Old 04-11-2008, 02:03 PM   #1 (permalink)
redsky@night's Avatar
Battery Problem
I have recently brought my Sky out of storage from a long winter. My battery is completely dead. I have charged it several times and driven the car to ensure a good charge but it won't hold. has anyone else expereinced this.
redsky@night is offline   Reply With Quote
Old 04-11-2008, 11:05 PM   #2 (permalink)
harrower's Avatar
new battery per saturn
Just got our sky out of storage. Started it every two weeks in winter OK.
Secon d week out od storage, battery died. Couldn't charge over 11 volts with battery charger. Took to Saturn and had diff recall done and new battery installed. All is fine. Inner plastic fender must be removed to replace battery.
18 screws. Glad it was warranty.
Sky Redline Black-Black-Black
3 Peddle-18" Chrome
Magnaflow 3"
harrower is offline   Reply With Quote
Old 04-11-2008, 11:22 PM   #3 (permalink)
Skip's Avatar
It is easier to take off the right side fender. It is 4 screws and bingo there is the battery....Skip...
Skip is online now   Reply With Quote
Old 04-11-2008, 11:43 PM   #4 (permalink)
Bogie's Avatar
Once a lead acid starter battery gets below a certain charge level, it can rapidly deteriorate. The longer it stays low, the quicker it can deteriorate.
Although a fully charged battery will lose charge just standing there, it should not lose too much over a few weeks to put it in the rapid deterioration mode. Hence, a good charge every few weeks should keep it out of danger. But there are exceptions:
1. If it's connected, and there is a drain (called parasitic drain) from the various components connected to the electrical system, then it can reach the deterioration point much faster.
2. An alternator charge is not the most friendly charge type for low battery, as these batteries don't like to be charged fast. So it's possible to do "some" damage each time you let the battery go low and then jolt it back with an alternator charge.
So, what to do? As for (1), disconnect the battery when in storage. As for (2), use a battery charger that charges in a kinder gentler fashion. There are also charge systems that keep the battery constantly charged, which is probably the best way to keep the battery healthy.
It's hard to tell if a particular battery was simply poorly manufactured or if it was allowed to wither too long without having good info on the exact parameters involved....parasitic drain....and/or charge rate.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Belle? That's my car
Alizée? That's my avatar
Old 04-12-2008, 05:36 PM   #5 (permalink)
stromo's Avatar
i kept mine on a "battery tender junior" over the winter. $26. started right up in the spring.
2007 RL
Graphite / Black leather / magnaflow 3" quad
stromo is offline   Reply With Quote
Old 04-13-2008, 12:17 PM   #6 (permalink)
Get one of the green-knob disconnect switches and put it on the negative cable and when you want to leave it sit for a while ( several weeks or more) turn the knob and the battery is disconnected....most car places and flea markets sell them about $3.00 each, simple to install especially if you are already replacing the battery....just my $.02
pastohio is offline   Reply With Quote
Old 04-13-2008, 01:18 PM   #7 (permalink)
Bogie's Avatar
Now the engineer is curious as to what the parasitic discharge really is on our SKYs. Gone are the old days when once a car was "off", everything was really "off". Nowadays, with all our technical wonders, turning the car off doesn't stop the current flow:
1. Onstar runs for two days before shutting down (or so they say).
2. I suspect the computer control modules probably suck a little bit of juice.
3. And, of course, if the content theft is active it will be drawing current...if for no other reason than to operate the pretty blinking light.
4. Perhaps the temp sensor circuit also draws a bit since it operates when vehicle is off.
5. Remote keyless entry would draw some.
6. PassKey system might draw a bit?
7. Airbag?
I wonder what other electronic wonders we have that draw a wee bit of current...that on a day to day basis is minuscule, but on a month to month basis is significant? It would be interesting to get the specs on all those devices and add everything up, and see how long it takes to draw out a starter battery.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Old 04-13-2008, 05:06 PM   #8 (permalink)
darrylba's Avatar
Send a message via Yahoo to darrylba
A Different Battery?
Has anyone just replaced the factory battery with an aftermarket battery. If so, what kind is recommended. The factory battery certainly does not hold a charge very long.
darrylba is offline   Reply With Quote
Old 04-14-2008, 09:44 AM   #9 (permalink)
General input I have from other boards as well, do NOT buy the expensive Optima, it doesn't last any longer and will die like any other battery, buy one from NAPA or Sears that has a 3 year replacement warranty, put a disconnect on the battery if it sits for a month or so, and not worry for about 70-80 dollars, get the battery with the replacement warranty....my $.02
Old 04-14-2008, 11:35 PM   #10 (permalink)
darrylba's Avatar
Oh!
What size and model.
Old 04-15-2008, 08:03 AM   #11 (permalink)
gadget's Avatar
The Sears Diehard is a good battery.Auto Zone sells the same battery under they're brand for less.I think it's Duralast.
When I replace one I usually get the Optima though. You are right that they don't last any longer but you don't ever have to worry about corrosion or having it make a mess under the hood.I'm willing to pay the xtra $20 for that and the red top battery has 36 month replacement and then another 36 months Prorated warranty.
I tried the Exide version of the Optima because some salesman said it was just as good. Boy was that a mistake I went through three of them before the warranty ran out and it didn't have near the ability to crank the engine.
