Driver side power window won't go down - Saturn Sky Forums: Saturn Sky Forum
post #1 of 12 (permalink) Old 07-19-2011, 11:02 PM Thread Starter
Fuses? Wiring? Glad its up and not down.
otterear
Seattle,WA
2007 Sky Bluestone
01.11.2011
otterear is offline
post #2 of 12 (permalink) Old 07-19-2011, 11:33 PM
Gordon shamway's Avatar
Quoted: 9 Post(s)
<otterear
This trouble have many reason I guess.
Switch, motore, Wire reel (roller made by Resin. if brake the roller when moter cannot move wire)
You should check the indside door opent door panel.
2008 RL turbo 5SP
LED tail system
HID head and fog lamp
OPEL GT dual horn
Gordon shamway is offline
post #3 of 12 (permalink) Old 07-20-2011, 09:46 AM
Check fuses FIRST. You have a set in the passenger floor board, and another under the hood on the right side above the turbo.
If the fuses are good, then it could be a window switch. I ran into the same issue with my Sky. Sometimes it'd work, others it wouldn't. The fix shouldn't be too expensive if you DIY. I was desperate to get the car back to working condition so I got it fixed by the dealer for a couple hundred bucks.
2008 Infiniti G37S Coupe 6MT - 58k - Megan Axle Back
2007 Sky Red Line 5-Speed - 79k - Light mods
2006 Saturn Vue 5-Speed - 103.4k
Koobie is offline
post #4 of 12 (permalink) Old 07-20-2011, 10:07 AM
Quoted: 9 Post(s)
I have one question, you said "Driver side power window won't go down"
how about passenger side ? If you can move passenger side window, I guess fuse will not brake down. Koobie opinion "check power window switch" ya, When the door is opened, the power window switch is exposed to rain.
2008 RL turbo 5SP
LED tail system
OPEL GT dual horn
post #5 of 12 (permalink) Old 07-20-2011, 12:51 PM
Quoted: 167 Post(s)
If it IS the switch, here's some photos showing the innards (and how to get them out): Mod: How to add fully automatic Up & Down to your power windows! - Pontiac Solstice Forum
The grey thing is the driver-side switch, and uses the black relay to actually operate the motor because of the included auto-down circuit. My bet would be the relay is bad.
The other black thing with the 6 'pins' on top is the passenger switch and that one operates the motor directly (no relay, no auto-down).
TomatoSoup is offline
post #6 of 12 (permalink) Old 07-20-2011, 12:56 PM
08BlueSky's Avatar
Quoted: 2 Post(s)
Hereís a print of the circuit (canít speak of its origin nor accuracy) Ö And something odd happened when I printed it from Adobe so I filled it in by hand - if it helps any.
Pwr Windows.PDF
08BlueSky is offline
post #7 of 12 (permalink) Old 07-20-2011, 04:12 PM
dffr1's Avatar
Attachment 41029
My recommendation is: if the pass side works then the fuse is good, appears to be common...
Next I would check for a short when the down button is depressed between, C + D wires, Dark Green and Tan - if you have a meter. You can also check the pass side's switch to confirm - checking A + D, also dark green and tan.
Before you do the next step lets wait for someone else to approve:
If all else fails short drivers side C + D wires and see if the window goes down, if it does then the switch is bad - most probable cause....
'72 Nova
'81 RS Camaro
'84 TransAm
'86 Grand National
'08 Sky 2.4
dffr1 is offline
post #8 of 12 (permalink) Old 07-20-2011, 04:42 PM
Quoted: 167 Post(s)
This is actually a great idea to test it out. Unfortunately the steps are wrong since you have to short two sets of wires to operate the motor, plus "D" is the passenger side
The following pic show the connector, wires and colors (verified for both my Solstice and two other Skys). Just look at the connector and the wires directly attached (the other spliced wires and breaks are for my auto up/down mod, so ignore them). To test as dffr1 suggests you'd have to short BOTH G->C and H->F to get the window to go down. Then G->F and H->C to get it up again (or vice versa).
post #9 of 12 (permalink) Old 07-20-2011, 04:55 PM
dffr1's Avatar
[ Unfortunately the steps are wrong since you have to short two sets of wires to operate the motor, plus "D" is the passenger side
I guess that you are saying that the first schematic is wrong, it shows
D and H as common to both motors, which would be odd to do ?
'72 Nova
'81 RS Camaro
'84 TransAm
'86 Grand National
'08 Sky 2.4
dffr1 is offline
post #10 of 12 (permalink) Old 07-20-2011, 05:18 PM
Have you tried a bigger hammer to persuade it to move?
I work on lots of things. I've got a collection of different hammer sizes. ;o)
JimElvis is offline
post #11 of 12 (permalink) Old 07-21-2011, 12:06 AM
Quoted: 167 Post(s)
It is wrong, yes, but only in that the written-in "H" should actually be an "A". "D" is shown correctly, as only going to the passenger window.
post #12 of 12 (permalink) Old 07-21-2011, 09:21 AM
08BlueSky's Avatar
Quoted: 2 Post(s)
Sorry, my eyes & handwriting are going bad
thanks for the clarifications soup!
Human Verification
