Air Intake
Copied from the Saturn Web site ... listed as an option ($495) available for the Sky ...
"Air Intake Increasing cold air intake, this accessory improves the SKY's performance by allowing the engine to breathe more easily." What exactly does it do? increase power? improve fuel economy? or what? ![]()
Silver Pearl, Black Top, Black Leather, 1 disk Monsoon, Auto, LSD, KS Windscreen Love @ 1st sight 9-05 Imaged 3-8-06 Order Status 30 3-15 Order Status 38 4-5 Invoiced 4-26 At dealer 5-11 Picked Up 5-13 VIN #1240 Crashed 10-30 Returned 12 14 Last edited by bubbacc : 02-17-2006 at 04:12 PM. |
#2 (permalink) | |
2.4L Sky Midnight Blue Automatic VIN 0278 del 4/6/2006 CAI "A person, who is nice to you, but rude to a waiter, is not a nice person." |
#3 (permalink) |
I was actually going to post this thread earlier because this is a very nice option! I have an air intake on my 01 Toyota Solara and before I installed it my car had a very low sound to it but after installing it my car ran mush better and actually put out a nice deeper pitch when flooring it. I liek the way my car handled aftre getting the intake so now I will definitely get an intake for my SKY at some point. Now question is do I wait for Injen (very repitable air intake company) to make a model that fits the SKY and only pay tops $200-$250 or get the factory one? The are quite simple to install and I did it in minutes and I am not the best at car mechanics but when I go it, it was obvious how to install it. Also as a side note they say since it allows your engine to breathe better it also boosts you a couple to a few horsepower...so maybe with it teh car will be like 180hp. All I am saying is there was quite the noticable difference in my Toyota after the intake.
P.S. Here is just the beginning of many threads on should we get an exhaust too? Catback!? The mods will probably be endless in about a year's time... Last edited by tiger20005 : 02-16-2006 at 03:51 PM. |
#4 (permalink) |
On the solstice a CAI (Cold Air Intake) is good for an extra 10hp across the entire rpm range, meaning you will notice a difference when you hit the gas. Also it will change the pitch, some people like it, others don't, it's juat a personal thing. Lastly IF you drive it the same you will get better gas milage because the air will be slightly cooler, but mostly because of the fact that the air will flow straighter and quicker which means the VE (Volumetric Efficieny) of the engine will go up.
#5 (permalink) |
I've been looking at this one (I assume it would fit both Kappas) --> http://kappasphere.com/handler.cfm?c...nction=product
#7 (permalink) | |
Neil |
#8 (permalink) |
cold air intake
You may want to check with Saturn before putting in a CAI. Most CAI's void any warrenty on the engine. Reason is because the CAI puts the air filter down lower to the ground and can suck water into the engine. THAT IS A BAD THING! I have had one in my last two cars and it caused bad things to happen until they were removed. So before spending the money and putting one in I would check with Saturn and see if it voids their warrenty. Trust me even if you put it in and it fries the engine and you take it out....they still know. If you live in a desert though.... GO FOR IT!!
#9 (permalink) |
a CAI does NOT technically void any warranty.... if it causes something to fail the mfg can chose not tocover the affected part..... CAI don't typically suck in water unless submerged.... what happens on alot of cars is that the oil from the filter covers the MAF sensor in a film so the car doen't run right.... a little throttle body cleaner normally fixes it fine
#12 (permalink) |
Moderator Emeritus
I've read the 10+ hp increase as well. I would think that if Saturn is offering CAI then at least their version shouldn't void any Warranty. And of course you should have a Warranty from the manufacturer of the part if you go for an aftermarket part.
#13 (permalink) |
if you buy the car with it you get the full warranty, if you have adealer install it later you get the remaining warranty or 12 months 12000 miles on the part, might be 24 / 24k. If you buy it and intall it yourself you might be screwed, On some GM performance parts they offer a warranty for the part only if you install it, other itmes they offer no warranty. Also if you install it they could blame just about anything wrong with the engine on you not installing it right, even if you did.... so don't do it yourself unless you trust your dealership.
#14 (permalink) | |
2006 Solstice, Mysterious [sold] - Born Sept 8th, 2005 2007 Solstice GXP, Mean - Born Nov 17th, 2006 |
#15 (permalink) |
warrenty
I was told by my mitsubishi tech that if water would happen to get into the engine from the cai, the warrenty will be voided and I would have to pay for a whole new engine to be put in. He also said that the techs can tell if you take out the cai and put the stock back in. Basically because they know it was water that caused the engine to fry and there is only one way for water to get in it. It is true though that you have to go through quite a bit of water for this to happen. One problem I noticed is that if you live where you get a decent amount of snow, it really screws with filter because snow gets attached to it. As with anything you do to the car that can change performance, it is good to check with the dealer first. I know with my car, the first thing I am doing is putting the exhaust system they offer at www.Kappasphere.com on it. That will increase hp pretty well and give the sky a sweeet sound.
