Help with Fuel Injector Wiring - Saturn Sky Forums: Saturn Sky Forum
Old 01-27-2013, 09:16 PM   #1 (permalink)
Yo Jeff's Avatar
Looking for a little bit of help on the electrical for the fuel injectors. I'm installing a Snow Performance Stage 3 Boost cooler with the variable controller. I have to hook two wires on the variable controller to the two wires on any of the fuel injectors. Getting to a single injector or the electrical connector is a task. However, the electrical harness that has a connector at the front of the rail would be my best way to tap into the 2 wires for a single injector. I just need to make sure I select the two for one injector. I can't seem to find a wire schematic or diagram for that plug. That connector plug at the front end of the harness has 11 wires, which would be right, 2 for each injector and the 3 wires for the fuel tank meter/pump sensor.
Using common sense, when you look at the wires on that connector, you have 8 wires that have a scheme, there are 4 wires on the top side of this connector, (brown, blue, and green, gray) and right below each on the bottom side of the connector is the same color with a stripe. My guess is that each injector is one of the colors mentioned above and the 2nd wire for the injector or its mate has the stripe on it. Another thing, the other side of the harness where these brown, blue, green and gray wires are, they match up to the 8 pale orange wires for the injectors.
But, really need to make sure so if anyone out there has access to the color code for the connector and the front end of that harness and can help me out, I would appreciate it.
Jeff
2008 SKY Redline
Magna Flow w/exhaust cut outs
GMPP LNF Upgrade
Fujita CAI
DDMWorks Dual Gauge Pillar Pod
Aeroforce Gauges
Eibach ProKit
DDMWorks IC/Charge Pipes
VDI Doors
Solo Hi Flow Cat
DDM Backbone & Pro-beam Brace
Venom Brace
Yo Jeff is offline   Reply With Quote
Old 01-28-2013, 08:53 AM   #2 (permalink)
Your guess looks right. This diagram is from Autozone's site...
TomatoSoup is offline   Reply With Quote
Old 01-28-2013, 01:32 PM   #3 (permalink)
Elff's Avatar
My Photos: (5)
That's the first kit I've heard of that doesn't use a Boost line or map sensor.
Good Luck, and let us know how everything works out.
LUSIFER
Old 01-28-2013, 06:17 PM   #4 (permalink)
Yo Jeff's Avatar
Thanks, now my guess won't go boom..... appreciate the help
2008 SKY Redline
GMPP LNF Upgrade
Fujita CAI
Aeroforce Gauges
Eibach ProKit
VDI Doors
Solo Hi Flow Cat
Venom Brace
Old 01-28-2013, 06:24 PM   #5 (permalink)
Yo Jeff's Avatar
Can't wait to get it all done
I'll let everybody know in a few months, I'm doing the 2871 also and have Vince waiting to do the tune, but I won't take the SKY out in the cold and snow, so it will have to wait till April or May unless we get a nice March. Wife keeps walking by it in the garage (with all the pieces parts laying around), shakes her head and comments; "hope it goes back together" and "will drive be forward and not something else"?... I tell her just don't mess with cruise control button, it might ignite the meth...
2008 SKY Redline
GMPP LNF Upgrade
Fujita CAI
Aeroforce Gauges
Eibach ProKit
VDI Doors
Solo Hi Flow Cat
Venom Brace
