Old 05-02-2008, 09:43 PM   #1 (permalink)
3xHounds's Avatar
GM Bulletin # 08153 For Brake Symptoms
Took a road trip from just north of Nashville to Pensacola and back this week. This morning on the way back as I crossed back into TN I got a ck engine light. I pulled into the rest area and called ONSTAR to perform diagnostics. They told me that it appeared to be an emisions problem, but nothing serious and to go to the dealer at my convienience.
I went straight to the dealer, and they said that the code was P013A, O2 sensor too rich. Ulitmately cleared but here is where the brakes come in.
While waiting the service advisor came out and told me that they wanted to make the GM recomended repair for our brake issue. I was told that they were going to change the programing to increase the brake vacum.
Has anyone else had this done? I will post my observations after I have driven her for awhile.
A thousand miles this week with most of it top down was most excellent!
2008 Suburst Yellow RL
3xHounds is offline   Reply With Quote
Old 05-03-2008, 12:08 AM   #2 (permalink)
jonahgirl's Avatar
Send a message via AIM to jonahgirl
So glad you posted this. Had my Sky two days and have the brake problem of low vacum at startup. Almost hit the boat backing out of the garage to discover no brakes.
jonahgirl is offline   Reply With Quote
Old 05-03-2008, 12:22 AM   #3 (permalink)
3xHounds's Avatar
jonagirl,
I wait until the car idles down, about 30 seconds to a minute and I have enough vacum presure. If I try to move before that I have "crunchy" feeling brakes. I know the feeling of almost hiting the boat in the basement.
Old 05-03-2008, 03:56 AM   #4 (permalink)
Bogie's Avatar
Interesting comment. I thought the programming dealt with the Optimized Hydraulic Brake (OHB) function, not the vacuum. I find it hard to believe there is any "programming" that can increase the vacuum. Vacuum is pulled from the manifold. There is no place in the manifold to squirt in bits and bytes...and even if you could, they don't create vacuum. The possible exception is programming that runs the engine higher on first start and then quickly retards the throttle, which might build vacuum more quickly in manifold and subsequently in the brake vacuum cylinder.
The OHB is computer driven...so bits and bytes could make more direct difference at that point.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Belle? That's my car
Alizée? That's my avatar
Old 05-03-2008, 03:57 AM   #5 (permalink)
Bogie's Avatar
Welcome jonahgirl.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Old 05-03-2008, 09:06 AM   #6 (permalink)
darrylba's Avatar
Send a message via Yahoo to darrylba
Oh Whoa
Wow! Who is this chic, BOGIE! For President!
darrylba is offline   Reply With Quote
Old 05-03-2008, 09:18 AM   #7 (permalink)
WishfulThinking's Avatar
...The possible exception is programming that runs the engine higher on first start and then quickly retards the throttle,...
I had a similar thought. Of course you can't completely rule out that they're just not mentioning the "install the pump" part. (Someone reported reprogramming being involved with the pump installation also, if I remember correctly.) It will be interesting to hear more details after the updates are made.
At the very least, it's good to hear that a dealer is taking action on this before being asked to.
Old 05-03-2008, 09:30 AM   #8 (permalink)
Emergency? Grab your hand brake! Spoken like a true 2.4 driver!
puggsleyssky is offline   Reply With Quote
Old 05-03-2008, 09:34 AM   #9 (permalink)
jonahgirl's Avatar
That's what I did! Freaked me out....a little disappointing in a new car though Had my Z4 for nearly four years and only took it in for oil change.
As long as I have brakes AFTER the warm up period I can handle the issue. I read where some lose it after cruise control too....scary
Old 05-03-2008, 10:12 AM   #10 (permalink)
sidejam's Avatar
I just had a new OS installed on the ECU. I'll see this morning if it makes any difference with the brakes. Usually I let the car idle for a bit before I move it. But, today I'll start it then go right away to see how it is.
I'll let you guys know later today.
sidejam is offline   Reply With Quote
Old 05-03-2008, 11:27 AM   #11 (permalink)
Celt03's Avatar
Anybody got a way to post a copy of this bulletin ?
www.imsaturn.com/profile/Celt
Old 05-03-2008, 02:17 PM   #12 (permalink)
BlueSkyRL's Avatar
quote "OS"...Operating System?? If that's what they told you then they don't know what they are doing
Midnight Blue RL - Automatic
Rust proofed & Undercoated
Third brake light decal
Opel Gt antenna
3" Magnaflow exhaust
CTI hard pipes
Dejon Intercooler
Old 05-03-2008, 05:44 PM   #13 (permalink)
mbeardsley's Avatar
Yes, the ECM now runs this OS...
2008 Red/Red/Redline
Auto, Single Monsoon, Spoiler
Deposit Placed 05/26/07
Built 07/20/07
Delivered 08/07/07
mbeardsley is offline   Reply With Quote
Old 05-04-2008, 10:33 AM   #14 (permalink)
sidejam's Avatar
Believe it or not, this new OS does seem to improve the braking on initial engine start up. It's not absolutely perfect, but it definitely made a very noticeable difference.
Old 05-04-2008, 02:12 PM   #15 (permalink)
Bogie's Avatar
A 44 year old DOM with a 23 year old French chick for his avatar.
No....wait...in certain circles that is a perfect pre-requisite for President.
Seriously, I am only interested in her VOICE.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Old 05-06-2008, 10:42 PM   #16 (permalink)
SCVanguard's Avatar
I had this done before the actual bulletin came out when they needed to fix my wastegate solenoid...but it didn't make any difference at all in my RL.
Maybe I should go back now that they have a real bulletin about it...
Brad
2008 Sky Redline
Chili Pepper Red
18" chrome
Monsoon
Stubby
Old 05-13-2008, 09:56 PM   #17 (permalink)
3xHounds's Avatar
Cold start RPM varies between 1,300-1,500. This "fix" did absolutely nothing, it may be worse.
Old 05-13-2008, 11:13 PM   #18 (permalink)
Bogie's Avatar
The engineer in my is really wondering what they think the problem is, and what they are doing to fix it. They really should get three of us together:
1. Someone who says "no problem".
2. Someone who says "problem sometimes".
3. Someone who says "big problem".
Diagnostic the three, and have a go.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