#16 (permalink) |
First 2000
I'll wait for the intakes to start being whored out by the aftermarket and ebay for 40 bucks.
I brought a new turbo 2 years ago that cost as much as that intake Dealers will say all sort of crap about warranties and the aftermarket. By law (Magnuson-Moss Warranty Act) they can't just void out your whole warranty. If a particular aftermarket part you put on CAUSES a related factory part to fail the dealer can not honor the warranty for that particular part IF they can prove your part is what caused the failure. However, since most consumers don't know this you sometimes have to fight for them to honor the law. |
#17 (permalink) | |
#18 (permalink) |
First 2000
A Cold Air Intake or CAI brings colder & denser air into the engine, thus increasing horsepower and torque. Usually the increase is anywhere between 8 – 15 WHP (Wheel Horse Power) depending on how the engine responds to bolt on modifications. You also need to consider the general design of the engine and its position within the engine bay, as the CAI becomes more or less effective depending on how far it can get away from the "heat" of the engine, plus the direct nature of the pipe going directly into the engine (vs. a pipe that twists and turns its way through the engine bay like you see in late model Honda Civics).
Some engines have a very restrictive air intake, so the CAI really does make a notable improvement. Most CAI are sold by aftermarket companies, and usually go from $100 - $200. Go on e-bay and you can see some “homemade” CAI’s that are about $80 and offer comparable performance but lack the visual WOW that a Injen or AEM CAI might have. Also, you will have a much more noticeable engine “roar” with a CAI, as you are usually replacing several plastic parts designed to “quiet” engine sounds with a straight metal pipe. However, there are several downsides to a CAI. The first being the risk of Hydrolock. Since CAI’s are near the front and bottom of the engine there is the risk that the air filter (or the opening where air is being sucked in for the engine) might become submerged in water via a puddle. This then results in water being sucked inside the engine and into the combustion chamber. Since water does not “compress”, this can cause the engine rods to snap, or the engine block itself to crack. From personal experience I can tell you that this is a REAL possibility. I equipped my car with an aftermarket CAI for over a year, enjoyed the performance it brought, but was shocked when I drove through a medium sized puddle and had my car suddenly die on me. I had snapped a rod, and I can tell you it was no fun paying the bill to have my car fixed. I now use a Short Ram Intake, which is the same as a CAI except it does not extend outside of the engine bay, which protects your engine from the risk of Hydrolock. It does not perform as well as a CAI as the air it sucks in is not as cold (as the filter never extends outside of the engine bay), so it only brings a 8 WHP gain. Now, as far as this relates to the Saturn Sky… is this a Factory option being offered by Saturn, or a local dealer? If the factory is offering this as an option then it would have to be covered under warranty, just as a Turbo in the Redline version would be covered under warranty. You would probably be protected if you Hydrolocked your car. Also, I can see Saturn charging $400 + for a CAI for several reasons. The first being that a $200 CAI from an aftermarket company would void the warranty… a $400 one right from GM would not. If we are talking about an option you can add onto the MSRP of the vehicle and then finance, then $400 sounds like a good deal. Pont number 2 is that the NA (Naturally Aspirated or Non-Turboed) Sky owners might want a performance boost so that they are not totally left in the dust by the Redline Turboed Sky’s… and a CAI might just be the type of mod most Sky owners would be willing to do if it was covered under the warranty. Remember that a CAI is a VERY EASY mod, especially compared with other NA mods (Exhaust, Headers, Cams, and so on. The only easier mod would be a racing chip), so it could be a relatively cheap way of boosting performance closer to the redline level. Last edited by lbsst14 : 02-18-2006 at 06:16 PM. |
#20 (permalink) | |
First 2000
An aftermarket intake does not void your warranty. Well unless of course you come in to your dealer with a hydrolocked motor and a soaking wet cold air intake.
I can't see it providing much more then a few horepower on a N/A 4 banger. The reviews for the pontiac's intake aren't so hot Quote:
#21 (permalink) |
I believe the price is a little high, $500 will go a very long way towards a extended warranty. What have some of the previous Saturn owners like Ernest paid for a extended warranty? I was quoted " about a grand" for 5 year 50K mile 100 deductable. Im sure K&N, MTI, & RK sport as well as others will be offering the same thing later at 1/2 the cost . I do recommend here in Texas if you buy one look for one that has a CARB # meaning it complies with all emission laws.As far as voiding the warranty, Saturn has to prove it was the modification that voids the warranty, they just can't point and say oh you changed your air filter, thats why you spun a bearing.
#22 (permalink) | |
