30 Gas Saving Tips....
HEY JUST THOUGHT I WOULD SHARE THIS... SOMEONE SENT IT TO ME THIS AM.... MOST OF IT IS ALREADY COMMON SENSE. I PERSONALLY CAN'T COMPLAIN BECAUSE BOTH OF MY PERSONAL CARS WHEN I BOUGHT THEM I KNEW ONLY COULD TAKE THE 93 SO OH WELL & I BOUGHT BOTH CARS TO DRIVE THE HECK OUT OF THEM!!!!
The surest way you can improve your fuel cost problem is to change your motoring habits. Listed below under four categories are 30 effective methods of doing so... no need to buy expensive add-on equipment. ENGINE WARM-UP 1. Avoid prolonged warming up of engine, even on cold mornings - 30 to 45 seconds is plenty of time. 2. Be sure the automatic choke is disengaged after engine warm up... chokes often get stuck, resulting in bad gas/air mixture. 3. Don't start and stop engine needlessly. Idling your engine for one minute consumes the gas amount equivalent to when you start the engine. 4. Avoid "revving" the engine, especially just before you switch the engine off; this wastes fuel needlessly and washes oil down from the inside cylinder walls, owing to loss of oil pressure. 5. Eliminate jack-rabbit starts. Accelerate slowly when starting from dead stop. Don't push pedal down more than 1/4 of the total foot travel. This allows carburetor to function at peak efficiency. HOW TO BUY GASOLINE 6. Buy gasoline during coolest time of day - early morning or late evening is best. During these times gasoline is densest. Keep in mind - gas pumps measure volumes of gasoline, not densities of fuel concentration. You are charged according to "volume of measurement". 7. Choose type and brand of gasoline carefully. Certain brands provide you with greater economy because of better quality. Use the brands which "seem" most beneficial. 8. Avoid filling gas tank to top. Overfilling results in sloshing over and out of tank. Never fill gas tank past the first "click" of fuel nozzle, if nozzle is automatic. HOW TO DRIVE ECONOMICALLY 9. Exceeding 40 mph forces your auto to overcome tremendous wind resistance. 10. Never exceed legal speed limit. Primarily they are set for your traveling safety, however better gas efficiency also occurs. Traveling at 55 mph gives you up to 21% better mileage when compared to former legal speed limits of 65 mph and 70 mph. 11. Traveling at fast rates in low gears can consume up to 45% more fuel than is needed. 12. Manual shift driven cars allow you to change to highest gear as soon as possible, thereby letting you save gas if you "nurse it along". However, if you cause the engine to "bog down", premature wearing of engine parts occurs. 13. Keep windows closed when traveling at highway speeds. Open windows cause air drag, reducing your mileage by 10%. 14. Drive steadily. Slowing down or speeding up wastes fuel. Also avoid tailgating - the driver in front of you is unpredictable. Not only is it unsafe, but if affects your economy, if he slows down unexpectedly. 15. Think ahead when approaching hills. If you accelerate, do it before you reach the hill, not while you're on it. GENERAL ADVICE 16. Do not rest left foot on floor board pedals while driving. The slightest pressure puts "mechanical drag" on components, wearing them down prematurely. This "dragging" also demands additional fuel usage. 17. Avoid rough roads whenever possible, because dirt or gravel rob you of up to 30% of your gas mileage. 18. Use alternate roads when safer, shorter, straighter. Compare traveling distance differences - remember that corners, curves and lane jumping requires extra gas. The shortest distance between two points is always straight. 19. Stoplights are usually timed for your motoring advantage. By traveling steadily at the legal speed limit you boost your chances of having the "green light" all the way. 20. Automatic transmissions should be allowed to cool down when your car is idling at a standstill, e.g. railroad crossings, long traffic lights, etc. Place gear into neutral position. This reduces transmission strain and allows transmission to cool. 21. Park car so that you can later begin to travel in forward gear; avoid reverse gear maneuvers to save gas. 22. Regular tune-ups ensure best economy; check owner's manual for recommended maintenance intervals. Special attention should be given to maintaining clean air filters... diminished air flow increases gas waste. 23. Inspect suspension and chassis parts for occasional misalignment. Bent wheels, axles, bad shocks, broken springs, etc. create engine drag and are unsafe at high traveling speeds. 24. Remove snow tires during good weather seasons; traveling on deep tire tread really robs fuel! 25. Inflate all tires to maximum limit. Each tire should be periodically spun, balanced and checked for out-of-round. When shopping for new tires, get large diameter tires for rear wheels. Radial designs are the recognized fuel-savers; check manufacturer's specifications for maximum tire pressures. 26. Remove vinyl tops - they cause air drag. Rough surfaces disturb otherwise smooth air flow around a car's body. Bear in mind when buying new cars that a fancy sun roof helps disturb smooth air flow (and mileage). 27. Auto air conditioners can reduce fuel economy by 10% to 20%. Heater fan, power windows and seats increase engine load; the more load on your engine, the less miles per gallon. 28. Remove excess weight from trunk or inside of car - extra tires, back seats, unnecessary heavy parts. Extra weight reduces mileage, especially when driving up inclines. 29. Car pools reduce travel monotony and gas expense - all riders chip in to help you buy. Conversation helps to keep the driver alert. Pooling also reduces traffic congestion, gives the driver easier maneuverability and greater "steady speed" economy. For best results, distribute passenger weight evenly throughout car. 30. During cold weather watch for icicles frozen to car frame. Up to 100 lbs. can be quickly accumulated! Unremoved snow and ice cause tremendous wind resistance. Warm water thrown on (or hosed on) will eliminate it fast. EXTRA TIPS Install pressure regulator valve (sold in auto parts stores)... Use graphite motor oil... Beware of oil additives, regardless of advertising claims... Add Marvel Mystery Oil into gas fill-ups... Investigate fuel/water injection methods and products... combine short errands into one trip... Use special gas additives to prevent winter freezing of gas lines!
