Old 08-18-2007, 08:46 PM   #1 (permalink)
joker70's Avatar
3rd brake light
Ok I was curious does anyone have a step by step on how to remove the brake light and or is it hard I would like to find out before I get into it just in case its not what I am expecting thanks in advance
joker70 is offline   Reply With Quote
Old 08-18-2007, 09:52 PM   #2 (permalink)
xmicro_Redline's Avatar
I believe you need to take off the rear bumper. What are you trying to do??
Old 08-18-2007, 10:59 PM   #3 (permalink)
joker70's Avatar
pull the light out to change the leds
Old 08-18-2007, 11:08 PM   #4 (permalink)
YellowSky's Avatar
Send a message via AIM to YellowSky
change them to what?
Opel GT conversion
ONYX Black
ADD ON
RACE PRECISION EVERYTHING
opel badges and lights
Flurecent halos
SOL black rims
FIREFIGHTER Tag "SKYYY"
YellowSky is offline   Reply With Quote
Old 08-19-2007, 01:39 AM   #5 (permalink)
joker70's Avatar
auhh got you wanting more well I will only say this to a differant type of led
Old 08-19-2007, 04:43 AM   #6 (permalink)
Skip's Avatar
Remove your tag. remove the tag light two screws. Reach in and diconnect the third brake lite....Skip...after that I installed the pulser array...
Skip is online now   Reply With Quote
Old 08-19-2007, 09:20 AM   #7 (permalink)
jel
jel's Avatar
On mine the most difficult part was the limited access for movement up there. And on top of that, the clip is on top of the plug, not the bottom (on mine anyway). So I eventually wrapped a piece of coat hanger around one of my fingers and used that to lift the plug clip because it's about impossible to rotate your forearm to reach it.
JPM leather dash
Dual XDVD8285
Interior carbon fiber kit
Wind Restrictor V2
Fujita dual filter CAI
Kappasphere KS2/Li'l Chromies
Blackcat gauges
Billet grille
O-series stubby/FlameBall shifter
V doors
Sequential brake/3rd pulsating lights
Old 08-19-2007, 10:18 AM   #8 (permalink)
He wants to take out the whole light. Unless he has VERY thin hands and small tools, no way can he get the light out that way. He will have to remove the rear bumper.
Old 08-19-2007, 03:52 PM   #9 (permalink)
twirp is offline   Reply With Quote
Old 08-19-2007, 03:55 PM   #10 (permalink)
YellowSky's Avatar
Originally Posted by twirp View Post
I. The real *%^$# hard part is getting the adhesive that NASA should be using to hold heat tiles on the shuttle with. I
Brake Light Modification
CLASSIC
Opel GT conversion
ONYX Black
ADD ON
Flurecent halos
SOL black rims
Old 08-19-2007, 07:13 PM   #11 (permalink)
joker70's Avatar
I pulled the plate light off and then the wire for the light but it is not screwed on it has the pop out pins and the glue like you twirp I think the connecter is also glued through the plastic that the light sits in so I am not sure even if I were to wire the adhesive it will come out it may be harder than I was thinking so I have to change the whole plan around thanks for all the imput on this. Question! Twirp when you pulled the light out did you keep the old one and if so could you snap a pic of the back I would like to know if I can unsolder the leds and replace them with a differant kind.
