Though I’ve not (yet) been there myself, first thing I’d do is to try and reach up under the dash to see if the cabling is attached – and or get to it by removing the glove box?
i might have to check this out. i tried charging a little 12v power outlet led flashlight but it didnt work so i assumed it was the light that was bad. might have to try something else in it.
You don't have to take the dash off at all. First remove the support cable in the glove box. Next carefully pull both sides of the glove box inward. This will allow the box to drop down enough to get at the outlet. Easy Peasy.
Same problem, remove glove box door and press the down on the wire. There are two hinge pins on the bottom of the door, push these toward the middle and remove them. To remove the elastic band push down on the clip. The glove box will slide up and toward you. No push of the side needed.