'07 2.4 Liter
Polar White With Tan Trim
L.S. Differential
Dual Filter Fugita CAI
SMS BBTB, Vector tune
Old 04-15-2008, 12:35 PM   #12 (permalink)
Mine would'nt start if the car sat unused for 4 or 5 days. Saturn insisted the battery was fine. It was not. One of the cells was defective, If you drove the car everyday there was enough juice to get her running. If she sat for awhile the volt level dropped enough to prevent the engine from even turning over-totally dead. It took me 3 trips to the dealer to get them to acnowledge the fact that the battery was defective. Interesting group,these servive people. They charge buckets full of money for their services and I as a consumer have to diagnose my own problems and then convince them on the proper cure. Love em.
swieck is offline   Reply With Quote
Old 04-15-2008, 12:39 PM   #13 (permalink)
the car is in today, it is getting a new battery (at least it better) as well I am getting the rear seals fixed for the recall. I will let you know what they have to say
Old 04-15-2008, 02:58 PM   #14 (permalink)
So in typical fashion I had not yet heard back from the dealership so I call. It turns out that the battery was defective and they have replaced it udner warranty. Good news. As for the recall for the seals, they told me that they have now ordered the parts and I will have to come back in three to four weeks. ahhhh
Old 04-15-2008, 04:23 PM   #15 (permalink)
southphillylakes's Avatar
Has anyone use the battery jumper's that plugs into the lighter outlet ? I have a couple of battery jumpers that clamp on the battery for a hot shot, they worked well with my other cars, but I as thinking about getting a smaller lighter/outlet jumper for the SKY.
Southphillylakes
Drexel Hill Pa
95 Saturn
2000 Saturn
1976 Corvette
Deposit Dec 30 05
Ordered April 1 06
Drove it home May 31 06
VIN 2924
Sunburst Yellow
Premium Trim package
Chrome Wheels-cancel wheels-to get car
6 Cd
southphillylakes is offline   Reply With Quote
Old 04-15-2008, 05:11 PM   #16 (permalink)
Bogie's Avatar
I have one of these:
Duracell: Portable Power
A nice investment:
1. Easy for maintaining air in tires.
2. Can jump start car.
3. Great for basic use during power outages.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Old 04-16-2008, 03:04 AM   #17 (permalink)
Morfious's Avatar
I have used Optima batteries for years and have not had a problem with them. THey are deep cycle batteries and will react to repeated discharge better than the factory battery did. My Red top Optima (in my Jeep) came with a 3 year replacement warranty, which was honored and replaced. YMMV, but I have not had issues with the optima battery.
Mean GXP Delivered 1/30/2007 $MSRP +$2K
My Stereo Install--> Ultimate Pioneer Avic D3 Install Thread
Mods:
Solo-Performance Street Race exhaust
Debadged
JPM interior & shifter
O.Z. Ultraleggera
DDM Works Big Brake Kit
Dunlop DZ 101
Morfious is offline   Reply With Quote
Old 04-16-2008, 08:32 AM   #18 (permalink)
gadget's Avatar
I have used Optima batterys for around 15 years.
I presently have three Optima battery's Two yellow top commercial battery's in my truck because it has a winch and a lot of other electrical and one redtop in the other car.
Optima has always honored the warranty which is as good or better than any other battery.
As long as they are charged properly they will give excellent service.
'07 2.4 Liter
L.S. Differential
Old 04-16-2008, 12:04 PM   #19 (permalink)
What is the cost of the Optima, about $140 or so ??!! I have heard many people that they are continually using the Optima warranty, could it be that they don't last as long and the added cost you are paying is a form of "insurance" for the many they have to replace ?? The Sears Gold with the full warranty is about $80, and the best charger is one that maintains the battery and has some type of chip in it that senses charging when needed....I believe that if the car sits for a month or more, I just turn the knob on my battery disconnect, the battery sits quietly for the month and ready for me to turn the knob when I want to go....thanks
Old 04-16-2008, 11:01 PM   #20 (permalink)
gadget's Avatar
the sears gold is $99 for 700 cold cranking amps.3yr free replacement. 100 months prorated
The Optima Red top is going for $149 900 for cold cranking amps.6yr free replacement 88 month prorated. But Optima batteries don't leak acid.
The only battery that Sears makes thats in the same class as the Optima is the diehard platinum which is $189. 880 cold cranking amps. four year free replacement.100 month prorated. No leaks
Duralast gold (Autozone) Same battery as sears diehard gold (Different label). 3yr free replacement five years prorated $79.
'07 2.4 Liter
L.S. Differential
Old 04-17-2008, 09:16 AM   #21 (permalink)
OK, two questions for you: Where inline do you have your disconnect? And does it totally remove power from all circuits? Does this mean that you lose radio presets? Where did you get the disconnect? OK, that was four!
Thanks for your input.
Clif
Remember, Freedom is NOT FREE
2007 Bluestone
Li'l Chromies
Avic-Z2
RPI GT Exhaust with RPI cat downpipe
RPI IC
DDM Works 4 piston calipers
Kappasphere KSR disks
Opel GT antenna
clif is offline   Reply With Quote
Old 04-17-2008, 11:01 AM   #22 (permalink)
Some auto stores, car swap meets, flea markets and try searching on line ( when I get a chance I will search the internet and post here ), should be mounted on the negative terminal by removing the negative terminal and putting the green-knobbed disconnect on the battery first and then putting the terminal that you removed , put onto the disconnect thing,you can also remove the green knob completely and it acts as a simple protection that no one can easily start your car and drive away , and when I use it, the radio presets did not get lost when I disconnected,
About the batteries, the problem with Optima is they aren't sold everywhere but if you buy at a Sears or Auto Zone, you have more places to return it to....just my $.02, these cars don't need too muc
