Old 06-28-2008, 02:35 AM   #1 (permalink)
GeniusInABottle's Avatar
My Photos: (3)
Having problems starting car when adding fuel
My Sky Redline has been having a rather odd problem for the passed couple of months now, and the techs at 2 different dealerships haven't been able to fix it.
It seems that whenever I add gas, the start immediately after takes an extended period of time. Sometimes it's about 10 seconds, sometimes more. The car will eventually start, and every start after that is fine until I add more fuel so it's definitely related to adding fuel.
Also, it does this with or without the BSR tune, so it's not that.
Help!
2008 Saturn Sky Redline | BSR Stage 1 Tune, RPi Stage 2 IC, GMPP Air Intake, GM Turbo Cat-Back Exhaust, Eibach Pro-Kit Springs, Konig Again 5 Wheels, 245/45 Goodyear Eagle F1 GS-D3 Tires
GeniusInABottle is offline   Reply With Quote
Old 06-28-2008, 03:28 AM   #2 (permalink)
Bogie's Avatar
The next time you fill up, don't start your car straight away.
1. Engage the ignition key to the accessory position.
2. Cycle through you DIC and note whether or not the display showing miles left has been updated.
3. Leave the car in accessory position for about 30 seconds.
4. Turn key to off and remove key.
5. Wait until the interior lights go off.
6. Now try and start the car normally and report back.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Belle? That's my car
Alizée? That's my avatar
Old 06-28-2008, 01:25 PM   #3 (permalink)
LANDSCAPE's Avatar
Are you "topping off" the tank?
If you try to squeeze a little more into it after the pump automatically shut off, you may be getting fuel into the emission system through the vent / vapor tank (charcoal box to keep fumes from polluting the air)
But then, I might be totally wrong.
Landscape
REDLINE #131984
Forest Green / Tan
N tires
Brake light pulse
V2 WR
Seat and Lumbar Mod
Polished SS IC pipes
Color match eng. cover
VDI Doors
Solo-Mach
Lil Chromies, Chrome Domes, Billet Grill
Dashhawk
Green Neon Underbody
LANDSCAPE is offline   Reply With Quote
Old 06-28-2008, 01:28 PM   #4 (permalink)
My Photos: (3)
Thanks Bogie, will do.
Old 06-28-2008, 01:29 PM   #5 (permalink)
My Photos: (3)
I've had this suggested before. This happens both when I fill up completely, and when adding only minimal amounts of gas, so I don't think that's it.
Old 06-28-2008, 03:32 PM   #6 (permalink)
My Photos: (3)
Bogie,
I did what you suggested. The miles left number was indeed updated upon adding fuel, and after doing the steps in the order you listed the behavior was the same.
Old 06-28-2008, 07:12 PM   #7 (permalink)
Send a message via AIM to Mandi
There is a bulletin out that takes about the terminals in the UBEC....inspecting for bent terminals and replace two connectors.....would think they would of chek or done this....what has Saturn done for this concern?
-2007 Saturn Sky Redline M/T
#03989, Built 6/30/6
Mandi is offline   Reply With Quote
Old 06-28-2008, 08:57 PM   #8 (permalink)
gadget's Avatar
Have any of the dealerships pulled the fuel pump out of the gas tank. Sounds kind of like you may have gotten a bad tank of gas.
'07 2.4 Liter
Polar White With Tan Trim
L.S. Differential
Dual Filter Fugita CAI
SMS BBTB, Vector tune
Old 06-28-2008, 10:19 PM   #9 (permalink)
WishfulThinking's Avatar
Just out of curiosity, it might be interesting to try just removing the gas cap and putting it back on, and see if the gives you the same problem. I believe they normally operate with some vacuum in the tank. It might not like having that vented (although I'm not sure what that would point to as the problem).
Old 06-29-2008, 12:07 AM   #10 (permalink)
Bogie's Avatar
I would say they should look at the fuel pump, but not necessarily because of bad gas. The symptom occurs after each fill up. Something may be happening on fillup that disturbs the pump in some way so that it's not feeding properly, or is triggering a sensor message to that effect.
I have no idea what sensor feeds the computer gets from the fuel system, but I can guess there are probably several sensor feeds back to the ECM, and I would guess all need to be "green" before the electronic ignition starts the fuel flowing for a start. It's plausible the start initiation is waiting for the fuel sensors to all go "green", and either the sensor or the pump itself isn't delivering. Sometime over the ten or more seconds of start attempt, the pump (or sensor) is back in spec, the ECM gets a "green", and the car starts.
This is pure speculation, but based on the fact the problem is cause after a fill up, and the one thing in the tank that can be affected by a fillup is the fuel pump.
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
Old 06-29-2008, 08:53 AM   #11 (permalink)
gadget's Avatar
I'm thinking the screen on the end of the suction tube of the fuel pump may be substantially plugged. Saturn fuel pumps used to have a check valve on the discharge side of the pump that could have something in it.( I don't know if they still have the check valve or not) High octane fuel used to destroy it.
'07 2.4 Liter
L.S. Differential
Old 06-30-2008, 08:22 PM   #12 (permalink)
JRinKY's Avatar
I have seen this behavior as well, but not related to fueling the car. It seems mostly related to "hot restarts" and is almost exclusive to having the air conditioner switched on.
VIN 00252
2.4 Manual
Midnight Blue
Old 07-17-2008, 11:43 AM   #13 (permalink)
My Photos: (3)
Got this fixed finally. For those of you looking this problem up for future reference, what needed replacing in my car was the purge solenoid. Hopefully this will be useful to you/your mechanic.
Old 07-17-2008, 12:17 PM   #14 (permalink)
MEGAS's Avatar
yeap,
i did have the exact same symptoms with the addition of a cel "P0459
Evaporative Emission Purge Solenoid Control Circuit High Voltage".
I did change this purge solenoid valve and so far all is ok.
MEGAS is offline   Reply With Quote
Old 07-18-2008, 12:14 AM   #15 (permalink)
GaryH's Avatar
Thanks for the heads up. Any idea what the purge solenoid does and how it works?
Silver Pearl
Black/Black leather
CD/MP3 XM satellite
5 speed manual
VIN#1745
Fiamm horn
Magnaflow Quad Tip Exhaust
Old 07-18-2008, 12:26 AM   #16 (permalink)
Mickey's Avatar
hopefully someone with a manual will chime in and tell us
Pontiac builds excitement...
NASSOA
Founding Member
#1922 12/03/05
N/A Classic Solstice
Mysterious
MODS:GM CAI & CATBack
Mickey is offline   Reply With Quote
Old 07-18-2008, 03:09 AM   #17 (permalink)
MEGAS's Avatar
Here is a photo of this valve.
It is connected with a canister that collects vapours and with the help of vacuum it throws vapours again in the intake manifold to be burned again.
For more info..
Ford Non-Enhanced Evaporative Systems: How They Work
Old 07-18-2008, 10:29 AM   #18 (permalink)
Bogie's Avatar
I wonder how this works with DI, seeing as we don't normally have fuel vapor in our intake manifold? If vapor is dumped in the manifold during valve overlap, then it goes right out the tailpipe unburned (or gets to combust in the exhaust channel). Not to mention possibly triggering all sorts of 02 sensor issues as it bounces down the back side.
Anyone know how a DI engine handles this dump of fuel vapor into the manifold?
Black Onyx
Black/Red Leather
Monsoon 6 Disc
French Transmission
Born July 2007
Snagged 8/31/07
