Old 05-30-2007, 11:27 AM   #1 (permalink)
Clogged Catalytic Converter
So I got a check engine light yesterday -- called OnStar to run a vehicle diagnostics (I love OnStar) and they said there was some sort of emissions error on the powertrain.
I took it in to Saturn today and they said that the catalytic converter is clogged and they are overnighting a new one to replace it.
Any ideas how this happened? Anyone else have it happen on their Sky? Is there anything else I should have looked at because of this? Any info would be appreciated.
USFJoseph is offline   Reply With Quote
Old 05-30-2007, 12:12 PM   #2 (permalink)
SunburstSky's Avatar
No worries, Had mine replaced too. At least your dealer isnt messing with it and replacing it on the 1st go around I went in 3 times.
Sunburst Yellow
The Dream Continues ...
SunburstSky is offline   Reply With Quote
Old 05-30-2007, 12:22 PM   #3 (permalink)
Converters usually fail due to excessively rich mixtures or longer term misfires. They burn out due to the heat of fuel burning in the converter. It takes a richer mixture to make the converter work, but too rich and you kill the converter.
Old 05-31-2007, 07:18 AM   #4 (permalink)
MISky's Avatar
Mine is being replaced today for the second time in six months. They don't seem to have a clue what's causing it. I'm not much of a mechanic, but it seems to me the converter is just a symptom of another problem, not the real cause. Thank god for the 100K mile warranty.
MISky is offline   Reply With Quote
Old 05-31-2007, 11:11 AM   #5 (permalink)
RPIpower's Avatar
What kind of gas are you guys using? What type of plugs?
Eloy
"Brutus" #001 RPi 2.4GTS
Race Precision, Inc.
7029 Marcelle Street
Paramount, CA 90723
562-630-5966
www.raceprecision.com
RPIpower is offline   Reply With Quote
Old 05-31-2007, 12:36 PM   #6 (permalink)
MISky's Avatar
93 Octane and stock plugs
Old 05-31-2007, 09:56 PM   #7 (permalink)
coopcj7's Avatar
had mine replaced at 10100 smiles. It kept throwing a rich code. it took them 3 times coming in before they replaced it. I haven't had a code and turning over 30000 smiles now
Chili Pepper Red
#3060
Black Top
Black Leather
Upgraded LSD
6 Disc Monsoon
Flowmaster Dual Exhuast
Redline Gauges
GMPP CAI
Bullet Door Locks
Old 06-01-2007, 01:33 PM   #8 (permalink)
RPIpower's Avatar
Somethings got to be wrong if your cats are going bad. The cats are tested and should last 100k miles before they even become a production item. If any of you have access to a wide band or something, I would monitor that for a while and see if you are running too rich, etc.
Eloy
Paramount, CA 90723
562-630-5966
Old 06-03-2007, 11:53 PM   #9 (permalink)
MISky's Avatar
I asked if they thought it was running rich after both replacements and they said no each time. How would I find out if it is and what could be done to correct it.
Silver Pearl/Red Leather/Auto/Loaded
Deposit 5/01/06
Delivered 7/10/06
Old 06-04-2007, 11:14 AM   #10 (permalink)
MidniteBlues's Avatar
Would a DashHawk work for this? And if not, what tool do you recommend that we can hook up to monitor this??
TODAY IS ANOTHER GOOD DAY, I WOKE UP ON THIS SIDE OF THE DIRT..
Old 06-04-2007, 12:51 PM   #11 (permalink)
RPIpower's Avatar
The Dashawk wouldnt work because its still reading from your factory narrowband sensors. You would need a wideband to see what the actualy AFRs are. Are you getting any misfires? The misfires would kill the cats faster than running too rich.
Eloy
Paramount, CA 90723
562-630-5966
Old 06-04-2007, 12:56 PM   #12 (permalink)
HotRedRoadster's Avatar
My cat went bad also...I had it replaced 1 week ago....Maybe bad cats??
2.4 Hahn Stage II (Hahn's Tune Sucks for 91 gas), 19' Kappasphere Wheels, Eibach Lowering Springs & RK Body Kit.
Placed Deposit: 2/17/06
Shipped: 7-5-06
Arrived: 8-2-06
Vin: 3371
HotRedRoadster is offline   Reply With Quote
Old 06-04-2007, 02:56 PM   #13 (permalink)
The Dashawk wouldn't work because its still reading from your factory narrow band sensors. You would need a wide band to see what the actually AFRs are. Are you getting any misfires? The misfires would kill the cats faster than running too rich.
Thanks for your reply Eloy, no I have been fortunate all around so far with my sky. (knock on particle board) I understand what you mean when we are talking wide/narrow bands. Is there a device the public can buy for this? Or is it a special item only dealers and facilities like yours can only buy? If I may ask, what do you use? Can I then assume that the dash hawk is strictly a narrow band device? not upgradeable?
Also, do you know if it is only 2.4L that are failing, or does that include R/L's. What have you seen? Also, as a possibly for causing CAT failures, would people running on regular fuel, or fuel less than premium perhaps contributing to these failures? I use strictly premium, so to date no problem of any kind with my mechanics--
Old 06-04-2007, 07:32 PM   #14 (permalink)
RPIpower's Avatar
I asked our main tech here and he thinks the cats could be failing due to misfires. I know a few people who have had CELs due to misfire. I got it a couple of times also.
Maybe 10 years ago, wideband 02 controllers were VERY expensive. With new technology, etc. its failry inexpensive to have a good one installed. I use the AEM UEGO which is only a couple of hundred bucks on my car and customers cars. If you dont want to go that route, you can always go to a shop that has an eddy current dyno and have them monitor your afr under different loads. That should cost you about $100.
Eloy
Paramount, CA 90723
562-630-5966
Old 07-04-2007, 12:53 AM   #15 (permalink)
First 2000
just took mine in yeah the onstar guy can check it in just a few minutes, thas freaking awesome, i also have a laptop connected to the edu and a program got it from sears and it works great.
well anyway i usually drivehard and fast around 80-90 mph on the highways, yesterday i was up around 80 and wanted to pass this car and all of a sudden knocking slightly and then the power went slowed to around 70 and tried to take it back up and nothing. took it in and they said it was the converter. i told them my car was backfiring a little in 2nd gear and they said it was running to lean, but i thought if its backfiring it means it running to rich.
lawdog6153 is offline   Reply With Quote
Old 07-04-2007, 08:28 AM   #16 (permalink)
SkyHi07's Avatar
My Photos: (11)
Send a message via AIM to SkyHi07 Send a message via MSN to SkyHi07 Send a message via Yahoo to SkyHi07
Is this only happening on Red Lines?
SKY 5/15/06 VIN 1971 "BlackSky"
SKY RL 2/1/07 "Wheezie"
SkyHi07 is offline   Reply With Quote
Old 07-04-2007, 12:43 PM   #17 (permalink)
Please post if R/L or CLASSIC
Old 07-04-2007, 01:04 PM   #18 (permalink)
Huh?? What the hell is that? Do you mean the 2.4L or the Sky? Who started this classless crap anywho?
Old 07-05-2007, 10:41 PM   #19 (permalink)
bradsky's Avatar
Send a message via AIM to bradsky Send a message via Yahoo to bradsky
N/A for Naturally Aspirated 2.4L
or
Classic
or
Base...
....any others?
**Just loving the sister car. Solstice GXP in the garage.
bradsky is offline   Reply With Quote
Old 07-06-2007, 02:01 PM   #20 (permalink)
It's not a classic, nor a base, it is a SKY!!! or 2.4L or NA, those I understand, that other crap is unknown to me--
