Old 02-09-2007, 12:36 AM   #1 (permalink)
Help: Engine Ticking Noise, Fuel Injectors?
I just picked up my new Sky Redline (red) from the dealer this evening, and not 5 minutes down the road I heard this faint ticking sound that increased with revs. As I continued my 45 minute drive home, the noise grew louder.
After pulling in the garage, I opened the hood and the rapid ticking sound is coming from the top of the engine. It is a continuous sound that is much louder than the engine at idle. When I rev up, the speed of the ticking increases. I believe the noise is coming from the fuel injector system.
Also, after the car idles for about a minute, the ticking noise continues but there is a new noise that repeats every 5 seconds and makes more of a clunking noise, almost like the sound of a computer hard drive that is dead and just makes that 'thunk boing' noise.
Can anyone else hear this noise, or does my car have something wrong?
What are the chances my dealer can actually test this vehicle, as my understanding is this is a new fuel system for GM. Any suggestions?
Thank you so much in advance!
redskync is offline   Reply With Quote
Old 02-09-2007, 12:54 AM   #2 (permalink)
cerberus's Avatar
My Photos: (19)
Welcome to the forum!!!! Yeah, lots of reports of injector noise here and at our related Solstice forum. I'll defer to the local Redline owners here, but sounds like you're discovering one of the normal traits of the car.
Old 02-09-2007, 01:30 AM   #3 (permalink)
Send a message via AIM to mrcheese87 Send a message via MSN to mrcheese87 Send a message via Yahoo to mrcheese87
mine makes the exact same noises and you actually used the same sound alike situation as i do..(hard drive clunking)...From what I have read on the forums, this is completely normal and just the fuel injector working. I have about 800 miles on my redline now...sounds the same as the day I picked it up with 8 miles on it and have had no issues...i'm no car mechanic, but I am a skyroadster.com pro
Stephen
Silver Graphite / Black Top
Redline
6 CD-Monsoon
Chrome
Red/Black Leather
Manual
Order put in 9.16.2006
Delivered to dealer - 1.12.2007
My Garage - 1.15.2007
http://www.myspace.com/mrcheese87
mrcheese87 is offline   Reply With Quote
Old 02-09-2007, 01:35 AM   #4 (permalink)
Update
To be clear, the noise is so loud that I hear it inside the car with the windows up and radio on at a moderate level. It is annoying to say the least. Can everyone else hear it inside the car as well?
Old 02-09-2007, 01:40 AM   #5 (permalink)
SKY Spy's Avatar
My Photos: (47)
Remember that your RedLine's fuel system is a "direct injection" system and is set-up to work at pressures up to 1,600 psi and the mechanical fule pump and the high pressure fuel injectors do make that clicking sound. There is an actual bulletin from Saturn and GM that states this is 100% NORMAL and there is no need for concern!!!
Enjoy your RedLine... You WILL get used to the clicking noise and eventually FORGET it is even there...
Have Fun!!!
Regards,
BA...
2nd SKY:
2008 RED on Red/Black Lthr
RedLine
Delivered - 7/14/08
Loaded
Auto
3" Magnaflow,
Lil Chromies & CAI
1st SKY: (Traded)
2007 Silver Graphite
RedLine
Loaded (-6CD)
Deposit - 4/11/06
Order # KFDHH7 - 5/27/06
Delivered - 2/21/07
SKY Spy is online now   Reply With Quote
Old 02-09-2007, 01:44 AM   #6 (permalink)
shadrach's Avatar
You've purchased a high-performance roadster with a little engine, light flywheel, and lots of other little 'neat' toys.
It will click, whirl, whistle, clunk, and shake. It's perfectly normal. Plus it's a GM product, so some noises might just be loose parts
shadrach is offline   Reply With Quote
Old 02-09-2007, 01:47 AM   #7 (permalink)
Yes, I can hear it inside the car...I think i forgot about it after the first, plus if i have the radio on...The only time i really pay attention to it is when i start it up and let it idle for a little bit
Stephen
Redline
6 CD-Monsoon
Chrome
Red/Black Leather
Manual
Old 02-09-2007, 01:49 AM   #8 (permalink)
Redline vs. Non - Same Fuel System?
Does the 'non' redline version have the same fuel system? If so, I know someone that I can compare noise levels with. Thanks so much for your help!
Old 02-09-2007, 01:58 AM   #9 (permalink)
Skip's Avatar
No the regular Sky is differant. DO NOT worry the noise is normal. If you want, research it by going into the archives, in search mode. Think now, 4 direct injectors putting gas into the compression chamber. It takes a whole lot of gas pressure to get it into the chamber. Plus it is running at 700 or 900 RPMs. Four solinoids kicking on and off at that speed will make some noise. You might wonder if it is not making that noise....As has been said the injectors run at high pressure to overcome the compession stage of the engine...Skip...
Skip is online now   Reply With Quote
Old 02-09-2007, 09:12 AM   #10 (permalink)
vrod's Avatar
In the old days, I'd say it was a valve issue. However, with this new type of engine here, I have to listen to what others tell me. Fuel injectors sound feasible enough. Hey, its under warranty, so if it breaks, they should fix it.
I've had good experience with Chevrolet (GM), so I put trust with their products.
