue is offline   Reply With Quote
Old 07-09-2008, 08:27 AM   #21 (permalink)
SkyhighNY's Avatar
Send a message via AIM to SkyhighNY Send a message via Yahoo to SkyhighNY
I was told just the other day that our local Pontiac dealer will gladly work on the Saturns also. Apparently they service it under the warranty. Call your local dealer and see what they say.
Silver Lining = 2008 Saturn Sky Redline, Silver Pearl/Red, Manual
Black Cloud = 1995 Toyota Tacoma, Black/Grey, Manual
Originally Posted by RainbowintheSky View Post
I'm trying to do the best that I can with what he gives me to work with.
SkyhighNY is offline   Reply With Quote
Old 07-09-2008, 08:57 AM   #22 (permalink)
Bogie's Avatar
And what makes you think the broad range of Saturn Techs would know how to work on SKY
