Help [ECM reflash for bad cat code?] - Saturn Sky Forums: Saturn Sky Forum
post #1 of 14 (permalink) Old 12-20-2006, 12:04 PM Thread Starter
SunburstSky's Avatar
What is a ECM Reflash? Need to explain it to techs. thanks
(the check engine light came on they cant figure out whats wrong I read a thread that a cat conv. went out on someone)
Sunburst Yellow
The Dream Continues ...
SunburstSky is offline
post #2 of 14 (permalink) Old 12-20-2006, 12:14 PM
ggccg's Avatar
This is probably something you want to studiously avoid talking to Saturn techs about or they will attempt to blame all problems on the ECM tune (if I am reading your post correctly.)
If you haven't had your ECM retuned and are just inquiring about Saturn ECM updates, they should be well aware of any and apply them at no charge.
ggccg is offline
post #3 of 14 (permalink) Old 12-20-2006, 12:23 PM
JohnD's Avatar
An ECM Reflash is a resetting of the program in the computer that controls how your car runs. Some ECM Reflashes change the mix of air/fuel, or change safety cutoffs or other tricks to alter performance.
There is some confusion in that you can also do a "ECM Reset" which deletes temporary variables stored in the ECM where it keeps information that it "learns" about the current operating environment. The ECM does this itself over time to adjust to changing conditions. You can force it to happen either through a command to the ECM with a special diagnostic/programming device that your dealer might have, or you can do it the unsophistimicated way by simply disconnecting the battery for 20 minutes. This won't change the program, it will just erase what the computer has learned about the specific particulars of your car and its typical environment and force it to relearn and adapt. And, like I said, it does this normally by itself from time to time anyway.
If you are getting a fault light indicating a bad Catalytic Converter, I don't think an ECM Reflash is the answer to your problem - if that's what you are asking.
Check out My Photos!
JohnD is offline
post #4 of 14 (permalink) Old 12-20-2006, 02:18 PM Thread Starter
If you are getting a fault light indicating a bad Catalytic Converter, I don't think an ECM Reflash is the answer to your problem - if that's what you are asking.[/QUOTE]
Thanks, that's what I was trying to figure out.
Sunburst Yellow
post #5 of 14 (permalink) Old 12-20-2006, 02:34 PM
Rick Tinley Park's Avatar
Reflashing or resetting the ECM is not going to solve a Cat converter problem. The codes are telling them what is wrong - they have to fix it.
I have been an Electronic Instrument Specialist for 20 years. Seems no one wants to believe the information the instruments supply.
When you blow a fuse - you are not fixing the problem by replacing the fuse. You replace/repair what caused the fuse to blow.
Rick Tinley Park
Delivered June 15, 2006
VIN - 3099
Sunburst Yellow
Painted Calipers
Brushed aluminum Interior panels
GM CAI
Yellow Engine cover and Fuse box
Custom Lighted Door Sills (WR)
Name - Sunni1
IL License # - YLO SKY 1
Rick Tinley Park is offline
post #6 of 14 (permalink) Old 12-20-2006, 02:38 PM Thread Starter
I wish you where the tech working on this car! I just got a call that they will reset it and have me put on 100-600 miles to see if the light comes on again! Seems to me if the light is on there is a problem. Can a cat cov. going out do any harm on other engine parts? thanks you guys for all the help!
Sunburst Yellow
post #7 of 14 (permalink) Old 12-20-2006, 03:06 PM
Send a message via AIM to Sattech Send a message via Yahoo to Sattech
excellent comment bout the fuse rick... a fuse just does'nt blow, something caused that fuse to "pop" and a mil light that comes on is caused by a particular sensor or something else.. ok i'll stop rambling on its lunch time here.. sorry
Sattech is offline
post #8 of 14 (permalink) Old 12-20-2006, 03:40 PM
JohnD's Avatar
If the light goes on, there are two obvious causes...
1. The cat is bad, the sensor is good, and so it is reporting accurately that the cat is bad.
2. The cat is good, the sensor is bad, and so it is reporting erroneously that the cat is bad.
If it's case 1, then the problems are most likely to be emission related. Your car will stink or over-pollute. I would not expect your pistons to fall out. Even if they did, then they are covered by the 100,000 mile engine and powertrain warranty.
If it's case 2, then you have nothing at all to worry about mechanically. You have a sensor going off and giving you annoying bad advice, that's all.
So I think in either case you are okay in terms of not blowing up your engine, but of course you want to find out if the problem is the cat or the sensor and get it fixed so the annoying light goes away.
JohnD is offline
post #9 of 14 (permalink) Old 12-20-2006, 03:54 PM Thread Starter
Thank John that makes me feel a whole lot better. Wanna make sure the tail end of the line in the Socal runs is up to par
Sunburst Yellow
post #10 of 14 (permalink) Old 12-20-2006, 03:55 PM
MidniteBlues's Avatar
Quoted: 8 Post(s)
I would let them know, "Hey dude, We have either a bad CAT or a bad sensor"--Take your pick, but replace one or the other--I suggest the CAT first--They seem to have shown failures more than (especially if it was sprayed with unburnt fuel)--sensors--So that would be my first choice--Resetting it will not fix the problem--trust me, if a problem exists--IT WILL come back--Replace "something" is my advice--At least for "fault isolation'- there have been a thread or 2 on this subject-
MidniteBlues is offline
post #11 of 14 (permalink) Old 12-20-2006, 04:06 PM
JohnD's Avatar
When I drive, I refer to you as "the stinger..." As in, I glance in the rear view mirror for a flash of bumble-bee yellow, and then exclaim "Our tail has its stinger. We can go now."
JohnD is offline
post #12 of 14 (permalink) Old 12-20-2006, 04:29 PM Thread Starter
I dont know why the tech seem to be afraid to work on this car or so it seems. I agree reset is just a bandaid, no worries I put 500/miles/wk so if they're trying to put me off with such a high number in miles I'll be back in a wk once it comes on obviously there is a problem. Its such a hassle to make the time to take it in every time, you would think they would be sick of seeing me monthly and just take care of the problems.
John how is your service center (I Know both are owned by the same company) but maybe the techs in ANA are a bit better?
Sunburst Yellow
post #13 of 14 (permalink) Old 12-20-2006, 04:33 PM Thread Starter
Sunburst Yellow
post #14 of 14 (permalink) Old 12-20-2006, 06:05 PM
JohnD's Avatar
Can't say. Only had an oil change done at Santa Ana, and that was fine. We haven't had to hunt anything down. I have an "iffy" DIC switch on SPIRIT; I haven't scheduled that work yet, but when I do that will be my first real test of how they do with a pesky little annoying problem.
JohnD is offline
Human Verification