RedLine, Manual
Forest Green/tan top/interior
chrome wheels
6 disc changer, XM
vrod is offline   Reply With Quote
Old 02-09-2007, 09:12 AM   #11 (permalink)
CountryGirl's Avatar
When we test drove ours at the dealer, we had the sales rep take it back to the service department because of that noise. She came right back and said that he said it was the fuel injectors. Then I remembered the discussions on the forum - OH - that noise!
I consider a lot of this stuff like my Neptune washer. It makes a lot of strange noises I've never heard from a washing machine, but it's all perfectly normal for it. Come to think of it, that sounds a lot like my husband!
Bluestone/Black REDLINE
Perma-grin since Jan 2007
CountryGirl is offline   Reply With Quote
Old 02-09-2007, 12:28 PM   #12 (permalink)
same noise from my R/L
cseadoo is offline   Reply With Quote
Old 02-09-2007, 01:14 PM   #13 (permalink)
jason's Avatar
I noticed it also, but now I feel much better knowing it is normal. I thought it sounded like a mechanics lift going up....
Redline
Sunburst Yellow!
Delivered-In garage December 2007! My late Christmas present.
6,125 miles
jason is offline   Reply With Quote
Old 02-09-2007, 02:14 PM   #14 (permalink)
TulsaSky's Avatar
High Perfomance
Yes you have a high performance car and it will make all kinds of noise, some on this forum even feel that the exhaust is not loud enough, really they change it out. In our corvette I thought the radio sounded awful until we got stuck in traffic and turned the car off and listen just to the radio. Its that big V-8 that rumbles under the hood that drowns out the radio, now I know why the Boise system is the upgrade, we bought ours for perfomance not comfort duh
With the Redline you will hear the motor and all the associated sounds and in mine the wind noise from the seal problem passenger side only when you reach 50+MPH. Start up my Impala and I have to listen for the motor, oops I have restarted the car and it was running, can't hear the motor just the difference of a well insulated 4-door family car and the Sky Redline as the hot fast convertible.
TulsaSky
07 Midnight Blue Red Line Sky
Old 02-09-2007, 02:55 PM   #15 (permalink)
Rick Tinley Park's Avatar
My Photos: (11)
TulsaSky
You know -- you are So Right
It is nice to hear a motor again, to hear it change pitch and make the mechanical sounds it really is supposed to make.
Find out about my radio show
http://www.anj.westpm.net
Founder:
www.chicagolandroadsters.com
Rick Tinley Park
Delivered June 15, 2006
VIN - 3099
Sunburst Yellow
Name - Sunni1
IL License # - YLO SKY 1
Old 02-16-2007, 12:46 AM   #16 (permalink)
glkeegan's Avatar
My ticking noise is so loud that I took it in to the dealer. Same answer, it is the fuel injectors. They gave me a copy of the service bulletin. So far I am very pleased with the Redline.
redkeygunsky
Gary Keegan-Florida
Chili Pepper Red
Turbo Sky
5 Sp Manual
Premium Trim Package
Monsoon Audio
Tan top
Splash guards
glkeegan is offline   Reply With Quote
Old 02-16-2007, 01:04 AM   #17 (permalink)
that ticking sound is the clock counting down until you, along with the rest of us has a diff problem...just kidding....enjoy all is well...it is one great car.
mdsky is offline   Reply With Quote
Old 02-16-2007, 08:23 AM   #18 (permalink)
SKYGAZR's Avatar
My Photos: (11)
FYI
SKYGAZR
SKY REDLINE LOADED AUTO. CHILI PEPPER RED WITH COBALT RED LEATHER AND CHROME WHEELS.
2007 CORVETTE Z06 6 SPEED MANUAL LOADED VELOCITY YELLOW 505HP
SOLD: Sky RL Chili Pepper Red 5 SPD MANUAL
SOLD :Sky Chili Pepper Red 2.4L
Loaded!
SKYGAZR is offline   Reply With Quote
Old 03-22-2007, 03:05 AM   #19 (permalink)
The hard drive ticking nosie is the pressure control solenoid on the mechanical fuel pump and the regular ticking is of course the injectors putting out 2,176 psi at WOT
SkyTech is offline   Reply With Quote
Old 03-22-2007, 08:29 AM   #20 (permalink)
I know they say it's a normal thing for all turbos not just the Red Line and GXP.
deluke is offline   Reply With Quote
Old 03-22-2007, 04:41 PM   #21 (permalink)
It's a normal thing for any car with electronic injection. Much louder on direct injection whether it has a turbo or not. You can hear the ticking on a non-turbo, non-direct injection car if you're outside the cabin. Yes, it's the price you pay for owning a sportscar. Lots of compromises.
Old 03-23-2007, 03:35 PM   #22 (permalink)
duck833's Avatar
Just get the magna-flow and the CAI and you will not be able to hear anything. The Magna-flow and the sucking sounds from the turbo will drown out anything else!
Ordered cars at two dealerships, ended up snagging one at Saturn of Beaverton, Oregon
Member of the Snaggers Club
RED Line
Yellow
Magna-Flow. CAI, chromies, stubby ant
Loaded
duck833 is offline   Reply With Quote
Old 04-19-2007, 12:26 PM   #23 (permalink)
