Old 10-17-2005, 01:02 AM   #1 (permalink)
First 2000
2.4L ecotec
I put a depsoit down on a Sky about two weeks ago and plan to use it as a weekend car that I'll put very few miles on. I plan to keep my current car, a 1999 Saab 9-5 as my daily driver. I noticed that my Saab has a 2.4L eco tec turbo engine, which I assume is probably the same block? I dont have an aero edition so my engine only pushes 170hp but there is aftermarket pcm programing to get it to 230hp safley. My question is could I theoretically switch out the pistons for the sky with lower compression ones from my saab or another saab, use a Saab exhaust manifold with the turbo on there and pay to have some custom programing done and have a 230hp sky? I know there would probably be some more issues such as the sky is rear drive and the saab front so the exhaust manifolds might be very different in shape/size. It would probably as cost effective to wait for the redline but does anyone think this sounds pretty do-able?
werdnash2002 is offline   Reply With Quote
Old 10-17-2005, 01:09 AM   #2 (permalink)
First 2000
I was mistaken my saab actually has a 2.3L eco tec, is just a de stroked 2.4?
Old 10-17-2005, 03:22 AM   #3 (permalink)
Saab's are not Ecotec's. At least not that I know of. The 2.0 Turbo could be the same block as the 2.0 Super but the others are not on any US cars.
DuSpinnst is offline   Reply With Quote
Old 10-17-2005, 04:17 AM   #4 (permalink)
achieftain's Avatar
You would get better results from adding an after market turbo or S/C setup to the base Sky if the redline is not immediately available. Saab engine not the same.
The Sky's the limit!
achieftain is offline   Reply With Quote
Old 10-17-2005, 10:59 AM   #5 (permalink)
"2.4L eco tec turbo engine, which I assume is probably the same block? I dont have an aero edition so my engine only pushes 170hp "
Sounds like something's wrong here. A 2.4 that is turboed and only gets 170HP doesn't sound reasonable, since the non-turbo 2.4 Ecotec gets up to 177HP.
kingarthur is offline   Reply With Quote
Old 10-17-2005, 04:20 PM   #6 (permalink)
The 2.3L Saab engine in the 9-5 is not ecotec derrived. Only the 9-3 has an ecotec engine.
The 2.3L 9-5 engine, known as the "H engine" is a derrivative of the old Saab B engine and was originally introduced in 1981.
In 2003, the Epsilon based 9-3 switched to the GM ecotec engine.
So in other words, switching pistons is not likely going to help you out.
More Saab engine info here: http://en.wikipedia.org/wiki/Saab_H_engine#B235
Fformula88 is offline   Reply With Quote
Old 12-16-2005, 04:13 PM   #7 (permalink)
sol43621's Avatar
The Saab 9-3 runs a 2.0 turbocharged ecotec.
sol43621 is offline   Reply With Quote
Old 12-16-2005, 09:11 PM   #8 (permalink)
Yea, but the European ones. Opel and Saab seem to have a slightly different set of Engines than we do.
Old 02-26-2006, 10:56 AM   #9 (permalink)
Send a message via AIM to wakebord99
Ok, I'm by no means a Sabb expert. Yet, I was under the impression that the sabbs were built from Subaru platforms, and drivetrains..? Am I wrong?
wakebord99 is offline   Reply With Quote
Old 02-26-2006, 11:44 AM   #10 (permalink)
Only the 9-2x. It's based on the Subaru WRX.
reedred is offline   Reply With Quote
Old 02-26-2006, 05:32 PM   #11 (permalink)
Saab 9-3, 9-5 based on heavily modified versions of Epsilon (Vectra, Malibu, G6, Aura). Built in Sweden with Ecotec Engines from the Saab/Opel catalog.
Saab 9-2X is a Subaru Impreza (Base) and an Impreza WRX (Areo)
Saab 9-7X is a GMT-360 (TrailBlazer/Envoy)
Old 02-26-2006, 06:02 PM   #12 (permalink)
HAHA.. what is true and pure these days?? I mean even the Vette is shared with the XLR. WHAT HAS THIS WORLD COME TO
Hopefully will be a Sky Owner shortly...
Plan to Solo I & II this car regularly
99' Corvette Hardtop 6mt
01' Ford Taurus
91' Mercury Cougar
[/size]
