Adjusting the rear deck lid - Saturn Sky Forums: Saturn Sky Forum
Old 01-21-2013, 05:21 PM   #1 (permalink)
Sky_Pilot's Avatar
I've adjusted my deck lid up and down using the two adjusting (had to modify the passenger side) screws to ensure it's flush with the fender panels, but now I need to adjust it from side to side (not front to back). It actually has rubbed paint off the leading edge of the lid against the fender body panel. I don't see any visible adjustment points, so do I just loosen the 4 bolts that secure the lid to the hinges to adjust it or is there some other method to employ?
2008 Redline - Carpe Diem Incoronatus, Infantem!
10/30/07: Born
11/17/07: Adopted
07/05/12: GMR Lobotomy
07/06/12: Trifecta Tuned
DDM Xtreme BB
DDM Yellow Coil Cover
Dejon IC Pipes
MRZ Buttress Caps
HID Low/Fog & Pulsating Brake Lamp
Sky_Pilot is offline   Reply With Quote
Old 01-21-2013, 08:26 PM   #2 (permalink)
GS Stage 1's Avatar
You should find your answer here:
Solstice/SKY Body Adjustment PDF - Pontiac Solstice Forum
Sent from my DALEK MOBILE DEVICE using Exterminate.Com Free App
GS Stage 1 is offline   Reply With Quote
Old 01-22-2013, 12:07 AM   #3 (permalink)
Rob the Elder's Avatar
My Photos: (3)
The manual says open the trunk and push it to the side.
http://www.solsticeforum.com/forum/f62/punisher-65168/
http://www.skyroadster.com/forums/f2...cussion-42115/
Old 01-22-2013, 12:56 AM   #4 (permalink)
Sky_Pilot's Avatar
Yeah, no, that didn't work. I tried that yesterday after I dremelled the screw on the passenger down 1/8th of an inch to get it lower.
10/30/07: Born
11/17/07: Adopted
DDM Xtreme BB
Dejon IC Pipes
MRZ Buttress Caps
Old 01-22-2013, 10:48 AM   #5 (permalink)
gladmaker's Avatar
Originally Posted by GS Stage 1 View Post
Lots of good information here. I saved it where I could find it if needed.
Thanks!
2008 Bluestone Sky Redline
Venom Brace
Backbone Brace
Woodgrain interior
Diamond pattern console cover
gladmaker is offline   Reply With Quote