*SINISTER* Onyx 3 Peds LSD Spoiler Splash Guards Sky Mats Tint 3rd Brake Sinister Stubby Saddle DC Sports Brace AEM Intake RL Exhaust |
#3 (permalink) |
Man artical that is ancient.
Who has a carb anymore? Choke? LOL! This may have been true to cars made about 20-30 years ago. Now we have Fuel Injection, lighter cars and better wind resistance. Get caught doing 55 on the highways today prepare to be run off the road by an 18 wheeler given you the deuce! ![]() I can supercruise at 80 in my RSX with the Supacharger and get 35 mpg in 6th and that is a modified car making 330 HP or crank HP 650 cc Injectors stock is 270 cc.
07 SKY Redline Silver Red/Black Leather, JPM Dash Red leather, WDE Carbon Fiber Dash Kit, BSR Tune, Fujita Intake, Dejon IC pipes, Hahn IC, 3" Magnaflow Quad Exhaust, DDM BBK (RED), BlackCatCustom Gauges. http://www.compdoc777.com/Carstuff/sky1.jpg Last edited by compdoc777 : 04-16-2008 at 01:43 PM. |
#5 (permalink) |
30 gas saving tips
KimberlySky is that you in your Avatar?
My personel advice: sell your Sky, use a bike... ![]() ...and you can save gallons of gas....
Opel GT 2.0 Turbo onyx black, leather red/black, 20" Tomason rims, Eibach pro springs, bsr, Windstop, Inox GT-Badges, Wategate/Solenoid mod |
#6 (permalink) |
Yes that is me and where's your picture hiding are we?
I was posting the info about the gas because so many people have been complaining and asking on how to save... I on the other hand don't care how much it costs to drive either one of my cars I knew with both of them it would be the 93 and the price of fuel was never a concern of mine.
#7 (permalink) | |
Location: Marietta, South Carolina and Guelph, ON Canada
BUT that is a great idea, we should all use other transportation sometimes, or car pool. Save our Sky gas for all the SKY/SOL fun weekend trips...... Great idea German gt.......
JOIN US FOR 2009 TAIL OF THE DRAGON There once was a Kappa named Chili Who loved the back roads that were hilly Afraid of no turn She made those hoops burn I tell you that girl is a dilly BY DRUID
#8 (permalink) | ||||||||
![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
![]() And they forgot the one about "drafting. If you get real close to the car in front, you can reduce your wind resistance to almost nothing and provide symbiotic support to the car in front. ![]()
#9 (permalink) | |||||||||||||||
wow
Some of those are unavoidable - if you live down a bumpy dirt road you really have no choice.
and some don't seem right to me - something that is considered common sense Quote:
#10 (permalink) |
Where did this come from Opra Winfrey?
Most newer fuel injected vehicles get the best gas mileage @ around 70mph Avoid backing up to save gas? Well only if you normally drive in reverse for several miles at a time. ![]() Drive at the speed limit to hit the lights green? In Denver YA RIGHT! Try 5 to 10mph over the speed limit.Hosing a car down with water when it's freezing around here to remove ice will get you a car shaped ice cube! Remove excess weight. In a Saturn Sky? Someone does need to drive the car! I might entertain removing the passenger seat but thats going to make it hard to carpool.
'07 2.4 Liter Polar White With Tan Trim L.S. Differential B&G Springs and Dampers,Eibach Stabilizers Dual Filter Fugita CAI SMS BBTB, Vector tune Monsoon Stereo,Six disk changer PDA and 350GB hardrive space for audio Last edited by gadget : 04-17-2008 at 08:26 AM. |
#11 (permalink) |
I died laughing when I actually read them.... someone actually sent it out as a HUGE forward to a ton of people!
#12 (permalink) |
John D's Ten Ways to Save Gas in your SKY
First:"BABY" Silver Pearl 9 May 06 Then:"SPIRIT" Black Onyx Red Line 25 Oct 06 Check out My Photos! Last edited by JohnD : 04-18-2008 at 03:12 PM. |
#15 (permalink) |
